| Re: Defective Sails
[Re: MauganN20]
#20331 06/12/03 07:10 AM 06/12/03 07:10 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | It seems as though whether a squaretop would be an advantage or not would depend on a combination of crew weight and the conditions you mostly sail in.
My understanding of the squaretop is that it gives you a little more sail area and power in light air but depowers the boat in heavy air, because the top of the sail blows off (sort of like a Chinese junk). So if you are a heavy guy who sails in heavy air most of the time, I wouldn't think you would want a squaretop -- you would want to be able to take advantage of all the power you can get get. If you are a heavy guy who sails in light air most of the time, maybe the squaretop would be helpful. A lightweight guy, on the other hand, might really benefit from a squaretop in heavy air because of the way it depowers the sail.
Am I wrong? | | | Re: Defective Sails
[Re: Mary]
#20332 06/12/03 08:30 AM 06/12/03 08:30 AM |
Posts: 12,310 South Carolina | you can tune the "blow off" of the top of the square head to your weight by using a combination of batten strength/tension, and mainsheet tension.
Jake Kohl | | | Re: Defective Sails
[Re: h17racer]
#20335 06/13/03 11:32 AM 06/13/03 11:32 AM |
Joined: Apr 2002 Posts: 195 White Bear Lake, MN h17racer
Posts: 195 White Bear Lake, MN | Via one of the sailmakers websites...these guys say it a lot better than I can.
Sail Shapes
It's rare in sail design when an innovation can add power in light air AND reduce power in heavy air.
Physically, these Mainsails feature an additional batten at the head placed at 45 degrees to the luff. This batten supports the 'Square Top' leech profile. Rather than the standard aluminum headboard, the square top is over 30% wider with a conventional stainless ring which replaces the headboard.
The additional sail area creates more power and efficiency. Some power is added simply due to the increased size. Efficiency is greatly enhanced as the 'Square Top' profile increases the effective aspect ratio which raises the lift coefficient for better upwind performance. Additionally, the added sail area is behind the mast turbulence zone which lengthens the effective luff for enhanced tell tale flow in the upper 30% of the Mainsail. The net result is more speed on all points of sail in light to medium air.
Depowering in heavy air is the second half of the 'Square Top's' advantage. All of the additional sail area is added behind the load path from head to clew. When excessive wind pressure is added, this portion of the sail behind the load path line 'hinges' open automatically which depowers the upper portion of the Mainsail. That's right, automatically. Even if the mainsheet isn't eased, the top of the sail depowers. In many 'marginal' conditions, reefing the main can be delayed as the sail conforms to the puffs automatically.
When reaching downwind with the Asymmetric Spinnaker, the 'Square Top' Mainsail is again a major improvement. By easing the mainsheet, the 'Square Top' automatically 'twists' open at the top 1/3 of the leech. This aligns the Mainsail with the apparent wind angle which is progressively further aft in the upper portions. Your first observation will be the steady leeward tell tale flow, even the ones at the top. In this condition, a standard 'pin head' main twists open in the middle where it has the most roach, leaving the top stalled and under-powered.
Squaretop / Pinhead
Why the new 'Square Top' Mainsail profile? Why do classes with a choice go 'Square Topped? It seems that everyone including A Class cats, to the latest rage in Europe, the Formula 18's, the Nacra Express, Super Cat 22's, and Farrier Trimarans are all winning with Square Top Mains.
Let's start with the obvious. Square Top Mains look bigger than Pin Heads. Sail area can generally be expanded by 7% with a Square Top profile. Just remember that, "Sail Area is King".
But wait, there must be something more than just area. The A Class and the Formula 18 Classes chose the square top without any additional sail area bonus. Yes, the advantages are in fact numerous and spread around the whole race course.
Upwind the Square Top essentially "stretches your mast length" by increasing you effective aspect ratio. This translates into enhanced lift to drag ratios which means more forward power, less hull flying, and higher pointing. In windy conditions a more dynamic advantage for the Square Top is it's ability to lower the center of effort. At first this sounds ludicrous. Is appears that all the added sail area is up high and should raise the center of effort. Actually excessive wind loads push on the square top aligning it with the wind which effectively makes it invisible to the wind. It's as if the Square Top automatically reefs the to portion when overpowered.
A Pin Head unfortunately depowers where the roach is largest; in the middle rather than up high. the result in high winds is the Pin Head must ease the traveler to reduce excessive hull flying which immediately hurts pointing ability.
In summary Upwind: The Square Top can point higher in light air due to the increased Aspect Ratio. In heavy air pointing is enhanced due to the lower center of effort which enables the traveler to stay centered. In all winds you can sail with more sail area while pointing higher.
Off the wind the Jib (and Asymmetric spinnaker) backwinds the lower portion of any Mainsail. This makes the bottom the Main 'see' apparent winds from well forward while the top of any main 'sees' the apparent wind much further aft. Due to the fact that the wind speed is greater at the top of your mast than the bottom the apparent wind is further skewed vertically along the Mainsail. It's no wonder that it's so hard to get the leeward tell tales to flow on the top of Pin Head Mainsails.
Square Top mains solve this dilemma by twisting at the top thanks to the excessive sail area in the head. By adjusting the Mainsheet, twist is easily manipulated. When combined with proper vertical camber distribution (your sail makers job), this makes the entire luff match the 'twisted' wind directions vertically. The bottom line? All your leeward Mainsail tell tales along the luff flow continuously.
For those of you that consume numbers, a sail with attached flow (leeward tell tales are flowing) has 180% the power of a stalled sail (leeward tell tales drooping or spinning). So, the top portion of a Square Top Main that enjoys attached flow is producing 80% more power than an equal sized Pin Head with stalled flow. So a Square Top is really bigger than life.
It's rare in sail design where an innovation can enhance performance in all wind speeds and wind directions. Why didn't we discover the Square Top long ago?? | | | Re: Defective Sails
[Re: Mary]
#20341 06/13/03 04:41 PM 06/13/03 04:41 PM |
Joined: Jun 2001 Posts: 733 Home is where the harness is..... Will_R
Posts: 733 Home is where the harness is..... | Sorry...I was refering to the "junk boat"
The lateen rig with proper sail shape, tension and support I think would do pretty well...except for the weight and windage of the upper most spar.
Will
| | | Re: Defective Sails
[Re: Mary]
#20342 06/13/03 04:42 PM 06/13/03 04:42 PM |
Posts: 5,590 Naples, FL | Actually, that boat pictured has a sailplan that really is more effective than it seems. I remember reading up on the old America's Cup (or the 100 Guiney cup, I think it was called), and there's some way those things work that the top twists off or flattens as the sail is sheeted in higher breezes. I can't remember if they tightened the halyard or not, but some pictures clearly showed the top portion bleeding off wind in the gusts... Even with that old Egyptian Cotton sail material, it almost behaved like a modern mylar square-top...
1 registered members (basket.case),
490
guests, and 20
