| Re: Designing/Building an F16
[Re: Brett Goodall]
#190873 09/12/09 09:20 PM 09/12/09 09:20 PM |
Posts: 190 | That design was a quick throw together. I am not in the boat design biz. As to construction.. I have used 4mm okume ply for tortured wood construction in the past (a-cat and 18Sq) but for strip planking I think it would be to thin to get a proper tongue and grove joint. As to the beam issue I am using 4" (125+/-) .069 wall 6061 T6, these beams are leftover from an 18Sq project from 20 years ago. I am working on a oval carbon tube design to fit to my boat next year. Coming from a 18Sq background (and having not sailed a cat with a crew in a very long time) I am unfamiliar with the dynamics of an F-16 so any thing I suggest should be take with a few grains of salt.
lesburn1.blogspot.com
A-Cat USA 49 18Sq 49
[Re: taipanfc]
#190914 09/14/09 03:56 AM 09/14/09 03:56 AM |
Posts: 50 | HI JC, Yes, it would certainly be easier and probaly cost the same but it wouldn't be as much fun. I sail occasionally with David Lee on his Taipan and he has offered me a share in his boat but I have this urge to try out my ideas and to build a boat. Its like an itch, if you scratch the wrong place you wont get rid of it....
My ideas are basically that for the hull, if you have a smooth curve to the underwater shape, correct volume distribution and a fair hull you have a good hull shape. Then you need to be at the minimum weight and the whole thing has to be stiff. A lot of the speed is in the rig but most of all the sailor.
DIY is a compulsion...
Shane
[Re: pilgrim]
#190915 09/14/09 03:59 AM 09/14/09 03:59 AM |
Posts: 50 | This is at table of the hull half-widths in inches, stations are 12 inches apart. The bow is Station 0. Above the datum line the hull can be vertical sided, below the datum line, the hull is a semicircle with radius as in the table. Its basically a circular arc, formula of a circle is r^2 = x^2 +y^2 y = sqrt ( r^2 - y^2 ) - put this into a spreasheet and input R=1410 inches and you get this arc...
HULL WIDTH 13.50 INCHES TRANSOM WIDTH 10.96 STATION 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 0.75 1.64 2.61 3.48 4.25 4.92 5.48 5.94 6.30 6.55 6.70 6.76 6.70 6.55 6.30 5.94 5.48
The bow will have a bulb of radius 0.75"
[Re: pilgrim]
#190994 09/15/09 06:22 AM 09/15/09 06:22 AM |
Joined: May 2006 Posts: 954 Mumbles Y.C Wales U.K Mark P
Posts: 954 Mumbles Y.C Wales U.K | Hi Shane Unfortunately I don't work in inches, so the dim's for my single handed design are 300mm (12"approx) wide at the front beam, 295mm (11.75"approx) at the rear of the C/B case and 270mm (10.62"approx) at the transom. The depth of the hull under the front beam is identical to both the Stealth, Auz Tool & Bimare AJ, roughly 460mm (18.25") MP*MULTIHULLS | | | Re: Designing/Building an F16
[Re: Rolf_Nilsen]
#191231 09/18/09 03:20 AM 09/18/09 03:20 AM |
Posts: 50 | Thanks Rolf, Thats something to strive for...but my calculations so far yield 25.5kg per hull... guess i have to thin the wood i will be using...myabe I will planedown the thickness at the bow and stern.
Carbons tubes are the ultimate!May I ask what weight of cloth you are using for the carbon beams and how many layers? I assume you are going to bolt a traveller track onto the beam..
Shane
[Re: Rolf_Nilsen]
#191241 09/18/09 08:27 AM 09/18/09 08:27 AM |
Posts: 6,049 Sebring, Florida. | Rolf, on the beams, are you going to glue them to the hulls or drill and bolt them? I would think glue would be the best way to go but then you can't get them apart easily either.
Blade F16 #777
[Re: Timbo]
#191244 09/18/09 08:51 AM 09/18/09 08:51 AM |
Posts: 2,718 St Petersburg FL | Rolf, on the beams, are you going to glue them to the hulls or drill and bolt them? I would think glue would be the best way to go but then you can't get them apart easily either. And very illegal according the F16 class rules. | | | Re: Designing/Building an F16
[Re: Robi]
#191246 09/18/09 09:07 AM 09/18/09 09:07 AM |
Posts: 6,049 Sebring, Florida. | Well some day I might actually read all the rules...some day. ;^) I thought carbon beams were illegal as well? Or carbon anything?
Blade F16 #777
[Re: Timbo]
#191255 09/18/09 09:44 AM 09/18/09 09:44 AM |
Posts: 439 Memphis, TN | Carbon is LEGAL, and I think if you wanted to, you could build the whole boat out of carbon if you'd like. At least, I think.
Viper USA 132
1984 Hobie 18
3,236
guests, and 277
