| Re: Sail Shape
[Re: Oldbaldie]
#191474 09/21/09 02:13 PM 09/21/09 02:13 PM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | Sounds like you are not sheeting in enough, if the wrinkle runs from the tack upward on the leech.
Sail shape is important with the Wave, and basically because the mast is almost round, in designing sails we have treated the boat as if it had a fixed stick. So, we design the draft farther aft that on a wing-type mast.
I don't know what sail you have, but normal battens seem to work well, and sanding has not been on anyone's format. None of the top sailors do any sanding.
I will say this, on several sails I have they have a lot of fullness and I do very well in light winds. However, when the wind gets over 10 I need to stick extra stiffener battens in the bottom 3. Rick | | | Re: Sail Shape
[Re: IndyWave]
#193007 10/09/09 08:16 AM 10/09/09 08:16 AM |
Posts: 921 Alachua, FL |
Not class legal for racing however...
Why not? <<The downhaul line will be limited in length to 8 feet. There are no restrictions on the amount of purchase, as long as the 8' line is used.>>
Jack Woehrle Hobie Wave #100, Tiger Shark III HCA-NA 5022-1 USSailing 654799E Alachua FL/Put-In-Bay | | | Re: Sail Shape
[Re: IndyWave]
#193016 10/09/09 08:41 AM 10/09/09 08:41 AM |
Posts: 921 Alachua, FL | Exactly. 8 Feet max. I think the factory stock downhaul is 8 foot. Mine came with about 5'. 8 is all you need.
[Re: Mary]
#193092 10/09/09 03:29 PM 10/09/09 03:29 PM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | Yes, downhaul is limited to 8 feet in length, but no diameter is given. Small stuff goes through the tack grommet a couple times without binding, while larger stuff does not. So, you can get more downhaul with small diameter line than larger dia. line. I have encouraged Wave sailmakers to use super large grommets for the tack just for that reason. Most don't listen. Rick | | | Re: Sail Shape
[Re: Mike Fahle]
#193595 10/15/09 11:59 AM 10/15/09 11:59 AM |
Posts: 235 | Charlie,
Try sheeting in tight before putting on the downhaul. This will allow you to get more on the downhaul than you will without the mainsheet tension. Feel free to use a smaller diameter and longer line for the downhaul if that helps you get more tension. That should make a noticable difference. So, Mike. Was this what you did at Duck? At Duck, I had way too much pocket in my stock sail and there were too many problems for me tweak the boat, flatten the sail to my satisfaction, and feel safe in that kind of wind in order to continue. Especially with the jet skis fishing everyone out of the water. I think it was you who said, "We got a gust of 37 mph!" on Saturday that made my jaw drop. I was very disappointed that I missed the opportunity to continue at Duck. It was fun but it was extreme. | | | Re: Sail Shape
[Re: JJ_]
#193630 10/15/09 03:11 PM 10/15/09 03:11 PM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | Best bet is to add additional battens to the sail, starting from the bottom, 2nd and lastly 3rd, depending on the wind strength. On the thrown out race, I had stuffed stiff battens in the bottom three and was quickly pulling away from both Mike and Patrick.., that is, until the forestay broke. Rick | | | Re: Sail Shape
[Re: RickWhite]
#193793 10/17/09 11:52 AM 10/17/09 11:52 AM |
Posts: 235 | Best bet is to add additional battens to the sail, starting from the bottom, 2nd and lastly 3rd, depending on the wind strength. On the thrown out race, I had stuffed stiff battens in the bottom three and was quickly pulling away from both Mike and Patrick.., that is, until the forestay broke. Rick That certainly makes sense. Wish a notice flag had gone up that said, "Stiffen your battens, ye land lubbers, afore ye wander out into the screeching winds." Notice that you have batten sets in the online store: Battens. But you are switching out battens or adding battens...? | | | Re: Sail Shape
[Re: Mike Fahle]
#207818 04/09/10 10:10 AM 04/09/10 10:10 AM |
Posts: 778 Houston | Charlie,
Feel free to use a smaller diameter and longer line for the downhaul if that helps you get more tension. That should make a noticable difference. Thank You This and the other hints in this thread made a big difference. I am trying use an old stock Hobie sail, for the Wed Nights in Houston, until my new sail gets here. For a downhaul I used some old 3.5 mm spec 12 that had been treated with silicone to make it slick. It was almost like having real downhaul. I remember a Laser sailor showing me how to make a cascading system by tying loops in the line. I may have to talk to him. I raked my mast back until I could just barely tension the leach on shore. I found that this not only helped pointing but changing the sheeting angle got rid on some big old wrinkles and only added a small new one. I still need to get rid of some stack height in the blocks. I have some old downhaul hardware that lets you put the blocks in the sail grommet. I will look at it this weekend. I played with the bottom batten and found that an old TheMightyHobie18 batten and a tapered tubular batten marked "extra stiff" from a old Tornado sail to be about right. It paid off. I am still slow compared to the dinghies when the wind is below 10 kts but not as slow as I used to be. I pulled off a 2nd by beating up on a Laser driven by a little girl that looked to about 12 with braces. Don't laugh she was ahead of all the other Lasers and the boats that started 3 mins ahead of us and we were catching the ones that started 6 mins ahead of us. I think it was more fun sailing that race on a Wave than an A-Class. With an A-Class the main rule is overtaking boats stay clear. With a Wave you can interact. | | | Re: Sail Shape
[Re: carlbohannon]
#207835 04/09/10 04:04 PM 04/09/10 04:04 PM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | Hi Carl, Glad to see you are still in the Wave. But, what has happened to your lovely wife? She was really gung ho for a while there.
On the downhaul, class rules allow for 8' of line. I use small dyneema which is quite slippery and can easily get three wraps around the horn, using the middle and the outside of it.
The Lasers used to almost have a macrame thingy for their vang, but finally have legalized real equipment. I guess our class wanted to sort of emulate that. I get plenty of downhaul with the three wraps, but it would be easy enough to throw in a couple of small bowlines for extra purchase. Funny, but with the Laser, they were not allowed to lube the line. So, everyone would apply lots of bullfrog on their exposed skin.., and then accidently mess with the vang afterward.
Raking back is an absolute must, it seems. Also, almost everyone is going with really stiff battens at the bottom (acting more like a boom than a batten). And with the good aftermarket sails, are using pretty stiff battens in the lower sail, softer in the top. If it howls stick in some extra battens in the top for stiffeners.
Against the mono crowd (Force 5, Laser and Sunfish) here we are usually ahead of them most of the time unless it is very light and shifty -- OH that is right, you are in Houston..., silly me. In any kind of wind we leave them in the dust. Gotta get you to come to some of our events around the country.., great competition and great people. Have fun Rick | | | Re: Sail Shape
[Re: carlbohannon]
#207853 04/10/10 01:13 AM 04/10/10 01:13 AM |
Posts: 235 | Extra stiff batten in the lower pocket? Or a second batten in the lower pocket? If you use a second batten, don't you run the risk of damage to the sail?! Because you can't cram two battens into the batten pocket protector?! Plus, who actually sells a stiffer batten? Earlier, Mike said: There is no substitute for regular racing to get good and dial the boat in for various conditions. I guess I will have to get a little more ambitious and start playing around with battens myself if I want to keep up with these guys. Yes, but... Flattening the sail and twist-off and other sail shaping techniques are just good basics. Not something special, but something everyone ought to know how to routinely do. True?
551
guests, and 303
