| Re: Building foam core hulls with Female frame Jig
[Re: dacarls]
#195074 10/31/09 08:31 PM 10/31/09 08:31 PM |
Joined: Apr 2002 Posts: 695 Ft. Pierce, Fl. USA Seeker OP
Posts: 695 Ft. Pierce, Fl. USA | dacarls I don't know about corecell...I will be using divinicell...used to do this stuff for a living and spent a lot of time interacting with the factory reps, the big honchos from Europe. They came over for technical support in regard to a large scale project we were doing using their product. They told us to not use hot wire techniques as the resulting fumes were very toxic. If I had a powerful enough blower system I might give it a chance...it sure would make the material loss a moot point. However I get a headache just thinking back on the one time I did try it in the past...it doesn't cut fast like EPS and the smoke it nauseating...even with a dual cartridge respirator on...and that was just 6 mm H80. Hard at work today putting the backing on the frame Jig...here is some more pictures.... ![[Linked Image]](http://img264.imageshack.us/img264/1571/f14plug026.th.jpg) ![[Linked Image]](http://img267.imageshack.us/img267/496/f14plug028.th.jpg) ![[Linked Image]](http://img42.imageshack.us/img42/8766/f14plug029.th.jpg) | | | Re: Building foam core hulls with Female frame Jig
[Re: Seeker]
#214798 06/28/10 12:15 PM 06/28/10 12:15 PM |
Posts: 695 Ft. Pierce, Fl. USA | (Reposted from the F-14 Forum)...To take advantage of the most recent design trends I did a total revamp of my F14 design. Including: 1) Broadening the hull from 9-1/2" to 14" wide 2) Completely changed the section shape 3) Add slightly more rocker profile Almost finished with rebuilding the jig...here is the Starboard side Jig roughly completed… ![[Linked Image]](http://img8.imageshack.us/img8/6149/f14plug067.th.jpg) Uploaded with ImageShack.us | | | Re: Building foam core hulls with Female frame Jig
[Re: Seeker]
#233398 06/10/11 11:56 AM 06/10/11 11:56 AM |
Joined: Feb 2009 Posts: 678 Palm Beach County TheManShed
Posts: 678 Palm Beach County | I like what you are doing there. I'm trying to figure out how to build the frames / jig for my AMA's. I'd like to take a firsthand look at it since you just up in Fort Pierce about an hour from my house. Could that be arranged?
Mike Shappell www.themanshed.comTMS-20 Builder G-Cat 5.7 - Current Boat NACRA 5.2 - early 70's | | |
11,130
guests, and 412
