Page 3 of 5 1 2 3 4 5
Re: AC tech [Re: macca] #203960
02/20/10 05:34 AM
02/20/10 05:34 AM
Live in Germany, House in UK, ...
DanTnz Offline
DanTnz  Offline
Hobie seem to be the only manufacturer that prices it's parts list online Europe (in english!) the cost for a Tiger front crossbeam is over £1000, that's probably the complete assembly but then even the tiller crossbar is £200.
edit: Hobie UK Parts
I have seen N6.0 beams being advertised second hand at about £200 each from when I was looking for some for mine. But then we are comparing new for new here.
Re: AC tech [Re: DanTnz] #203961
02/20/10 05:39 AM
02/20/10 05:39 AM
DanTnz Offline
DanTnz  Offline
Another one by way of comparison only (i.e. not up to spec for an F16) Dart 16 main beam is £225.
Dart 16 Parts
Re: AC tech [Re: macca] #203963
02/20/10 06:13 AM
02/20/10 06:13 AM
Originally Posted by macca
I wonder why Rolf didn't just order a set of beams from a current manufacturer....
Because they were more expensive than he could make them out of Carbon! Simples.
Re: AC tech [Re: scooby_simon] #203964
02/20/10 06:37 AM
02/20/10 06:37 AM
Hamburg
Smiths_Cat Offline
Smiths_Cat  Offline
Hamburg
I once asked for a custom shaped alu extrusion (rudder foil). The simple answer from a well known rigging supplier was: "You wan't pay it. Make it form glass or carbon fibres."
It works fine for standard shapes like tubes. We got 4m spin pole from 40mm alu for 150€ or so.
By the way, if you are close to a company working with CFRP, you may ask for cutting scrap (or however it is called in english) or expired prepregs. Sometimes you get it for free.
Cheers,
Klaus
Re: AC tech [Re: scooby_simon] #203965
02/20/10 06:56 AM
02/20/10 06:56 AM
Australia
macca Offline
macca  Offline
Australia
A beam extrusion, even from one of the big manufacturers (at full retail) will still be a lot less than someone could build one in carbon.
I understand the challenge in building your own beams in carbon, but to try and justify that its cheaper than an alloy beam is just not reasonable.
________________________
http://aus300.blogspot.com
Re: AC tech [Re: macca] #203967
02/20/10 08:46 AM
02/20/10 08:46 AM
waynemarlow Offline
waynemarlow  Offline
For reference on beams try
http://www.aluminiumwarehouse.co.uk/index.html gobsmackingly cheap tube and it is delivered the next day.
and for carbon tubes try http://carbonfibretubes.co.uk/ some of the big boat spinnaker poles are just the right size for us and its surprising the low cost on smaller tubes for tiller sticks etc, talk to them they always seem to have a bit laying around from a production run somewhere.
Why didn't I use carbon beams on Bitsa? Carbon is a great product for tensile strength, it is terribly weak and much inferior to aluminim if hit with something sharp or given the usual sailing abuse. To protect it you must use a reinforcing glass or kevlar outer layer which brings the weight right up to that of similar Aluminium tube. Aluminium is a great product, it just doesn't have the kudos of carbon fibre.
Re: AC tech [Re: waynemarlow] #203971
02/20/10 09:13 AM
02/20/10 09:13 AM
Hamburg
Smiths_Cat Offline
Smiths_Cat  Offline
Hamburg
it is as with girls. We looks always for the bling bling, never for character.
But back to the original question: Are canted riggs class legal?
Re: AC tech [Re: Smiths_Cat] #203977
02/20/10 11:47 AM
02/20/10 11:47 AM
If you want to start a race with the rig canted permanently on one tack then - yes! laugh
Class rules state:
1.7.1 It is not permitted to adjust the following items while racing: the rake of the mast, the tension of the standing rigging, the angle or length of the spreaders or the position and height of the gennaker boom.
1.7.2 It is permitted to adjust the diamond wire tension while racing or to adjust the items named under 1.7.1 between the races.
Re: AC tech [Re: Jalani] #203985
02/20/10 12:24 PM
02/20/10 12:24 PM
Australia
macca Offline
macca  Offline
Australia
With that rule, its easy to change the rig canting. You just have to think about it a little...
Re: AC tech [Re: macca] #203988
02/20/10 02:36 PM
02/20/10 02:36 PM
Western Australia
Stewart Offline
Stewart  Offline
Western Australia
you forget about the spirit of the rules..
Re: AC tech [Re: Stewart] #204017
02/21/10 02:10 AM
02/21/10 02:10 AM
Australia
macca Offline
macca  Offline
Australia
Ahh, yes the "spirit" clause.... the get out of jail free card..
Re: AC tech [Re: macca] #204019
02/21/10 04:33 AM
02/21/10 04:33 AM
Western Australia
Stewart Offline
Stewart  Offline
Western Australia
suck it up mate..
Re: AC tech [Re: Jalani] #204029
02/21/10 11:52 AM
02/21/10 11:52 AM
France
pepin Offline
pepin  Offline
France
Class rules state:
For once I agree with Macca (I feel dirty smile. I don't see anything there preventing canting. You can't change the amount of tension, but nothing prevents you moving the mast side to side without changing the tension.
And sometimes those rules are weird: Pulling the jib halyard pulls the mast forward. Does this mean I can't adjust the jib tension on the water as it changes the mast rake? What about when I'm solo without a jib up? The halyard on my boat is still there, can I tension it?
Re: AC tech [Re: pepin] #204031
02/21/10 02:50 PM
02/21/10 02:50 PM
Netherlands
geert Offline
geert  Offline
Netherlands
What am I missing? don't see a problem in this rule.
If you move the mast top by manipulating the stays or whatever, you ARE raking the mast in a direction. And that is not allowed.
And putting the mast foot on a rail won't help either.
Am still with John Here.
Geert
Re: AC tech [Re: geert] #204032
02/21/10 03:35 PM
02/21/10 03:35 PM
Australia
macca Offline
macca  Offline
Australia
Nope, thats why we call fore and aft changes "rake" and sideways changes are "canting"
and by having a closed loop system you can change the mast cant without altering mast rake or rig tension.
Re: AC tech [Re: DanTnz] #204037
02/21/10 05:39 PM
02/21/10 05:39 PM
Port Noarlunga, SA, Australia
Darryn Offline
Darryn  Offline
Dart 16 Parts
Mosquito main beam or rear beam $45AUD or 27GBP.
cheers,
Darryn
Mozzy
1782
Re: AC tech [Re: Darryn] #204038
02/21/10 05:45 PM
02/21/10 05:45 PM
Brisveagas
Aido Offline
Aido  Offline
Brisveagas
Arrow cat aluminium mast section is $70au. I like to see you buy the carbon cloth for double that price.
Does seem that canting rigs would be ok under the rules. You could even use a canting system to help right the boat. Light crews would not need a righting pole or bag.
Aido
Viper 288
Re: AC tech [Re: macca] #204041
02/21/10 07:01 PM
02/21/10 07:01 PM
Darryn Offline
Darryn  Offline
If the forestay remains the same length and one side stay is lengthened with the other shortened wont that reduce the mast rake slightly?
Darryn
Re: AC tech [Re: Darryn] #204045
02/21/10 07:28 PM
02/21/10 07:28 PM
ncik Offline
ncik  Offline
I believe delivery costs for a full aluminium extrusion vs a roll of carbon cloth distorts the price for some ppl in certain out-of-the-way locations to the point that homebuilding in carbon becomes the cheapest option. That is the argument being put forward. Ignoring this aspect will certainly put aluminium extrusions ahead of carbon in price, but it isn't always that simple.
My personal experience was trying to buy a replacement mosquito mast a few years ago. If I lived near the major fleet it was a cheap exercise to just drop by the class stores and drive away with it for something like $300. I could not get one of these shipped to Brisbane, issues with length and fragility. So instead I had to search for alternatives locally and found a windrush mast supplier (which turns out to be very similar, it not the same), but the cost was near $700. At this price, it was nearly worthwhile building my own carbon mast, with easy availability of materials and my own labour. Maybe I didn't look hard enough for a viable transportation option.
But back to the topic. Where can I get some of that shark skin film?
Re: AC tech [Re: Darryn] #204046
02/21/10 07:34 PM
02/21/10 07:34 PM
ncik Offline
ncik  Offline
Darryn
yep, if the forestay to bridle connection is above the mast base relative to the platform.
if they are at same height then rake will not change. the canting rotation occurs around a line from mast base to bridle (imagine a triangle being rotated about one of it's sides)
this is if you measure rake from mast top to rear beam on centreline.
0 registered members (), 20,217 guests, and 543 spiders.
Most Online22,490
Yesterday at 08:14 AM
