| a truly planing cat??? #197623 11/25/09 07:47 PM 11/25/09 07:47 PM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen OP
Posts: 1,037 Central California | I've had the chance to be on the course many times with skiffs over the years. Up to about 15 knots or so, it is quite easy to outpace them up and down the course. But I've noticed that downwind, the skiffs seem to have a faster top end (and sail deeper) when the breeze really get up. The limiting factor for me seems to be the friction on the hulls--my rig is outpacing my hull(s). At times, I've felt the lee hull semi planing; but it still isn't totally planing like a sailboard. I've seen flatter and flatter aft hull sections, but has anyone taken modern cat design in this direction? http://www.youtube.com/watch?v=JbOr46fV4n0&NR=1
| | | Re: a truly planing cat???
[Re: ejpoulsen]
#197648 11/26/09 06:34 AM 11/26/09 06:34 AM |
Posts: 1,383 Kingston SE South Australia | Isn't it just a matter of how much wind? When it gets too windy to sail the 5.7 I take an Arrow out to blast around and that has dead flat hulls with a single centreboard. You can feel when it lets go because it takes off and goes all over the place overreacting to every tiller movement with a 3ft water spout off the front of the centreboard.
#197651 11/26/09 08:42 AM 11/26/09 08:42 AM |
Posts: 5,525 | On the first site, there is a picture of a model or prototype that is intriguing. Do you suppose A cats and F16s could be built in this manner? And still have similar performance. My knees, back and hips don't like to trapeze all that much. The biplane looks like it might be a little more user friendly.  For that matter, it might make a great Tybee boat!
Pete Pollard Blade 702
[Re: pgp]
#197657 11/26/09 10:36 AM 11/26/09 10:36 AM |
Posts: 1,037 Central California | Jake, I've seen that Parlier cat--the hulls look like they're off a seaplane. The guy's a genius; too bad that cat broke up so soon. Pete, Any cat type that flies a hull downwind (F16/18, A-class, etc) would really benefit from a hull that truly breaks free (and I don't mean via pitchpole). I've seen the chines, the trip turbulators, the flattened sterns, etc. But have we seen any of these truly break free so the lee hull is skipping on top of the water like a wake board? It sounds like with enough wind Jeff gets planing on his Arrow--totally flat bottom from front to back: http://www.seabreeze.com.au/News/Sa...nglehold-in-Arrow-cat-class_2251396.aspx
[Re: ejpoulsen]
#197658 11/26/09 10:43 AM 11/26/09 10:43 AM |
Posts: 5,525 | Go back and read the article in Jake's initial citation. The hulls are directly the result of sea plane design and permit speeds in the 250 kph range!
[Re: RickWhite]
#197661 11/26/09 10:54 AM 11/26/09 10:54 AM |
Posts: 5,525 | Any pictures? What are your thoughts on the biplane thingey?
It looks good to me, but I'm totally ignorant of design theory.
[Re: ejpoulsen]
#197674 11/26/09 12:03 PM 11/26/09 12:03 PM |
Posts: 53 Arkansas, USA | Eric- Good to hear from you! Their was a Lindahl designed "A" cat in the '80's that was almost literally an "upside down hull" design w/ intention to plane and there was a production planing cat- I believe it was a 16 footer even- not very popular- sold here in the US. I of course can't remember the name right now. I also recall I think it was Wouter posted about a new cat in Europe that had planing steps in the hull and was supposed to plane, I believe he saw it at one of the European boat shows. Here's an interesting link from the designer of the cat video you posted- http://www.mckeewildthings.com/Wet%20and%20Wild%20Fluid%20Dynamics.htmYou could always build your own too- seehttp://www.maelabs.ucsd.edu/mae_guides/presentations/examples/Catamaran.pdf Or get an inflatable that one that claims it easily enters the "planing state"-http://www.maelabs.ucsd.edu/mae_guides/presentations/examples/Catamaran.pdf Even the venerable AquaCat is claimed to be "planing"- "Featuring wide, flat bottom hulls with turned up bows and a small keel skeg, the pontoon design is unequaled in weight carrying capacity and planing speed." !! Kirt
Kirt Taipan 4.9 USA 159, Flyer USA 185 Will sail for food...
[Re: ejpoulsen]
#197689 11/26/09 04:25 PM 11/26/09 04:25 PM |
Posts: 571 Hamburg | The limiting factor for me seems to be the friction on the hulls hm, if it is really blowing hard, I think nose diving is the limit. Have a cat with a low aspect ratio rig and lots of sail area (low on the mast) and you are on the same level as a skiff. Cheers, Klaus | | | Re: a truly planing cat???
[Re: Smiths_Cat]
#197692 11/26/09 05:16 PM 11/26/09 05:16 PM |
Posts: 757 japan | a year or 2 ago, warbird, on this site was working on an 18' tigercat to make it a planning cat
he felt that as it had the required flat rear he could make it work. the tigercat being a 2 man boat was over powered and threatening to trip over it's bows so he was shortening the mast and mainsail to get the power lower
he's gone quiet of late but a search would find his posts on the matter
2,079
guests, and 265
