| $3500 for a rudder!!!!!! #187751 08/12/09 04:58 PM 08/12/09 04:58 PM | DougSnell
| DougSnell
Unregistered | Friend snapped the rudder on his F-28R Sat. They want $3500 to replacemit and that is out of China!! &(*&()_)(__( has this got out of control.
Doug | | | Re: $3500 for a rudder!!!!!!
[Re: ]
#187752 08/12/09 05:07 PM 08/12/09 05:07 PM |
Posts: 129 Austin, TX | For that you could carve one out of wood...
Bo Kersey Corsair 31-1D 276 | | | Re: $3500 for a rudder!!!!!!
[Re: ]
#187754 08/12/09 05:13 PM 08/12/09 05:13 PM |
Posts: 1,200 Vancouver, BC | Check with Phil's Foils...he makes custom blades and has done Farrier blades.
[Re: ]
#187779 08/12/09 09:00 PM 08/12/09 09:00 PM |
Posts: 1,307 Asuncion, Paraguay | Friend snapped the rudder on his F-28R Sat. They want $3500 to replacemit and that is out of China!! &(*&()_)(__( has this got out of control.
Doug Is that for the blade only or for the whole thing? (blade, cassete, tilt up system, gudgeons, pintles, tiller, extension) If it's just the blade, he can have mine, foils included...
Luiz
[Re: Luiz]
#187787 08/12/09 09:56 PM 08/12/09 09:56 PM | DougSnell
| DougSnell
Doug Is that for the blade only or for the whole thing? (blade, cassete, tilt up system, gudgeons, pintles, helm, extension) If it's just the blade, he can have mine, foils included... $3400 just for the blade to be class legal Doug
[Re: Ventucky Red]
#187788 08/12/09 10:04 PM 08/12/09 10:04 PM | DougSnell
| DougSnell
Unregistered | I will be ion Chula Vista next week, maybe I'll take a run by Corsair and see what is up - for a few bucks of course. Vahn.A.Lewis at uth.tmc dot edu Maybe you can work somthing out. Vahn is cool. Doug | | | Re: $3500 for a rudder!!!!!!
[Re: TheManShed]
#187802 08/13/09 01:33 AM 08/13/09 01:33 AM |
Joined: Feb 2009 Posts: 678 Palm Beach County TheManShed
Posts: 678 Palm Beach County | I am going to have a very unique rudder system on the TMS-20. Parts of the design I still have to work out. First the dagger board and rudder are going to be in the ama. Living in South Florida and the sailing in the Islands I need to have the ability to have retractable or kick-up rudders. The main hull will not have any rudders or boards hanging from it. The rudders will be in the keel not transom hung.
The design will be classic rudder and post except the shallow water option they will be mounted in a cassette that is part if the ama stern. The cassette will have the ability to pivot up as a section of the hull, no cavitations, or loss of efficiency, and the benefit of being mounted with a center stainless tube section. Because of the location and the angle of the hull they will be at an effective angle to the water and be smaller.
Unless I punk out at the last minute and hang them from transom to speed the process up to get the boat to the water.
Mike Shappell www.themanshed.comTMS-20 Builder G-Cat 5.7 - Current Boat NACRA 5.2 - early 70's | | | Re: $3500 for a rudder!!!!!!
[Re: catandahalf]
#187865 08/13/09 10:55 AM 08/13/09 10:55 AM |
Posts: 6,049 Sebring, Florida. | When did Corsair discontinue the 28R? And what did they replace it with in that size range? Anything?
Blade F16 #777
[Re: Timbo]
#187893 08/13/09 11:53 AM 08/13/09 11:53 AM |
Posts: 490 | | | | Re: $3500 for a rudder!!!!!!
[Re: catandahalf]
#187897 08/13/09 12:02 PM 08/13/09 12:02 PM |
Posts: 6,049 Sebring, Florida. | Thanks for the link, I see they do still make the 28R...just added the letter -S- to it. That's good because when I win the Lottery, I'm getting one!
Blade F16 #777
[Re: Timbo]
#187918 08/13/09 01:17 PM 08/13/09 01:17 PM | DougSnell
| DougSnell
Unregistered | Yea Vahn's problem is staying class legal. There is a big 28R fleet in the Houston area. OH and it broke at the casing. Clean break all the way across and just floated off LOL
Doug
[Re: catandahalf]
#187955 08/13/09 03:56 PM 08/13/09 03:56 PM |
Posts: 6,049 Sebring, Florida. | The 28 R is no longer in production.
The version offered features an aft cabin, similar to the F 27. Builders are focusing on the cruising market in order to remain alive. Not even the new F 22 is available in the open **** version unless you want to build it.
Think center **** and picture a traveler track across the aft cabin.
The Sprint 750 is Corsair's new racing boat.
Aloha - B Corsair 28RS Aft **** Sport Cruiser The Corsair 28RS, like all of its predecessors & current sisters, is an easily trailerable sport boat because of its lightweight & low profile on the trailer. As with other Corsair trimarans, the transition from trailering to sailing takes about 30 minutes. The mast is raised or lowered using the installed winch on the trailer as with all Corsairs. Everything about the Corsair 28RS is designed to get you on the water & across the water quickly, comfortably & affordably. With a well-planned main cabin, the Corsair 28RS allows for family cruising even without the aft cabin; the V-berth is ideal for one or two children & can certainly accommodate two adults, & the settee area converts to two singles, or an expansion of the V-berth. Moreover, the reduction in weight & expansion of **** that results from eliminating the aft cabin makes this Corsair a bit faster & great for warm climates where less cabin space is required. So what's this? I just scrolled down on the link you provided and it was there. Pictures too. http://www.corsairmarine.com/UserFiles/Image/C28RSSpec_sheet09UpdatedNov08.pdf
Blade F16 #777
369
guests, and 101
