| Re: Rudder toe in
[Re: DanWard]
#20282 06/05/03 11:17 PM 06/05/03 11:17 PM |
Posts: 364 | With toe-in and a bit of weather helm, the windward rudder runs straight while the leeward one carries load. This was helpful on both of my Nacras (5.O and 5.5u) with their large rudders, but parallel is working better on the Prindle 19. sail fast
Andrew Tatton
Nacra 20 "Wiggle Stick" #266
Nacra 18 Square #12
| | | Re: Rudder toe in
[Re: DanWard]
#20283 06/06/03 08:34 AM 06/06/03 08:34 AM |
Posts: 117 Northern VA | On a 16 with the asymmetric hull, the toe-in allows the leeward rudder to "smooth" the flow coming off the curve of the inside hull. When the windward hull is flying, the windward rudder has little effect. On symmetric board boats, I believe that a very small amount of toe-in "preloads" the rudders so that they don't flop around as much. Given that almost all rudder systems have some slack; two perfectly parallel rudders would tend to "hunt" slightly, whereas a very slight angle of attack would tend to keep them from moving. I've been told that most new cars run very little toe-in (definitely less than 10 years ago) for less tire scrub, less drag, better mileage. However, IMO, they are a little "twitchier" on the road. From that standpoint, maybe a little rudder toe-in adds some "feel" even if does add drag. 1/8" total toe-in is only 1/16" per rudder; over a 12" chord works out that each rudder is at a 2.4 degree angle of attack. I'll leave it to someone else to figure out the extra drag caused by that angle. Most boats seem to have a little weather helm, anyway; even perfectly straight rudders might see that angle or more upwind. Chris | | | Re: Rudder toe in
[Re: john p]
#20288 06/10/03 09:54 PM 06/10/03 09:54 PM | Anonymous
| Anonymous
Unregistered | Hi John, You have it right! Boats sail faster to windward with the rudders loaded, carrying some of the side force equal and opposite to the sail side force. The windward rudder in this situation which in moving into and out of the water vertically as the windward hull moves up and down will stall if it has the same angle of attack as the leeward rudder which is totally submerged. Reduce the angle of attack of the windward rudder a couple of degrees, rudder toe-in, and the windward rudder does not stall as it moves in and out of the water vertically and as the boat travels ahead. Good Sailing, Bill | | |
564
guests, and 41
