Page 3 of 3 1 2 3
Re: raising mast forward [Re: Peter_Lyons] #190835
09/11/09 07:27 PM
09/11/09 07:27 PM
Maryland, USA
PRagen Offline
PRagen  Offline
Maryland, USA
I raise my Taipan mast solo from the front as shown on the attached photos. Starboard shroud and front stay are pre-attached. The cheap PVC tripod holds the mast above the hull. The mast angle is needed because of the shroud length. I sometimes use the rope attached to the trap line if it is windy, or sometimes just raise it and hold up until I can grab the trap line then hold that while attaching the port shroud.
Mast raising holder
Mast Base
Temporary Support
Patrick Ragen
Taipan 4.9 USA 274
Re: raising mast forward [Re: PRagen] #190840
09/11/09 11:56 PM
09/11/09 11:56 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
Patrick,
Tell me about your mast, it looks a lot like the one on my '93 Boyer A cat. And what are you using for non skid, it looks great!
Dave
Re: raising mast forward [Re: davefarmer] #190842
09/12/09 12:28 AM
09/12/09 12:28 AM
Maryland, USA
PRagen Offline
PRagen  Offline
Maryland, USA
Originally Posted by davefarmer
Patrick,
Dave
Dave, I am not sure what you want to know about the mast. It is a standard Taipan 4.9 mast. I think the Blade F16's use the same section. At least that's what I heard when I was looking for a replacement when my mast was destroyed last year in a storm. Luckily I was able to find an extra stateside on the right coast.
I can't tell you anything about the Non-skid as it was on there when I bought the boat. It works well though.
AHPC Taipan 4.9 Mast
Damaged Mast
Non Skid
Patrick Ragen
Taipan 4.9 USA 274
Re: raising mast forward [Re: davefarmer] #190850
09/12/09 08:14 AM
09/12/09 08:14 AM
looks the same as Hydro-Turf, which is available in the on-line store
color chart
Re: raising mast forward [Re: _flatlander_] #190853
09/12/09 09:08 AM
09/12/09 09:08 AM
I am always amazed and impressed over how much work you guys have to do if you want to go sailing! Compared to us slackers who enjoy mast up storage at clubs with slipways covered by synthetic grass, shelters to change into drysuits, waterhoses and all kind of facilities, you are hardcore!
Re: raising mast forward [Re: PRagen] #190874
09/12/09 09:58 PM
09/12/09 09:58 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
Patrick,
The mast base just looks so similar to mine, I gues I was wondering if AHPC use the same extrusion for the Taipan as the A cat(31').
Thanks for the connection of Hydro Turf!
Dave
Re: raising mast forward [Re: davefarmer] #190875
09/12/09 11:47 PM
09/12/09 11:47 PM
Dave- You can get Hydro turf in patterns and colors. If you go to their website they have stuff that was ordered or not made to spec for cheap. You can also get it with a PSA already applied, so just peel n' stick. I've been thinking about doing the whole deck inbetween the beams, (like the Wildcat}, on my boat. I did a little 4"x30" strip where the tiller was rubbing on the gelcoat, and really like sitting on it.
Re: raising mast forward [Re: pgp] #190889
09/13/09 10:33 AM
09/13/09 10:33 AM
JJ_ Offline
JJ_  Offline
Re: raising mast forward [Re: phill] #190971
09/14/09 08:35 PM
09/14/09 08:35 PM
pgp Offline OP
pgp  Offline OP
Worked like a charm. SOP from now on.
Pete Pollard
Blade 702
Re: raising mast forward [Re: pgp] #192097
09/27/09 12:51 AM
09/27/09 12:51 AM
Arkansas, USA
Arsailor Offline
Arsailor  Offline
Arkansas, USA
I worked out a system a long time ago to raise my mast forward on my trailer for my Taipan. Basically consisted of drilling 1/4" holes in ends of front beam for caribiners clipped to trap lines to prevent sidesway, telescoping front mast stand, plate on front trailer beam support to clip mainsheet blocks to, plate on rear mast stand for 1:2 blocks that clip to mainsheet then line runs through turning block at rear mast stand and to caribiners that clip to shrouds. Trick is to have mast stand far enough in front of front beam that you can slide the mast up mast stand (I have a roller for that) far enough to fit mast base pin before the spreader hits the mast stand. Then simply lift mast with one arm while "sheeting in" on mainsheet (mainsheet does most of the "work" and you can stop and cleat at any time if necessary). Once get mast up simply unclip caribiner from side shroud and connect first one side then other- I put my trap harness on so I can tension with trap line when hooking up last shroud. Dropping is reverse of above. I have tried to include a photo of my boat with mast ready to raise.
Kirt
Kirt
Taipan 4.9 USA 159, Flyer USA 185
Will sail for food...
Re: raising mast forward [Re: Arsailor] #192425
09/30/09 10:28 PM
09/30/09 10:28 PM
JJ_ Offline
JJ_  Offline
Kirt
That looks good.
If I get it correctly, you are using both shrouds to lift the mast then, correct?
The forestay and bridles are already rigged...
Then you unhook one shroud at a time to connect?
Page 3 of 3 1 2 3
0 registered members (), 794 guests, and 436 spiders.
