| Re: Stealth tramp reinforcement
[Re: hobiegary]
#194783 10/28/09 10:39 AM 10/28/09 10:39 AM |
Posts: 976 France | screw an aluminum C track on top What about the aluminum extrusion having a flat bottom while the hull is curved? Well, if you are filling the existing groove, nothing prevents flattening the top so the C profile lies flat. Also most C profile are designed to be put on curved masts anyway.... | | | Re: Stealth tramp reinforcement
[Re: carlbohannon]
#194998 10/30/09 12:20 PM 10/30/09 12:20 PM |
Posts: 713 WA, ID, MT | Carl, I agree the the proposed solutions are getting complex, but I think Gary's correct in pointing out that the channel molded into the hull is flexing, and I think that this is what's allowing the bolt rope to escape, not that the bolt rope is shrinking in dia. I have this issue on another boat, and I increased the bolt rope dia, and the channel just opened up more. But I do need to inspect the channel closely to see if I can confirm that the groove is indeed opening under pressure. Thanks for your input!
Dave | | | Re: Stealth tramp reinforcement
[Re: davefarmer]
#195036 10/31/09 03:29 AM 10/31/09 03:29 AM |
Posts: 1,382 Essex, UK | Following Gary's post I thought I'd check on my older boat. Having pulled the tramp off, I used a very bright torch to shine through the slot onto the inside of the track. Having thoroughly inspected both sides, I found a short crack (about 7" long) that had been repaired previously and was now ok - all of the rest of that port track and the entire starboard track were undamaged. I checked the integrity of the repaired crack by trying it with the blade of a penknife and I couldn't even get the tip in (I could have if I forced it, but you get the idea). I'm therefore perfectly content that enlarging the bolt rope was the correct solution and that the crack (repaired by a previous owner) was not contributing to the problem I was experiencing - especially as my tramp tended to pull out of the aft section of the starboard track!
Carl's right - I think you should look at the simpler solutions first................
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: Stealth tramp reinforcement
[Re: Jalani]
#195080 11/01/09 12:08 AM 11/01/09 12:08 AM |
Posts: 713 WA, ID, MT | Ok, I checked out the grooves with good illumination and a larger screwdriver. The stbd hull's groove is cracked nearly three quarters of its length. Gary did indeed make a good effort to open the crack and epoxy it, but it has broken open again. A smaller(shorter) crack is visible in the port hull, which hasn't been repaired. I really don't think I can easily and sufficiently reinforce this groove to the point that it will reliably hold in a bolt rope. When I pry gently with the screwdriver, I can see the cracks open up, as well as noticible flexing of the hulls in the vicinity of the groove. In my opinion, any successful repair of this design would need to occur from the inside, which seems substantially more work. I found a couple of lengths of alum C channel from a SC20 that seem stout enough to stand up to the loads. I'm currently drawn to attaching these to a filled and glassed over groove. So unless someone here talks me into something else, my next questions are: If I fill the groove with West high densitity filler and tape over the groove, would that be solid enough to attach the track with #10 x 1" self tapping screws? (I expect to epoxy the track down as well). Or should I embed nuts in the groove when filling? If so, I'm gonna have to locate them accurately, probably with the track and some bolts. What can I spray/coat the screws with to insure that they'll release from the epoxy? Thanks for all the input guys, my thinking has gone thru a fair evolution since the beginning of this thread. I'm excited to beef this boat up enough to stand up to the abuse I'm sure to give it.
[Re: Rolf_Nilsen]
#195122 11/02/09 05:21 AM 11/02/09 05:21 AM |
Posts: 976 France | I would have got the "magic mushrooms" you linked to earlier and used those with a backing plate epoxied inside the tube. Marstrøm is pretty expensive but there has to be other suppliers. Can't do that, those would be at the wrong angle if screwed to the filed tube. Mushrooms need to be fixed perpendicular to the trampoline plane. | | | Re: Stealth tramp reinforcement
[Re: davefarmer]
#195759 11/10/09 09:23 AM 11/10/09 09:23 AM |
Posts: 431 Netherlands | Would sail slugs parhaps work for you? That's the way my rear lacing is attached to the tramp on my Nacra 5.2. I'd bet they'd only pull out if the whole track ever separated.
[edited for typo]
6,173
guests, and 813
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online7,715 13 minutes ago | | |
