Rake back the mast ....... a mystery ! #192598
10/04/09 10:05 AM
10/04/09 10:05 AM
C
cooper engineer Offline OP
C
Please help me !
I have tried in much forum and pages web but are't successful to find a convincing answer to my question:
Rake back the mast the mainsail aerodynamically improves the performance? ..... and why ?
Thanks
Re: Rake back the mast ....... a mystery ! [Re: cooper engineer] #192600
10/04/09 10:52 AM
10/04/09 10:52 AM
SE Pa. or Chesapeak Bay
HMurphey Offline
HMurphey  Offline
Depends on the boat .... Yes, Daggerboards??? No Daggerboards ....
The H16 likes to have alot of mast rake ... No daggerboards
The TheMightyHobie18 likes only a little mast rake ... Yes, daggerboards
To mathmatically prove it, takes some very involved calculations to prove why involving both hydrodynamics and aeodynamics. But it involves where the "center of effort" is on the sail and where the "center of effort is on the hull and underwater foils ... and how they combine.
Harry
Re: Rake back the mast ....... a mystery ! [Re: HMurphey] #192601
10/04/09 11:25 AM
10/04/09 11:25 AM
C
C
Sorry , yes Daggerboards ...TheMightyHobie18 ..... but how mach "little" mast rake ? where is the limit ?
Re: Rake back the mast ....... a mystery ! [Re: cooper engineer] #192604
10/04/09 11:56 AM
10/04/09 11:56 AM
The limit is your ability to get a firm leech on the sail. Block-to-block on the main system with a firm leech is as far as you can go.
Re: Rake back the mast ....... a mystery ! [Re: John Williams] #192606
10/04/09 03:03 PM
10/04/09 03:03 PM
Scarecrow
Scarecrow
Cooper, mast rake hanges a few things and as a result a full explaination is complicated. But the main reason it helps is to do with lift distribution.
with the mast upright the centre boards are providing most of the hydrodynamic lift that stops your boat going sideways. In order to develop this lift your boat must go sideways a little (leeway) so that the angle of attack of the symetrical foils is sufficient to generate lift. If you rake your mast back then the cntre of effort moves aft so that now the rudders are also being asked to supply lift.
by splitting the load between the boards and rudders you have reduced the amount of lift required from the centre boards and therefor the amount of leeway you'll need to generate said lift. As a result you'll point higher.
As JW says the limit is defined by when you go vlock to block on your main, but before that happens you may find you've developed to much weather helm, making your boat hard to sail.
Re: Rake back the mast ....... a mystery ! [Re: ] #192607
10/04/09 03:15 PM
10/04/09 03:15 PM
Hard to sail = slower, just to point that out smile
There are also some zany mathematics on how pressure distribution changes as the leading edge of a foil is raked aft, how it becomes more stall tolerant and loads of other stuff that is relatively "far out".
My thumb of rule on mast rake: Rake the mast aft until you can let go of the helm when going upwind in your dominant conditions and with crew/sails trimmed for best VMG.
We experimented with rake a lot while sailing the Tornado. For us the class standard ment that the rudder(s) at times was overloaded and lost grip. Then we had to sheet out to regain control. When we corrected this we became faster. We sailed at 200kgs crew weight which was not the norm. Find the setting that suits you and that is your setting cool
Re: Rake back the mast ....... a mystery ! [Re: cooper engineer] #192608
10/04/09 04:28 PM
10/04/09 04:28 PM
Budapest, Hungary, Europe
CatSailingHu Offline
My really simple rule (no mathematics.. ) :
rake the mast forward! until you can manage the boat in downwind without pichpole or without to much risk at the given conditions (wind and waves).
Sanyi
Nacra Infusion
www.catsailing.hu
Re: Rake back the mast ....... a mystery ! [Re: cooper engineer] #192612
10/04/09 05:37 PM
10/04/09 05:37 PM
UK
Cheshirecatman Offline
UK
Aside from the H16 trim application where you can vary the CLR, a heavily raked mast can help create a rollover vortex to delay separation on the low pressure side.
Cheshirecatman
Re: Rake back the mast ....... a mystery ! [Re: Cheshirecatman] #192622
10/05/09 12:36 AM
10/05/09 12:36 AM
C
C
Cheshirecatman
Finally a technical explanation!
Can give a detailed explanation of this vortex?
Re: Rake back the mast ....... a mystery ! [Re: cooper engineer] #192623
10/05/09 05:31 AM
10/05/09 05:31 AM
UK
UK
With the limited rake of a sailboat mast it is more likely a series of inconsistent vortices which will help delay separation. The result is greater tolerance to sail trim and less tendancy to stall.
I believe there is benefit to be had from deliberately generating more controlled vortices to do this. This has been the subject of previous threads.
Cheshirecatman
Re: Rake back the mast ....... a mystery ! [Re: ] #192627
10/05/09 06:44 AM
10/05/09 06:44 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
That all makes pretty good sense, but would also mean that moving the whole rig backwards would have the same effect. [yes that would mean moving the front beam]
there does seem to be some benefit from having the mast angled back from the vertical. Could it be that some lift is generated? A bit like the long spinny pole on a H16 rakes the spinnaker luff and generates lift?
Re: Rake back the mast ....... a mystery ! [Re: TEAMVMG] #192679
10/05/09 04:07 PM
10/05/09 04:07 PM
Scarecrow
Scarecrow
Some light reading on the aerodymanic component of mast rake.
Marchaj
Re: Rake back the mast ....... a mystery ! [Re: ] #192684
10/05/09 04:30 PM
10/05/09 04:30 PM
andrewscott
andrewscott
Available from these sellers. - 1 used from $999.99
$999.99 ???????????? unless the book comes with a new main sail..... WhatTheHECK ???
Re: Rake back the mast ....... a mystery ! [Re: ] #192694
10/05/09 05:34 PM
10/05/09 05:34 PM
UK
UK
Re: Rake back the mast ....... a mystery ! [Re: Cheshirecatman] #192704
10/05/09 07:27 PM
10/05/09 07:27 PM
ncik Offline
ncik  Offline
A-class cats with their highly efficient and very vertical masts would disagree with the vortex theory.
Scarecrow's explanation is as technical as needed for improving upwind performance. The trick is finding the right balance for fastest times around the course. Balance of lift to drag as well as upwind and downwind performance.
Re: Rake back the mast ....... a mystery ! [Re: ncik] #192706
10/05/09 08:33 PM
10/05/09 08:33 PM
Herbie53 Offline
Herbie53  Offline
+1 - 2 Day Acat regatta a couple weekends ago, first day I was going upwind as fast or faster than anyone, only to get my clock completely cleaned downwind (3 or 4 boats per leg). Moved the mast forward 1 pin for day two and was able to mostly hold my position downwind (always somewhat of a challenge since I'm 215#) in spite of usually deadly (to me) light air. I think optimum rake is a very situation and boat specific thing... more is not always better.
Re: Rake back the mast ....... a mystery ! [Re: Herbie53] #192709
10/06/09 12:59 AM
10/06/09 12:59 AM
C
C
..... as imagined, there isn't a definitive solution.
Re: Rake back the mast ....... a mystery ! [Re: cooper engineer] #192731
10/06/09 08:37 AM
10/06/09 08:37 AM
andrewscott
andrewscott
There is no 1 asnwer to a question with so many variables....
Even with all the variables... the great sailors almost always finish in the top spots... so there is non-definitive solution !
Re: Rake back the mast ....... a mystery ! [Re: ] #192803
10/06/09 05:11 PM
10/06/09 05:11 PM
Will_R Offline
Will_R  Offline
Also, don't forget a/b Uni's and the location of your daggers. The further aft your daggers are, the more rake you will HAVE to run to balance all the CE's.
Re: Rake back the mast ....... a mystery ! [Re: Will_R] #192859
10/07/09 10:49 AM
10/07/09 10:49 AM
is that like the 'shared lift' concept of the ARC/supercat designer?
so if you moved the boards well forward, and kept the rake more vertical, does sailplan efficiency increase? Kind of like swept wings vs. straight wings in aircraft?
0 registered members (), 21,948 guests, and 1,940 spiders.
Most Online23,915
6 seconds ago
