| Re: D.I.Y. Square top for Nacra 5.2 worthwile?
[Re: DennisMe]
#191829 09/24/09 06:20 AM 09/24/09 06:20 AM |
Posts: 1,203 uk | I would have thought that it would be really tricky to get the leach of a dacron square top to behave. sail would stretch pretty quickly
[Re: TEAMVMG]
#191830 09/24/09 06:39 AM 09/24/09 06:39 AM |
Posts: 4,451 West coast of Norway | I would have thought that it would be really tricky to get the leach of a dacron square top to behave. sail would stretch pretty quickly I guess you are assuming the sail to be a crosscut? A radial cut will handle it OK. | | | Re: D.I.Y. Square top for Nacra 5.2 worthwile?
[Re: DennisMe]
#191933 09/24/09 11:32 PM 09/24/09 11:32 PM |
Posts: 4,451 West coast of Norway | Dennis, unless you get a pentex cloth with fibers running like they do in the Maxx cloth and it's like (0-90,+-45 and 70 I think, it has beena while) the pentex will distort just as bad as dacron. You need fibers oriented along the load paths and in a squaretop that is hard to to with a crosscut layout. Maxx cloth is pretty well suited. The Maxx Pen09 might fit you, or something heavier. Crosscut is definately the way to go for building from scratch at home. Radial is a lot more work. Check out Contenders website and give them a call. You might get a good deal on some Maxx for your first deal with them. http://www.contendersailcloth.com/maxx.asp?Sid=3&SHid=530&SWid=1004Take care with Sailcut. When you e.g. add luff curve , the height of the sail will be changed. What you put in is not what comes out, but is slightly different. On a mainsail this is noticeable, but you can fix it with some creative work with scissors before you put on patches and tape along the foot. For sails that have to measure in, check all dimensions after assembling panels. Thanks for the info on the sewing machine. As you probably guessed the budget for items like his is ever low.  I now have a secondhand Pfaff domestic machine with their walking foot solution. Picked it up for about EUR120 and it has chugged its way through 5 sails by now. It really struggles with patches and thread tension. Runs out of thread on the bobbin etc. but it works. Let me know when you begin to import the Taiwan machines.  | | | Re: D.I.Y. Square top for Nacra 5.2 worthwile?
[Re: Rolf_Nilsen]
#191936 09/25/09 01:46 AM 09/25/09 01:46 AM |
Posts: 571 Hamburg | Hi Dennis, I remember that the price difference between Dacron and Pentex wasn't that much, when we asked our sailmaker for a new spi trumpet. However it wasn't MAXX or FLEXX of course. The only cost is in new battens Right battens are expensive, but so simple that even I could make it by myself (and I don't even have workshop). Feel free to contact me for details. Cheers, Klaus Ah, and go for s square top. A good square top is always better than a pin head sail and a bad square top is still better than a bad pin head sail. You may need a more powerfull main sheet. | | | Re: D.I.Y. Square top for Nacra 5.2 worthwile?
[Re: Smiths_Cat]
#191938 09/25/09 02:36 AM 09/25/09 02:36 AM |
Posts: 4,451 West coast of Norway | The only cost is in new battens Right battens are expensive, but so simple that even I could make it by myself (and I don't even have workshop). Feel free to contact me for details. New thread perhaps? I would love to hear your thoughts. Ah, and go for s square top. A good square top is always better than a pin head sail and a bad square top is still better than a bad pin head sail. You may need a more powerfull main sheet.
Square tops rule  | | | Re: D.I.Y. Square top for Nacra 5.2 worthwile?
[Re: Rolf_Nilsen]
#191940 09/25/09 03:09 AM 09/25/09 03:09 AM |
Posts: 431 Netherlands | Ok Guys: Square top it will be! Smiths_cat, any help on the battens is appreciated (I already have a vacuum pump; aka old hermetic airconditioner pump). I would love to hear what you have to say on making those battens! Separate Thread on Making battens (Please post in this separate thread!)
542
guests, and 44
