| Re: port / starboard race rule
[Re: brucat]
#196185 11/13/09 03:31 PM 11/13/09 03:31 PM |
Posts: 6,049 Sebring, Florida. | But did the Starboard tack boat hail the port tack boat? In some instances the starboard tack boat would rather duck the port and hope the port doesn't tack, he might not hail, and choose instead to duck. Unless he hailed "starboard" or after the duck, hailed "Protest", if I were the port boat, I don't think I would consider him fouled at all. Maybe he didn't want to exert his rights and ducked instead so as to keep clear air? Is that considered a "Foul" by the port tack boat?
I know I have often ducked port tack boats because I wanted to continue on, alone. But if I don't want them to tack I either hail them that I will duck or try to duck early enough that they don't tack on me.
Blade F16 #777
[Re: brucat]
#196188 11/13/09 03:44 PM 11/13/09 03:44 PM |
Posts: 3,116 Annapolis, MD | err... yes I was hunting... Its rainy cold and nasty... so this was a fish in a barrel kind of opportunity. as to the rule.... What Mike said!
crac.sailregattas.com
[Re: Timbo]
#196191 11/13/09 04:16 PM 11/13/09 04:16 PM |
Posts: 3,116 Annapolis, MD | Timbo... what part of port tack shall keep clear of starboard do you want to argue with?
No hail of "starboard" is required.... "Wake up and pay attention" amounts to the same thing. You are not asserting your rights with some hail... and you are not declining your rights when you don't say a word.
Starboard is NOT DUCKING PORT.... She is avoiding a collision with PORT.... It's a foul by port. Port put her self in that position and took the risk.. So... pay the piper.
As windy noted... Self policing... means YOU call the foul on yourself.... you don't have to hear protest if you know you fouled him. If there was some doubt... He can help you out by telling you... Protest.... If he says protest and you think you were clear ahead... better have a witness who has the proper angle to disprove Starboard's claim that they altered course to avoid a collision.
The rules are black and white here to make the penalty on Port large enough so that she is conservative in her time and distance judgments.
ps In catamarans... its of dubious value to tack and try to lee bow starboard.... so you would prefer port to tack below you and get shot out the back as opposed to ducking and getting a shift or more pressure on port tack. If they are clear ahead of you... they are winning for the moment.... If they want to tack on you and get your air..... that's what winning gets you. Maybe's cause boats to go boom!
[Re: Mark Schneider]
#196194 11/13/09 04:51 PM 11/13/09 04:51 PM |
Posts: 6,049 Sebring, Florida. | I wasn't there Mark, were you? It's a tough call until you tell me the exact situation, type of boats, wind speed, direction, etc. and he said it was a Distance Race which to me means maybe neither one of them was "close hauled" but instead trying to get to some fixed marker up the shore/river/what have you.
I really don't know why I bother...
Mark you are right, always. What was I thinking?
And Maybe's do not cause boats to go boom, Asshats who don't hail Starboard cause boats to go boom.
Blade F16 #777
[Re: ]
#196216 11/13/09 08:38 PM 11/13/09 08:38 PM |
Posts: 807 Hillsborough, NC USA | ...if you foul someone in a race ... can you do an on the course correction? if yes, what is required? First of all, take a look at the preamble to the rules "Basic Principle - Sportsmanship and the Rules". It says: ... A fundamental principle of sportsmanship is that when competitors break a rule they will promptly take a penalty... Therefore, if you believe you have fouled someone, you should take a penalty, whether they protest or not. If you aren't sure, then it's perfectly ok to see if they protest you. Check rule 61 "Protest Requirements" also. It says: a boat intending to protest shall inform the other boat at the first reasonable opportunity. When her protest concerns an incident in the racing area that she is involved in or sees, she shall hail 'Protest' and conspicuously display a red flag at the first reasonable opportunity for each... Now, there are some exceptions, and the sailing instructions may add additional requirements, but that is the basic notification requirement. Note that the protesting competitor has to say the word "protest". You can't say "you owe me turns", or "you broke a rule", or "you fouled me". You have to say "protest". If your boat is 6 meters or longer, then you must fly a red flag. If you don't do both of these without delay, then your protest is invalid. Now, about exoneration, look at rule 44. Rule 44.1 says: A boat may take a Two-Turns Penalty when she may have broken a rule of Part 2 while racing... The sailing instructions may change the penalty, or offer an alternative penalty, but if they don't then a boat may usually exonerate herself by making two turns as described by rule 44.2: After getting well clear of other boats as soon after the incident as possible, a boat takes a One-Turn or Two-Turns Penalty by promptly making the required number of turns in the same direction, each turn including one tack and one gybe... I hope that helps, Eric US Sailing Certified Judge, Member, Area D Appeals Committee | | | Re: port / starboard race rule
[Re: scooby_simon]
#196217 11/13/09 08:42 PM 11/13/09 08:42 PM |
Posts: 3,116 Annapolis, MD | Depending on your class, they can be picky about actually displaying a protest flag and a hail is not valid, if you ever see a whiffle ball hanging on a dinghy boom, it's got the flag in there! Depends on size of boat. Less than 6m flag is not required (usually). As for hailing protest; that is not required either. If you foul, you should do your turn(s). It's possible you get seen fouling, but out of earshot and so you cannot hear the protest hail. Scooby... I think the culture over here (NA) is to not protest an incident that you see but are not directly involved in. Is this common to issue third party protests among the brits? Does it help the game by getting people to take fewer chances and sail smarter?
[Re: sbflyer]
#196219 11/13/09 08:52 PM 11/13/09 08:52 PM |
Posts: 807 Hillsborough, NC USA | Don't starboard tackers ever break the rules? Yes. It is entirely possible that both (or all) boats involved may break a rule. I prefer not to think of the rules in terms of "rights", but in terms of "obligations". In a typical starboard/port crossing, the port boat (P) is obligated to keep clear (rule 10), If the starboard boat (S) changes course, she is obligated to give P room to keep clear (rule 16.1). S is also obligated not to "hunt" P (rule 16.2). Both boats are obligated to avoid contact if reasonably possible (rule 14). If, for example, P does not keep clear of S, and S does not avoid contact (and there's damage or injury), then both boats may wind up disqualified. Regards, Eric US Sailing Certified Judge Member, Area D Appeals Committee | | | Re: port / starboard race rule
[Re: Timbo]
#196220 11/13/09 09:06 PM 11/13/09 09:06 PM |
Posts: 807 Hillsborough, NC USA | Maybe he didn't want to exert his rights and ducked instead so as to keep clear air? Is that considered a "Foul" by the port tack boat? If the "right-of-way" boat changes course for strategic or tactical reasons, rather than as an "avoiding action" that does not constitute a foul. For example, if S believes that the left side is favored (wind shift, better velocity, etc.), wants to go left, and bears away to prevent P from tacking on her lee-bow, then P does not break rule 10. If P hails "tack or cross", and S waves P across, then P is clean (even if S bears away). I hope that helps, Eric | | | Re: port / starboard race rule
#196222 11/13/09 09:19 PM 11/13/09 09:19 PM |
Posts: 807 Hillsborough, NC USA | <hunting>... a sexy slang term that I would argue does such harm that this term should not be uttered.
It is the most misused and misunderstood term in sailing and many think its part of the rules. A get out of jail free card because..." you were hunting me"
... Its just a mess.... on par with mast abeam. "Hunting", like "barging", is not a term defined in the rules, but one often used to describe a particular situation. In real life, neither hunting nor barging is a "get out of jail free card" for the hunted or barged boat. There are, however, rules that prohibit both hunting (RRS 16.2) and barging (RRS 11 / Section C Preamble). I don't consider either term to be so harmful as to prohibit its use. Regards, Eric | | | Re: port / starboard race rule
#196224 11/13/09 09:32 PM 11/13/09 09:32 PM |
Posts: 807 Hillsborough, NC USA | No hail of "starboard" is required.... "Wake up and pay attention" amounts to the same thing. You are not asserting your rights with some hail... and you are not declining your rights when you don't say a word. Well, yes and no. The rules do not explicitly require the starboard tack boat to hail. If there's contact, however, S may find herself in trouble. Rule 14 requires all boats to avoid contact "if reasonably possible", and Dick Rose recently published an article in which he wrote that hails are a reasonable part of avoiding contact. If S could have avoided contact by hailing, and did not, then she breaks rule 14. So, although the rules are not explicit in this situation, a hail may be implicitly required. Either way, when both boats know one another is aware of the situation, and understands the other's intentions, problems are far less likely to occur. Good communication on the water is almost always helpful. Regards, Eric | | | Re: port / starboard race rule
[Re: Timbo]
#196226 11/13/09 09:52 PM 11/13/09 09:52 PM |
Posts: 887 Crofton, MD | and he said it was a Distance Race which to me means maybe neither one of them was "close hauled" but instead trying to get to some fixed marker up the shore/river/what have you. I'm missing why "close hauled" is impotant hear? | | | Re: port / starboard race rule
[Re: Isotope235]
#196227 11/13/09 10:12 PM 11/13/09 10:12 PM |
Posts: 3,116 Annapolis, MD | RE Eric's acceptance of the term hunting.
No... I see people take 16.2 and say... well, I was keeping clear.... er.... I had not changed course but was going to cross clear ahead... when starboard footed off and hunted me and I was forced to foul him. He did not give me room and opportunity to stay clear.
or... I footed off to clear starboard but they also footed to hunt me... and I fouled starbord because of their actions.
They think that 16..2 means the ROW boat is restricted from sailing puffs, headers and lifts or changing gears from point mode to foot mode going into a cross...People who throw the hunting charge believe that starboard is somehow constrained to simply going straight as the cross approaches. With this interpretation of 16.2, port does not give starboard enough room.
Perry's guidance that a 16.2 violation should not be subtle.... Port needs evidence that port changed course to duck and starboard changed course and changed course again solely to get them.
So I take 16.2 as a limit on Starboard actions... Not something that Port should be thinking about in a cross. Port should either be clear ahead and crossing... or clearly ducking and keeping clear.
What am I missing?
[Re: Isotope235]
#196229 11/13/09 10:37 PM 11/13/09 10:37 PM |
Posts: 3,116 Annapolis, MD | If S could have avoided contact by hailing, and did not, then she breaks rule 14. So, although the rules are not explicit in this situation, a hail may be implicitly required. This is a stretch.... linking a hail that is not required because you are the ROW boat ... to not taking action in avoiding a collision This is a bogus concatenation of your responsibility.... If you could avoid the collision and did not take action... you violate rule 14. period! Injecting this yes and no interpretation is silly and contributes to the confusion that leads to.. well.... he did not hail starboard so that I thought he gave me permission to cross... (see this thread in fact) No one will disagree with you on Either way, when both boats know one another is aware of the situation, and understands the other's intentions, problems are far less likely to occur. However, Communication like hails of "starboard" is frequently a class culture issue. In tornado's... they think you are a hick from the sticks if you are constantly hailing boats on every cross.... they are pros... they know the rules. They tell you to shut up.... (If you don't figure it out on your own.) So...Yes... communication can't be wrong and No communication may not be warranted... Yes and NO guidance on things like class culture ... no problem... Yes and no answers on the rule requirements is misleading.
[Re: Chris9]
#196230 11/13/09 10:40 PM 11/13/09 10:40 PM |
Posts: 3,116 Annapolis, MD | where to begin? Sorry that was to easy. OK... but given our internal troubles on the little bit of water we sail on.... OBVIOUSLY A LOT OF PEOPLE ARE MISSING A LOT OF RULES!.... Sigh...
[Re: scooby_simon]
#196232 11/13/09 11:07 PM 11/13/09 11:07 PM |
Posts: 263 SC | Depending on your class, they can be picky about actually displaying a protest flag and a hail is not valid, if you ever see a whiffle ball hanging on a dinghy boom, it's got the flag in there! Depends on size of boat. Less than 6m flag is not required (usually). As for hailing protest; that is not required either. If you foul, you should do your turn(s). It's possible you get seen fouling, but out of earshot and so you cannot hear the protest hail. Yes, be careful on that. It bit our Tybee 500 team (I was ground crew) in the *** a few years back. Two of the boats (either accidentally or on purpose, not judging) cut inside the last buoy around the Cape. Our team filed a formal protest on the beach because they did not unwind their course to exonerate themselves and they admitted to such. The rule in the RSS specify (61.1.a.2) a boat less than 6 meters (19'8 1/4") in length is not required to display a protest flag. The I20 is actually 20' in length so over the limit by 3.75", so our protest was thrown out on a technicality because our team didn't display a flag (don't know who could have seen it but....) It was frustrating but interesting, everyone was reading the RSS's and running around measuring hulls, a good learning experience. I didn't realize that Ksurfer had posted the rule on page one of this thread.
Always borrow money from a pessimist. He won't expect it back.
2,534
guests, and 340
