| Rig Tension #190255 09/04/09 10:32 AM 09/04/09 10:32 AM |
Posts: 34 | This weekend will be light wind. Do we still go as tight as possible on the shrouds?
-Kevin Hobie Wave "Demons" #666
| | | Re: Rig Tension
[Re: KevinMarple]
#190278 09/04/09 12:58 PM 09/04/09 12:58 PM |
Posts: 921 Alachua, FL | This weekend will be light wind. Do we still go as tight as possible on the shrouds? Rick etal, say never go tight at all. Loose is good.
Jack Woehrle Hobie Wave #100, Tiger Shark III HCA-NA 5022-1 USSailing 654799E Alachua FL/Put-In-Bay | | | Re: Rig Tension
[Re: RickWhite]
#190369 09/05/09 11:05 AM 09/05/09 11:05 AM |
Posts: 235 | Really? With the standard forestay adjuster, I rake back as far as I can.
But I tighten to the third hole from the bottom on the sides.
The fourth hole from the bottom on occasion.
Any looser and the mast bangs around in chop and light winds.
So do you tighten the rig overall in light winds and loosen it in heavy winds?
| | | Re: Rig Tension
[Re: JJ_]
#190420 09/06/09 06:41 PM 09/06/09 06:41 PM |
Posts: 34 | we ended up racing in 2-3 knt when it was good so any light air advice would be good. I have a 10 hole fore stay and kept the forestay on the 1st hole. my shrouds were at the bottom hole of the chainplate but it still seemed loose.
| | | Re: Rig Tension
[Re: KevinMarple]
#190612 09/09/09 07:24 AM 09/09/09 07:24 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | Those who race with success all use loose rigs. If you grab the sidestay with your fist and twist it, you should see an angle of about 45-degrees. That is pretty loose, but could even be looser.
As soon as you go off the wind at all, the battens will bump up against the sidestay. With loose rigging, the sail will push the sidestay away and maintain its shape. If a tight rig, the batten will invert and you will have terrible shape. Rick | | | Re: Rig Tension
[Re: RickWhite]
#192975 10/08/09 07:35 PM 10/08/09 07:35 PM |
Joined: Jun 2001 Posts: 425 Toledo, Ohio (western end of ... Mike Fahle
Posts: 425 Toledo, Ohio (western end of ... | A loose rig downwind on the Wave is faster than a tight rig, especially if you are raked back as far as you should be to be fast and point high upwind. HOWEVER, if you do not want the rig to slam around in chop and break your bridle wire like Rick's did in Duck, N.C., then you may want to tighten the shrouds just for that reason. If you are racing and want to win, then just put up with the slamming rig and make sure you check it diligently after the races and replace anything suspicious, right Rick?!
| | | Re: Rig Tension
[Re: Mary]
#193002 10/09/09 07:59 AM 10/09/09 07:59 AM |
Posts: 921 Alachua, FL | It would be nice if we could have lever things on our shrouds to increase/decrease rig tension as needed on the water -- similar to what the old A-Class cats had on their mast to change bridle-wire tension. This is what we had on the Hobie 14s. It worked well to eliminate the slop and damage. <<5.3 A single line or shock cord line may be secured to the bridle intersection and run to a cleat on the front crossbar to adjust mast rake. The mechanical purchase shall not exceed 1:1.>> It seems to me that this would be a reasonable ammendment to the rules.
1 registered members (FredL),
2,406
guests, and 222
