H16 mainsheet line best thickness / 3/8 vs. 7/16 vs. 1/2 #190456
09/07/09 09:48 AM
09/07/09 09:48 AM
Southern Illinois
rfarson Offline OP
rfarson  Offline OP
Southern Illinois
What is the best thickness for the mainsheet line in most boats. Seems there are different recommendations.
I'm not really a racer but do want the line to go through the blocks well but still be easy on the hands!
thanks
~~~Ron
Re: H16 mainsheet line best thickness / 3/8 vs. 7/16 vs. 1/2 [Re: rfarson] #190472
09/07/09 03:43 PM
09/07/09 03:43 PM
I use 5/16". It seemed awfully small at first, but it runs through the blocks like butter and isn't that bad on the hands. Depends on the type line you get.
7/16" and 1/2" are too big.
3/8" works OK, but it depends on the type of line you use.
What's your budget? Sampson Trohpy braid is a good all-around line that's easy on the hands. About $1.13/ft for 3/8".
Or, you could go to the Cadillac of lines - Maffioli Swiftcord at $2.87/ft for 3/8"
Lots of stuff in between.
Re: H16 mainsheet line best thickness / 3/8 vs. 7/16 vs. 1/2 [Re: mbounds] #190474
09/07/09 04:35 PM
09/07/09 04:35 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Use 5/16. The 3/8 will run but it does drag through the blocks.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: H16 mainsheet line best thickness / 3/8 vs. 7/16 vs. 1/2 [Re: hobie1616] #190523
09/08/09 10:08 AM
09/08/09 10:08 AM
the question is...what size blocks?
If you're talking original, 5:1 Seaway, or the 80's Harken 6:1 setup 3/8" will probably be OK. Those blocks are all good sized.
If you're running, or plan to run, with the latest set-up and the 40mm carbo upper block, definitly go with 5/16" (salsa wink )
Re: H16 mainsheet line best thickness / 3/8 vs. 7/16 vs. 1/2 [Re: _flatlander_] #190610
09/09/09 06:34 AM
09/09/09 06:34 AM
Southern Illinois
rfarson Offline OP
rfarson  Offline OP
Southern Illinois
yeah, I have the Harken 6:1 setup so will go with 3/8. Smaller may hurt my hands..
~~~Ron
Re: H16 mainsheet line best thickness / 3/8 vs. 7/16 vs. 1/2 [Re: rfarson] #190620
09/09/09 08:23 AM
09/09/09 08:23 AM
Thunder Bay ON CAN
M
mmadge Offline
mmadge  Offline
M
Thunder Bay ON CAN
5/16 is the way to go,get Yale Light it lists at 5/16 but runs a little fatter (easier on hands).
Re: H16 mainsheet line best thickness / 3/8 vs. 7/16 vs. 1/2 [Re: mmadge] #191722
09/23/09 12:41 AM
09/23/09 12:41 AM
K
Keven Offline
Keven  Offline
K
How do I find out what size blocks I have?
0 registered members (), 439 guests, and 51 spiders.
