release agent for epoxy #195663
11/08/09 09:40 PM
11/08/09 09:40 PM
WA, ID, MT
davefarmer Offline OP
WA, ID, MT
I'd like to embed some ss nuts in the tramp groove of my F16 Stealth. I need to locate them with screws that will be removed after the epoxy has set. What can I spray/coat the screws with to assure that they'll come out easily? Thanks!
Dave
Re: release agent for epoxy [Re: davefarmer] #195677
11/09/09 06:18 AM
11/09/09 06:18 AM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
Mould release is made for the job
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: release agent for epoxy [Re: JeffS] #195686
11/09/09 07:14 AM
11/09/09 07:14 AM
When heli-coiling new beam bold mounts I have used synthetic grease to ensure the loacting/driving bolts do not stick to the arldite I use to ensure the heli's stay put. Wht do you want to put nuts inside the track? I'd suggest a better bet would be a larger bolt rope on the tramp!
Re: release agent for epoxy [Re: scooby_simon] #195688
11/09/09 08:19 AM
11/09/09 08:19 AM
lesburn1 Offline
lesburn1  Offline
A coat of mold release wax for starters.
Then if they do stick use a torch to heat a screw driver and then use that screwdriver to heat the screw. That will release it and then you can use a good screwdriver to remove the screw. When you are done throw away the driver you use for the heating, as it will most likely have lost it's temper.
lesburn1.blogspot.com
A-Cat USA 49
18Sq 49
Re: release agent for epoxy [Re: scooby_simon] #195690
11/09/09 08:49 AM
11/09/09 08:49 AM
France
pepin Offline
pepin  Offline
France
Originally Posted by scooby_simon
[...]Wht do you want to put nuts inside the track? I'd suggest a better bet would be a larger bolt rope on the tramp!
The why explained.
Re: release agent for epoxy [Re: pepin] #195895
11/10/09 11:23 PM
11/10/09 11:23 PM
WA, ID, MT
WA, ID, MT
You're good Pepin! Yeah, I'm convinced that the groove is seriously compromised. The hulls are flexing in the vicinity of the groove, and I think it will only get worse with time. I want to fill in the groove and glass over it for strength reasons.
Sources for mold release in the US? Thank you gentlemen!
Dave
Re: release agent for epoxy [Re: davefarmer] #195901
11/11/09 12:19 AM
11/11/09 12:19 AM
ncik Offline
ncik  Offline
just spray with silicon spray then let dry for a bit. did it recently for about a 60mm long M8 or M10 thread and it worked. was a lot of friction to pull it out and a bit of heat built up in the thread (hand screw driver used to remove), but it came out. this method is suggested by bladerider in one of their maintenance manuals for creating a carbon thread in the foils.
Re: release agent for epoxy [Re: ncik] #195965
11/11/09 11:40 AM
11/11/09 11:40 AM
WA, ID, MT
WA, ID, MT
Excellent, thanks Gero. I have that stuff on hand, and hope to start the repair this weekend.
Dave
Re: release agent for epoxy [Re: davefarmer] #196008
11/11/09 06:14 PM
11/11/09 06:14 PM
ncik Offline
ncik  Offline
probably best to test it first.
Re: release agent for epoxy [Re: ncik] #196012
11/11/09 07:58 PM
11/11/09 07:58 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
I've used simple light machine oil, WD-40 or mold release for smaller machine screws in epoxy. I suspect PAM cooking spray would also work. Epoxy does not tend to adhere well to smooth metal finishes like stainless unless they are roughened up and throughly de-greased.
Mike.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: release agent for epoxy [Re: Tornado] #196114
11/12/09 11:41 PM
11/12/09 11:41 PM
Palm Beach County
TheManShed Offline
TheManShed  Offline
Palm Beach County
Turtle Wax or paste car wax also works
Mike Shappell
www.themanshed.com
TMS-20 Builder
G-Cat 5.7 - Current Boat
NACRA 5.2 - early 70's
Re: release agent for epoxy [Re: TheManShed] #196160
11/13/09 11:48 AM
11/13/09 11:48 AM
waynemarlow Offline
waynemarlow  Offline
Car wax works great but be careful of the ones with silicon in as the excellent paint job are going to do will look pretty tardy in about 12 months, when it start to flake smile
Re: release agent for epoxy [Re: waynemarlow] #196371
11/15/09 10:08 AM
11/15/09 10:08 AM
Palm Beach County
TheManShed Offline
TheManShed  Offline
Palm Beach County
Yep! Got to sand, prep with silicon / wax remover, and be clean before paint. That should be a step always!
Easy with the wax usually the first few threads then spread it out. I like this method better then say WD40 wax "stays together" where oils penetrate and may be harder to clean up for paint prep.
Good Luck!
Mike Shappell
www.themanshed.com
TMS-20 Builder
Re: release agent for epoxy [Re: TheManShed] #196384
11/15/09 01:18 PM
11/15/09 01:18 PM
WA, ID, MT
WA, ID, MT
I just pulled the track off, after using it to locate the screws. I sprayed them with silicone, worked ok, one snapped off, out of maybe 18. Still 1/2" sticking up, I'll try to heat it carefully and see if it'll break free. I just used zinc plated steel screw for locating the nuts, s.s. screws are definitely stronger. Overall, looks like this will work well. I'll post pics in a while.
Dave
