anti-sieze #203936
02/19/10 05:47 PM
02/19/10 05:47 PM
PTP Offline OP
PTP  Offline OP
I think this has been covered but a quick search didn't give me the answer I was looking for.
tapping some SS screws into aluminum (mast base blocks on the 31). I really don't anticipate having to undo these anytime remotely soon (previous blocks were bent and I had to basically torque the heads off the previous screws, grind down, re-tap) but thought I might try to at least preserve the options. 4 #10-31 screws ought to keep things solid too. I saw some people mention physical isolation but that isn't practicle in this situation.
spray stuff corosion inhibitor?? how long would this reasonably last? the previous blocks were there for 10 yrs so I figure it might be that long again. I don't think it is reasonable to think that spray on stuff would last that long so I might just forgeeeetttaboutit.
Re: anti-sieze [Re: PTP] #203946
02/19/10 07:34 PM
02/19/10 07:34 PM
catman Offline
catman  Offline
Use this and you will be able to remove the screws 10 years later.
Google TEF GEL
Re: anti-sieze [Re: catman] #203954
02/19/10 10:26 PM
02/19/10 10:26 PM
PTP Offline OP
PTP  Offline OP
thanks... I think I will try that.
Re: anti-sieze [Re: PTP] #203972
02/20/10 09:14 AM
02/20/10 09:14 AM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
Tef gel is the best. I think APS and Layline carry it.
Isak Dinesen
E. B. White
Re: anti-sieze [Re: PTP] #203978
02/20/10 11:49 AM
02/20/10 11:49 AM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
Two things to consider. If you want to do screws, and what you're screwing into may not be too thick, consider these:
Rivnuts
For corrosion protection, we've also had good luck using:
Lanocote
Re: anti-sieze [Re: Keith] #203980
02/20/10 12:13 PM
02/20/10 12:13 PM
Newport, RI
wildtsail Offline
wildtsail  Offline
Newport, RI
+1 for Tef Gel.. expensive but worth every penny but you shouldn't need all that much anyways.
0 registered members (), 474 guests, and 30 spiders.
