| Re: Getaway "sport"
[Re: GregK]
#19343 05/07/03 01:14 PM 05/07/03 01:14 PM |
Posts: 4 | I disagree that it defeats the purpose of the boat. True, it will add a step to the rigging, but you will retain all the other features of the boat like the high floatation, foward tramp, wings, coolers in hulls, etc... .
The purpose of adding a boom is not just to give the bottom of the sail some stiffness, but to allow a wider sail than the current one used (within limits of the boat design), giving extra sail area and extra power. A boomless rig limits the width of the sail to be between the mast and foward of the main traveler.
I was thinking the mod would be something extra and the original boomless configuration would still be available by using the original sail. The mast would simply have a slot to add a boom. You would need a wider sail to use the boom which you could purchase as an extra part giving you 2 different sails, thus the way to get extra power (boom and wider sail). This is why I called it a "getaway sport" and not a totally different boat. If you want to cruise you can go boomless. If you want to fly a hull and go fast or race you can put on the boom and the wider sail.
Does anyone have any idea if a wider sail, say 1 foot wider at the base, would make much difference? How about adding a boom?
Greg | | | Re: Getaway "sport"
[Re: flounder]
#19345 05/09/03 02:41 PM 05/09/03 02:41 PM |
Posts: 12,310 South Carolina | good lord! - tell us what you really think!
Jake Kohl | | | Re: Getaway "sport"
[Re: GregK]
#19348 05/12/03 10:51 AM 05/12/03 10:51 AM |
Posts: 12,310 South Carolina | It's still a lot faster than a comparable monohull!
[Re: flounder]
#19350 05/12/03 04:36 PM 05/12/03 04:36 PM |
Posts: 12 Dallas, TX, USA | have you ever seen somebody fly a hull on a getaway for an extended amount of time? I have a getaway and am a beginner sailer. I find it very difficult to 1) get the hull up (but i usually have 4-5 people on it  ) 2) when i do get it up, it goes over or likes to bury the front nose. btw: i completely turtled my getaway on saturday this past weekend. a power boat helped me unturtle it, b/c i didn't know that you just have to stand on one side and be VERY patient. it sure was fun though.
Ssyba
'01 Hobie Getaway
| | | Re: Getaway "sport"
[Re: ssyba]
#19351 05/12/03 04:49 PM 05/12/03 04:49 PM |
Posts: 12,310 South Carolina | good to hear that you are enjoying your boat! If you have substantial weight on the boat and are trying to lift a hull, have a person or two go to the leeward side to take some weight off the windward hull. It will probably be a wet ride over there though! Remember to either ease the sails or steer more into the wind to reduce power if you're flying too high.
Secondly, if you are reaching to get as much power as possible (wind at 90 degrees to your direction of travel), you should have a good deal of your crew weight at the back of the boat to keep the nose high. You'll be amazed how much effect weight placement has on boat handling and performance. When reaching in heavy air, all catamarans need to have the weight back on the far corner and most have put foot straps aft of the rear beam to make it easier to trapeze back there. You are a bit more vulnerable to capsize when reaching because you can't just turn the boat into the wind to depower. Be ready to ease the sails when overpowered and reaching because steering up or down will only help the boat fly higher!
As far as righting a turtled catamaran - you're right - get that weight on the corner. Rig you're righting line around the opposite hull and hang on to that while getting all your weight (or as much can fit) as far out on the corner of the boat that is farthest downwind - be it bow or stern. It shouldn't take too long to pop back up.
[Re: flounder]
#19354 05/13/03 05:35 PM 05/13/03 05:35 PM |
Posts: 12 Dallas, TX, USA | "A family member has owned one since they came out, so yea I have sailed the boat with two people flying a hull often. It is a wonderful boat in a good blow." wow, i guess i just need to get some confidence up learn to sail while flying a hull.
Ssyba
'01 Hobie Getaway
| | | Re: Getaway "sport"
[Re: Damon Linkous]
#19355 05/13/03 05:37 PM 05/13/03 05:37 PM |
Posts: 12 Dallas, TX, USA | Ssyba, You asked if anyone has seen a Getaway fly a hull? Getaway Flying High Hope that inspires you! thanks for the pic. that is pretty incredible. although, I have wings and the opposite wing tends to drag in the water making it hard to have a stable ride while flying the hull.
Ssyba
'01 Hobie Getaway
| | | Re: Getaway "sport"
[Re: ssyba]
#19357 05/13/03 06:01 PM 05/13/03 06:01 PM |
Posts: 545 Brighton, UK | I followed the link and thought the picture was great, but even better I won a holiday see http://www.patriottravel.us/landingPageGO/lpGO104.htm apparently I was the one millionth customer to visit the site, unfortunatly I couldn't find my phone in time to claim it, also the site tried to install some spyware, luckily it was blocked by my antispyware software. Is thebeachcats.com a reputable web site, do they know that thier sponsors/advertisers are using spyware? | | | Re: Getaway "sport"
[Re: grob]
#19358 05/13/03 06:16 PM 05/13/03 06:16 PM |
Joined: Dec 2002 Posts: 312 Memphis, Tennessee Damon Linkous
Posts: 312 Memphis, Tennessee | I went to the link you indicated and couldn't find any spyware, only a kind of "loud" advertisement. Could you send me information on why you think this ad contains spyware? I can assure you TheBeachcats.com is a reputable site, as far as the advertisers, I'm using Fastclick.com to supply the ads, and they have a clean rep. There is always the possibility that something gets past them though, so let me know and I can block a particular advertisement and complain to Fastclick. If anyone is worried about spyware, (or wonders what it is) I suggest running Ad Aware, available at http://www.lavasoft.de/ Please be "aware" that this and other detectors will report even things you intentionally are running as spyware, you need to read the reports carefully before deleting things from your computer. Thanks, | | | Re: Getaway "sport"
[Re: Damon Linkous]
#19359 05/13/03 06:32 PM 05/13/03 06:32 PM |
Posts: 545 Brighton, UK | Damon, I only know because while viewing the link my antispyware software reported that it had blocked spyware from Gator, and I beleive it was from thebeachcats or possibly from the "loud advertisment" site as these were the only sites I was viewing. If anyone wants to know about Gator see http://www.cexx.org/gator.htmI know this is only a matter of personal opinion but I don't like ads that try to trap the gullible with opening lines "like congratulations you are the one millionth visitor and have won a holiday" then tries to trick people into buying a holiday. That kind of advert is not "loud" its dishonest. I hope you manage to sort it out. All the best Gareth | | |
2,423
guests, and 262
