What does a Scotsman wear under his wetsuit? #19977
05/27/03 02:57 PM
05/27/03 02:57 PM
Durham, North Carolina
jwrobie Offline OP
jwrobie  Offline OP
Over the weekend I spent 16 hours in a wetsuit. My baggy swimsuit seems like the wrong thing to wear under a wetsuit - it is not designed to absorb sweat, rumples up under the wetsuit, and is generally uncomfortable.
So what is the best thing to wear under a wetsuit? And what is the best way to keep it clean?
Jonathan
Re: What does a Scotsman wear under his wetsuit? [Re: jwrobie] #19978
05/27/03 03:22 PM
05/27/03 03:22 PM
I wear lightweight jogging shorts so I have something to strip down to if I need to - they're pretty revealing and not terribly sexy when they're wet though (well...that depends on what you look like I guess)
Re: What does a Scotsman wear under his wetsuit? [Re: jwrobie] #19979
05/27/03 03:41 PM
05/27/03 03:41 PM
Bradenton, FL
Sycho15 Offline
Sycho15  Offline
Bradenton, FL
biking shorts or neoprene shorts
Re: What does a Scotsman wear under his wetsuit? [Re: jwrobie] #19980
05/27/03 04:12 PM
05/27/03 04:12 PM
jwrobie Offline OP
jwrobie  Offline OP
Let me clarify: what is the best way to keep the wetsuit clean, especially when it gets sweaty inside.
Jonathan
Re: What does a Scotsman wear under his wetsuit? [Re: jwrobie] #19981
05/27/03 04:19 PM
05/27/03 04:19 PM
jcasto1 Offline
jcasto1  Offline
Best way I find to clean a wetsuit is to put it in bathtub, slosh it around a lot, and even walk around on it. Drain water & repeat. Then hang up on (sturdy) hangar. After draining/drying overnight, turn it inside out & hang out to dry again.
There is actually a product sold for washing wetsuits. I have not tried it, but it is probably just a mild detergent.
Jim Casto
NACRA 5.5 & NACRA 5.7
Austin TX
Lake Travis
Re: What does a Scotsman wear under his wetsuit? [Re: Jake] #19982
05/27/03 04:21 PM
05/27/03 04:21 PM
jwrobie Offline OP
jwrobie  Offline OP
I haven't tried uploading pictures to the forum, and this doesn't seem like the occasion to try it for the first time ;->
Jonathan
Re: What does a Scotsman wear under his wetsuit? [Re: Sycho15] #19983
05/27/03 04:31 PM
05/27/03 04:31 PM
jwrobie Offline OP
jwrobie  Offline OP
Would baggy and absorbant boxer shorts do? I have some made from nice thick cotton.
Jonathan
Re: What does a Scotsman wear under his wetsuit? [Re: jwrobie] #19984
05/27/03 04:58 PM
05/27/03 04:58 PM
I turn mine inside out and wash them occasionally in the washing machine on delicate with no detergent. I hang them inside out afterwards to dry. I haven't experienced a smelly wet suit yet.
Re: What does a Scotsman wear under his wetsuit? [Re: Jake] #19985
05/27/03 05:40 PM
05/27/03 05:40 PM
Will_R Offline
Will_R  Offline
I use old mtn bikeing shorts w/the pad cut out OR better yet, spandex shorts that you can pick up from Walmart. They are the best thing I have found.
Will
Bathing suits underneath give you campers ass! [Re: Will_R] #19986
05/27/03 09:37 PM
05/27/03 09:37 PM
Columbia South Carolina, USA
dave mosley Offline
dave mosley  Offline
Lycra bottoms and whatever those "skins" are made from are the way to go. No Campers butt, and no chafe
Dave Mosley
www.seacats.org
Re: What does a Scotsman wear under his wetsuit? [Re: jwrobie] #19987
05/27/03 09:50 PM
05/27/03 09:50 PM
I know its not the right thing to do, and I know I'll probably get rubbing rashes from it, but I always go commando under my wetsuit, either that or just boxers :P
Re: What does a Scotsman wear under his wetsuit? [Re: MauganN20] #19988
05/27/03 11:24 PM
05/27/03 11:24 PM
sonicassassin Offline
I dunno what a Scotsman would wear, but I just wear my boxers.
As for cleaning and washing, I just keep my wetty wet for a couple of days. It doesnt do them any harm, then I just chuck it on the clothesline till its dry and stuff it in my wetty-bag, same with my booties.
My wetty is a 5x3mm with some type of Titanium weave? - Its super warm though.
Re: What does a Scotsman wear under his wetsuit? [Re: MauganN20] #19989
05/28/03 09:08 AM
05/28/03 09:08 AM
Burlington, Vermont USA
K
Kevin Rose Offline
Kevin Rose  Offline
K
I know its not the right thing to do, and I know I'll probably get rubbing rashes from it, but I always go commando under my wetsuit . . .
Same here.
You're supposed to wear something underneath?
Kevin Rose N6.0na #215 Lake Champlain (New England's "west coast") Burlington, Vermont
Re: What does a Scotsman wear under his wetsuit? [Re: Kevin Rose] #19990
05/28/03 10:33 AM
05/28/03 10:33 AM
I think some of us must have a natural buffer that prevents rashes
Re: What does a Scotsman wear under his wetsuit? [Re: MauganN20] #19991
05/28/03 11:11 AM
05/28/03 11:11 AM
K
Kevin Rose Offline
Kevin Rose  Offline
K
That's right. That's what I'll call my spare 20 lbs . . . a "natural buffer".
Re: What does a Scotsman wear under his wetsuit? [Re: Kevin Rose] #19992
05/28/03 12:44 PM
05/28/03 12:44 PM
oh thank goodness - I thought you guys were talking about being hairy.
Re: What does a Scotsman wear under his wetsuit? [Re: MauganN20] #19993
05/28/03 02:35 PM
05/28/03 02:35 PM
Neb
flounder Offline
flounder  Offline
Neb
I highly recommend O'Neill rash guards of all types underneth wetsuits. They are very strechy, soft and the seams are on the outside so they do not dig into the skin.
I wear rash guard tops all year around, even in 100+ degree heat. BluePlanet, O'Neill and Mysterioso's are SPF rated between 30-50. Get'em wet and they stay cool, plus you avoid cancer!
Re: What does a Scotsman wear under his wetsuit? [Re: flounder] #19994
05/28/03 03:44 PM
05/28/03 03:44 PM
Central Coast of California
SLO_Boozer Offline
SLO_Boozer  Offline
Careful in the summer sun with rashguards, they make for some funky tan lines.
The SLO_Boozer H 16 - "First Wish"
Re: What does a Scotsman wear under his wetsuit? [Re: SLO_Boozer] #19995
05/29/03 11:59 AM
05/29/03 11:59 AM
jwrobie Offline OP
jwrobie  Offline OP
So here are the suggestions I have received on this thread or in private email:
1. "Nothing comes between me and my wetsuit"
2. Skimpy, Speed-o style swimsuits
3. Lycra shorts, which may cut down on sweat
4. Rash guards
5. Boxer shorts
6. Old bicycling shorts - presumably the lycra ones?
In private email, someone suggested that (1) is the most common, but (3) is becoming much more popular.
Is that about right?
Jonathan
Re: What does a Scotsman wear under his wetsuit? [Re: jwrobie] #19996
05/29/03 05:57 PM
05/29/03 05:57 PM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
You're right on track.
Surfers invented the wetsuit. No self-respecting surfer wears anything under their wetsuit except maybe an upper body rash guard. I've been using/wearing wetsuits for 20 years and would never dream of wearing anything underneath.
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
1 registered members (Damon Linkous), 3,086 guests, and 241 spiders.
