Trailer Re-Paint #187429
08/08/09 05:22 PM
08/08/09 05:22 PM
V
Ventucky Red Offline OP
V
Going to be working on get my trailer roadworthy for next year and one of the projects is going to be sanding off the surface rust and refinishing it. Seem to remember a product out there that once you have the surface cleaned you painted this stuff on white, and when it cured it had turned black. It was some sort of a rust inhibitor/primer that really sealed things up to keep the rust from coming back.
Anyone know what this stuff is, or have any recommendations on other products that aren't going to require an EPA permit?
Thanks
Re: Trailer Re-Paint [Re: Ventucky Red] #187430
08/08/09 07:05 PM
08/08/09 07:05 PM
Palm Beach County
TheManShed Offline
TheManShed  Offline
Palm Beach County
Phospo is a product comes out a bluish color it turns the rust back changes the cemical properties.You can buy it at a professional auto paint store. I've used it before.
Mike Shappell
www.themanshed.com
TMS-20 Builder
G-Cat 5.7 - Current Boat
NACRA 5.2 - early 70's
Re: Trailer Re-Paint [Re: Ventucky Red] #187431
08/08/09 08:25 PM
08/08/09 08:25 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
I used a metal primer from Ameritone on some steel poles. It has held up very well in our salt air environment but you need either a stiff wind or a respirator when applying it.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Trailer Re-Paint [Re: hobie1616] #187434
08/08/09 09:54 PM
08/08/09 09:54 PM
Santa Cruz, CA
SurfCityRacing Offline
Santa Cruz, CA
Call these guys and have it coated with zinc.
LA Galvanizing
2524 E. 52nd Street
Huntington Park, Ca. 90255
(323) 583-2263
Re: Trailer Re-Paint [Re: SurfCityRacing] #187435
08/08/09 11:27 PM
08/08/09 11:27 PM
SC
zander Offline
zander  Offline
SC
I don't know if this is the stuff but I painted a car years ago and we used a product called "extends".
http://www.loctiteproducts.com/products/detail.asp?catid=13&subid=47&plid=168
it turned black an basically converts the chemical make-up of rust.
I highly recommend painting the trailer with herculiner, it's a roll on bedliner product that has served me very well.
http://www.herculiner.com/
Of course you could get it sprayed with Line-x or Rhino liner but that stuff is so expensive. The herculiner ran me a bout 100.00 a gallon but I have plenty left over for touch-ups.
Always borrow money from a pessimist. He won't expect it back.
Re: Trailer Re-Paint [Re: zander] #187449
08/09/09 09:04 AM
08/09/09 09:04 AM
South Louisiana, USA
Clayton Offline
Clayton  Offline
The stuff I use is called OSPHO (probably another name for Phospo listed above):
Product Details
OSPHO is a balnced formula of phosphoric, dichromate, wetting agents and extenders.Rusted Metal - OSPHO is a primer - NOT A PAINT. You do not have to remove tight rust. Merely remove loose paint and rust scale, dirt, oil, grease and other accumulation with a wire brush - apply a coat of OSPHO as it comes in the container - let dry overnight, then apply the paint. When applied to rusted surfaces, OSPHO causes iron oxide (rust) to chemically change to iron phosphate - an inert, hard substance that turns the metal black. Where rust is exceedingly heavy, two coats of OSPHO may be necessary to thoroughly penetrate and blacken the surface to be painted. A dry, powdery, grayish-white surface usually develops. Brush off any loose powder before painting.One gallon covers 600 square feet. Recommended for use under oil base primer or paint,
Great for use on rusted metal.
Clayton
Re: Trailer Re-Paint [Re: Clayton] #187453
08/09/09 10:17 AM
08/09/09 10:17 AM
pgp Offline
pgp  Offline
A quick search of the possible hazards includes chemical pneumonitis.
Pete Pollard
Blade 702
Re: Trailer Re-Paint [Re: pgp] #187456
08/09/09 12:26 PM
08/09/09 12:26 PM
Palm Beach County
TheManShed Offline
TheManShed  Offline
Palm Beach County
ospho could be the real name most of the letters different order - it has been a few years since I've used it.
Yes wear protection as you should with any chemical!
Mike Shappell
www.themanshed.com
TMS-20 Builder
Re: Trailer Re-Paint [Re: pgp] #187471
08/09/09 10:06 PM
08/09/09 10:06 PM
Clayton Offline
Clayton  Offline
Agreed, I guess the precautions should have also been posted, or a disclaimer included...
Re: Trailer Re-Paint [Re: Clayton] #187478
08/09/09 11:45 PM
08/09/09 11:45 PM
V
V
Yeah, been reading up on the stuff, don't think this is going to be an option.
Looks like it's going to be the Naval Jelly, Rustolem primer and paint.
Thanks all, I'll be photographing as I do it so stay tunned.
Re: Trailer Re-Paint [Re: Ventucky Red] #187494
08/10/09 08:43 AM
08/10/09 08:43 AM
catman Offline
catman  Offline
OSPHO is Phosphoric acid. Guess what's in naval jelly? The stuff is not that bad. Wear gloves, work outside, use a paint brush.
Frankly you would be better off finding someone that does Media Blasting and have the thing stripped completely. For example there's a guy around here that will strip a car frame and epoxy prime it for three hundred dollars. Way better than anything you can do and will last much longer. Look around maybe it'll be a better way to go.
Re: Trailer Re-Paint [Re: catman] #187500
08/10/09 09:46 AM
08/10/09 09:46 AM
V
V
Wow, great idea thanks, considering the time it would take me etc... this may be a way to go.
I'll start looking
Re: Trailer Re-Paint [Re: Ventucky Red] #187502
08/10/09 09:53 AM
08/10/09 09:53 AM
powder coat with a nice candy-apple red
Re: Trailer Re-Paint [Re: waterbug_wpb] #187504
08/10/09 10:06 AM
08/10/09 10:06 AM
andrewscott
andrewscott
don't forget to paint on flames
Re: Trailer Re-Paint [Re: catman] #187512
08/10/09 10:56 AM
08/10/09 10:56 AM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
Phosphoric Acid is also an ingredient in Coke (TM)
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: Trailer Re-Paint [Re: waterbug_wpb] #187528
08/10/09 12:59 PM
08/10/09 12:59 PM
V
V
I was thinking Day-Glow Lime Green with the chrome hubcaps that keep spinning when the trailer is stoped. wink
Re: Trailer Re-Paint [Re: Tornado] #187529
08/10/09 01:08 PM
08/10/09 01:08 PM
catman Offline
catman  Offline
I've heard of using Coke, Pepsi to clean rust and admit to trying it. Get a couple 2 liter bottles of Coke and pour it on and see what happens. grin
One more thing about using OSPHO (if you do) is make sure you get all the large, loose stuff off or you will be disappointed when the rust makes an early return.
Re: Trailer Re-Paint [Re: Ventucky Red] #187534
08/10/09 01:42 PM
08/10/09 01:42 PM
If that matches the boat, then Lime-green away.
Start an online discussion "Pimp my cat"
Re: Trailer Re-Paint [Re: Ventucky Red] #187540
08/10/09 04:18 PM
08/10/09 04:18 PM
Tampa, Fl
deepsees Offline
deepsees  Offline
Tampa, Fl
I have used the pickling agents before... they work as well as paint. Paint gives you a color of choice, nicer to look at. I painted my trailer the color of my below the water line color and it dresses up nice.
Deepsees
Re: Trailer Re-Paint [Re: catman] #187554
08/10/09 06:28 PM
08/10/09 06:28 PM
Santa Cruz, CA
Santa Cruz, CA
Frankly you would be better off finding someone that does Media Blasting...
Agreed. Here's the process from the anodizer I referred to in my previous post. LA Anodizing does all of the work for my custom trailer parts.
The galvanizing process consists of the following basic steps:
Oil and Grease Removal -- A hot alkaline cleaner is used to remove dirt, oil, grease and soluble markings. This process is known as caustic cleaning. This cleaning will NOT, however, remove epoxies, paint, and welding slag. Those contaminants must be removed by sandblasting, which we can arrange for you.
Pickling -- A dilute solution of hot sulfuric acid is used to remove surface rust and mill scale to provide a chemically clean metallic surface, readying the metal for the hot-dip process. This portion of the process can take anywhere from 30 minutes to 1-1/2 hours, depending on the complexity or the thickness of the part.
Fluxing -- Your steel parts will pass through this flux (a zinc ammonium chloride solution), which floats on top of our zinc bath. The fluxing process removes oxides and is intended to prevent oxidation of the steel prior to the zinc coating. This flux is then pushed aside to ensure clean removal of the steel parts from the zinc bath.
Galvanizing -- This is where the steel actually gets the zinc coating. The steel is immersed into a bath of molten zinc, which is heated between 820 and 850 F. During the galvanizing process, the steel comes up to the bath temperature and the zinc metallurgically bonds to the steel, creating a series of highly abrasion-resistant zinc-iron alloy layers, topped by an impact resistant pure zinc layer.
Inspection -- The final step in the hot-dip process to ensure compliance with the specifications. Coating thickness, uniformity, adherence and appearance are evaluated. Electronic testing gauges are used to give quick and convenient measurements of the coating. Additionally, Certificates of Compliance can be issued to satisfy the acceptable workmanship.
0 registered members (), 298 guests, and 46 spiders.
