Battens for Jib #190512
09/08/09 09:01 AM
09/08/09 09:01 AM
H
H16-71833 Offline OP
H
Looking for comments on this:
Why would I want to leave battens in my jib? I have a non-furling jib on my H16. The battens often get "stuck" on the mast when coming about. If I were using a furling jib, there are no battens, so can I take them out?
I know that they are used to control sail shape and all... What is the reality.
Re: Battens for Jib [Re: H16-71833] #190524
09/08/09 10:11 AM
09/08/09 10:11 AM
California
mmiller Offline
mmiller  Offline
California
If you remove the battens you get a big floppy bag of a sail with a flapping leech. Not good. The sail needs to be cut in a different way to got "battenless".
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: Battens for Jib [Re: H16-71833] #190589
09/08/09 08:08 PM
09/08/09 08:08 PM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
Take 'em out and go for a sail. You will answer your own question. If it looks OK to you, then you don't need 'em.
It it looks like a baggy POS then you do. It all depends on your level of appreciation for a nice looking sail.
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Alachua FL/Put-In-Bay
Re: Battens for Jib [Re: Mugrace72] #191085
09/15/09 10:42 PM
09/15/09 10:42 PM
Floyd Offline
Floyd  Offline
You can cut the battens down so they barely stick out then they dont hang up or try the super jib battens they get good comments on the Hobie site.
Re: Battens for Jib [Re: Floyd] #191123
09/16/09 02:59 PM
09/16/09 02:59 PM
Panama City Beach, FL
Tim H16 Offline
Tim H16  Offline
If your battens get hung up it is usually since they get caught on either the jib or main halyards.
I put a Hobie "halyard grip" on the mast to pull the jib halyard back to the side of the mast.
After I raise the main and set the main halyard's stop in the halyard hook at the top of the mast, I swing the main halyard behind the shroud and then tie it off to the mast cleat. Next I use the last foot of the downhaul rope to loop around the main halyard and then pull it all the way over to the downhaul cleat and then tie it off.
This keeps the jib and main halyards away from the ends of the jib battens so they can easily slide across the front of the mast.
Tim
'82 H16
Sail #88863 Blue Prism
Re: Battens for Jib [Re: Tim H16] #191133
09/16/09 04:56 PM
09/16/09 04:56 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
[Linked Image] Instead of a halyard grip try a Ronstan RF 185 cheek block. Place it just above where the top batten hits the mast and as far back as possible without drilling holes into the sail track. Make sure the open side faces aft.
US Sail Level 2 Instructor
US Sail Level 3 Coach
