| Re: Cheap Lightweight catamaran hulls
[Re: nesdog]
#18822 04/22/03 05:21 PM 04/22/03 05:21 PM |
Joined: Apr 2002 Posts: 349 Fort Loramie, Ohio jmhoying
Posts: 349 Fort Loramie, Ohio | Interesting idea. But don't the hulls normally need to breathe, so as to avoid expanding in the hot sun? I would think that something like this would have a designed max pressure and therefore have a relief valve built in to control over pressurizing. It would solve the problem with my Prindle 18 hulls taking on a little bit of water every time out, but I'd probably have to have a 12 volt air pump to keep a steady pressure. Jack
Jack Hoying
Fort Loramie, Ohio
[Re: grob]
#18823 04/22/03 05:37 PM 04/22/03 05:37 PM |
The same methode is used in intercontinental missiles and various other applications.
It is definately a smart thing to do, although I'm not sure about the patent though. As this idea has been used in various other applications is stands to reason that it is not new technology any more. Also its application in boat design is not new. How about the RIB's ? Rigid inflatables boats. In effect the rubber tube around the polyester plaining surface is stiffned in the same way.
But you're definately thinking outside of the box.
[Re: char]
#18828 04/23/03 07:15 AM 04/23/03 07:15 AM |
Posts: 2,844 42.904444 N; 88.008586 W | Use Helium, or another lighter than ambient air gas, it will reduce overall weight! I've always wanted to put some sort of vessels like inner tubes, with helium in my hulls, noone would know!
F-18 Infusion #626- SOLD it!
[Re: DHO]
#18834 04/24/03 10:07 AM 04/24/03 10:07 AM |
Posts: 217 | Uh, I think there is some interesting physics in the statement "your MASS will be about the same but your weight will be a little less". Mass and weight are different, we all agree, but two objects with same mass, in same gravitational field, have the same weight, don't they?
[Re: jcasto1]
#18835 04/24/03 12:20 PM 04/24/03 12:20 PM |
Posts: 12,310 South Carolina | I'm gonna have to belly up and agree with with Jcasto.
Jake Kohl | | |
20,780
guests, and 1,475
