Page 3 of 3 1 2 3
Re: Composite Tube Construction [Re: ] #200988
01/22/10 03:33 AM
01/22/10 03:33 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
It's just a PIPE there is no JOIN! wink
Originally Posted by Scarecrow
The pipe is the mould. With what I understand of your current system, when you set the up the infusion you would probably end up with resin running up the join in the pipe instead of through the fibres. This would result in a lot of dry areas. Having said that it would be relatively easy to set up your bag so the resin would go in one gap, through the fibres and then out the other gab. I might do an experiment at some stage.
There are spray adhesives that are used to hold fibres in location while setting up.
Re: Composite Tube Construction [Re: TEAMVMG] #200991
01/22/10 04:19 AM
01/22/10 04:19 AM
It is a pipe inside a pipe with two membranes. One with vacuum and one you inflate later on to increase pressure. I guess Scarecrow is still hung up on the split pipe method described earlier grin
Now, how would the ends of the pipe look, or is there a membrane able to hold 2-4 bar?
Re: Composite Tube Construction [Re: Rolf_Nilsen] #201065
01/22/10 10:07 PM
01/22/10 10:07 PM
Scarecrow
Scarecrow
Sorry, hadn't payed enough attention, I now see you're cutting the pipe after making the part.
Re: Composite Tube Construction [Re: Rolf_Nilsen] #201157
01/24/10 08:45 AM
01/24/10 08:45 AM
I like the idea of marrying several of these concepts. Use a split pipe and low pressure to form a thin carbon sleeve inside the pipe. Once cured, laminate and inflate again from inside the carbon sleeve you made in the split pipe and let it bond to the carbon sleeve (it becomes the outer part of the tube).
Page 3 of 3 1 2 3
0 registered members (), 288 guests, and 56 spiders.
