| Re: In-Water Boat Stand
[Re: jmhoying]
#20565 06/09/03 02:02 PM 06/09/03 02:02 PM |
Posts: 12 Minnesota | Thanks Jack - that's a great design. I wish I lived closer to Texas - Snag | | | Re: In-Water Boat Stand
[Re: Snag]
#20566 06/09/03 03:12 PM 06/09/03 03:12 PM |
Posts: 25 W. MICHIGAN | This may be a dumb question, but is there any danger of bottom deformation where the hull rests on the rollers?
I've always been against a boat on anything but a bunk type trailer. or am i just being obsessive/compulsive?
You can't drink all day if you don't start in the morning !
[Re: Mary]
#20568 06/09/03 03:36 PM 06/09/03 03:36 PM |
Joined: Aug 2002 Posts: 215 Durham, North Carolina jwrobie
Posts: 215 Durham, North Carolina | You really need cradles to distribute the weight. Does this apply to normal trailers as well - is my boat at risk if it spends most of its life sitting on the rollers of a trailer? Jonathan | | | Re: In-Water Boat Stand
[Re: jwrobie]
#20569 06/09/03 03:44 PM 06/09/03 03:44 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Well, you have a Prindle 16; right? It is probably not as much of a problem for your boat and for Hobie 16's and G-Cats, etc., as it is for the boats with more-round hulls. But age of the boat can be a factor, too.
I have seen rollers basically go right up through the hulls of boats that sit on them for a while. Scary. | | | Re: In-Water Boat Stand
[Re: DAVEY]
#20570 06/09/03 04:50 PM 06/09/03 04:50 PM |
Posts: 12 Minnesota | This may be a dumb question, but is there any danger of bottom deformation where the hull rests on the rollers?
I've always been against a boat on anything but a bunk type trailer. or am i just being obsessive/compulsive? That is an interesting point- thanks Davey Snag | | | Re: In-Water Boat Stand
[Re: Al Schuster]
#20574 06/23/03 08:05 AM 06/23/03 08:05 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Al, That doesn't look like the ones I saw at Wabamun and Mameo. They were not next to docks -- just out there offshore all by themselves, and there was enough superstructure so that they were easily visible even when there wasn't a boat on them. Otherwise, I would think they could be a navigational hazard.
Also, does your boat slide on and off the float either foreward or backward, rather than sideways? If so, with it alongside a dock that way, don't you have to keep the area clear for at least a boat length at one end in order to get it on and off?
At Sandusky Sailing Club in Ohio, the Thistle fleet had floating storage platforms attached to a main dock, but they were set up so the boat could be slid off and on perpendicular to the main dock, so a lot more boats could be accommodated. | | |
20,780
guests, and 1,475
