Rigging #19163
05/01/03 11:01 AM
05/01/03 11:01 AM
Adrock Offline OP
Adrock  Offline OP
How do I get my rigging tight? When i hoist my jib I can get slack on my fore stay I usualy move the shackel down at this point to make things tighter but i could do more.Is there some sort of basic formula where your pins should be on all of your wires for the right mast rake and tightness?
Re: Rigging [Re: Adrock] #19164
05/01/03 11:04 AM
05/01/03 11:04 AM
Nigel Offline
Nigel  Offline
let's start at the beginning...what type of boat are you talking about??? Nige
Re: Rigging [Re: Adrock] #19165
05/01/03 11:08 AM
05/01/03 11:08 AM
Adrock Offline OP
Adrock  Offline OP
80's Hobie 16
Re: Rigging [Re: Adrock] #19166
05/01/03 11:32 AM
05/01/03 11:32 AM
Fort Loramie, Ohio
jmhoying Offline
jmhoying  Offline
Fort Loramie, Ohio
Hello,
When your jib is rigged and tight, your forestay will be slack.
Is this what you are concerned with?
Jack
Re: Rigging [Re: jmhoying] #19167
05/01/03 11:53 AM
05/01/03 11:53 AM
Adrock Offline OP
Adrock  Offline OP
Yep that is what im wondering is this wrong am I pulling the jib haylard too tight or is my rigging too loose?
Re: Rigging [Re: Adrock] #19168
05/01/03 01:17 PM
05/01/03 01:17 PM
U
unlvrebel Offline
unlvrebel  Offline
U
On an H16, when you hoist the jib the forestay becomes slack. This supposed to happen. You now end up with the jib stay holding the front point of the boat with the shrouds holding the side. Do not adjust the forestay after setting the forestay. You will only have to readjust it to unstep the mast.
As for the proper tensioning of the jib and shrouds, there is a lot to read. Too much for me. I go with what feels right making sure that the mast is properly supported.
John
Palmdale, CA
H16
0 registered members (), 3,236 guests, and 277 spiders.
