Prevention of galvanic corrosion #19370
05/06/03 07:22 PM
05/06/03 07:22 PM
Burlington, Vermont USA
K
Kevin Rose Offline OP
K
The fittings on my mast have been mounted with a strip of clear tape between the aluminum mast and the stainless hardware in order to prevent contact between the dissimilar metals. It looks rather like Scotch tape. Does Performance use a special kind of tape that has been designed for such applications? (It's the factory installed hardware I'm referring to.)
Kevin Rose N6.0na #215 Lake Champlain (New England's "west coast") Burlington, Vermont
Re: Prevention of galvanic corrosion [Re: Kevin Rose] #19371
05/07/03 08:59 AM
05/07/03 08:59 AM
Houston
carlbohannon Offline
Houston
I asked the factory some years ago and was told it was "isolation" or "mounting" tape. I made a few more phone calls and determined it was probably mylar electrical tape.
You can buy the mylar tape. It looks like clear packing tape except it is more expensive and it lasts a lot longer. 3M makes a mylar tape. It is hard to figure out which one is mylar. You will need to email 3M. If you know a Tornado sailor ask them. They use mylar tape to fair the ceneterboard gaskets.
You can use outdoor electrical tape. Your local electrical supply company will probably have some. You can paint the fitting with liquid electrical tape or bed it with any adhesive or caulk that is rated as an insulator.
I use mylar or flurglas tape mostly because I have it handy and it is easy to use.
I hope this helps
Re: Prevention of galvanic corrosion [Re: carlbohannon] #19372
05/07/03 10:23 AM
05/07/03 10:23 AM
K
K
Carl,
I dropped a note to the factory, but I can usually count on a quicker, more thorough response from this forum. Thanks!
0 registered members (), 331 guests, and 55 spiders.
