Sliding slope with the Viper design ! #206265
03/21/10 07:02 AM
03/21/10 07:02 AM
Wouter Offline OP
Wouter  Offline OP
The 2Bsailing twitter account is very interesting : http://twitter.com/2Bsailing
2Bsailing has just twittered that :
"The Viper trapeze lines have been upgraded from wire to Dyneema and will come as standard on Vipers from now on."
oohhh, the use of new high tech lightweight materials on the Viper !
That is a sliding slope ! (joke, wink )
Note that neither the F18 class rules nor the Taipan class rules allow that.
But there is more interesting stuff.
2Bsailing will be present at the Carnac EUROCAT event this year. Mr. Bundock on the C2 F18 and Ms. Brouwer on a Viper F16.
All good news,
Re: Sliding slope with the Viper design ! [Re: Wouter] #206270
03/21/10 09:13 AM
03/21/10 09:13 AM
Wire trap lines are such a pain in the rear.
Re: Sliding slope with the Viper design ! [Re: Karl_Brogger] #206271
03/21/10 09:51 AM
03/21/10 09:51 AM
What about windage and longevity?
Re: Sliding slope with the Viper design ! [Re: Karl_Brogger] #206272
03/21/10 09:53 AM
03/21/10 09:53 AM
pgp Offline
pgp  Offline
What's the difference?
Pete Pollard
Blade 702
Re: Sliding slope with the Viper design ! [Re: pgp] #206273
03/21/10 10:22 AM
03/21/10 10:22 AM
I did this to my blade five years ago...
Re: Sliding slope with the Viper design ! [Re: Timbo] #206274
03/21/10 10:23 AM
03/21/10 10:23 AM
I've been using 1/8" Robline, and its actually a bit thinner than that, more like 3/32". I bought some Amsteel that was supposed to be 1/8" and its really thick. Too thick to get through the trap handle without modification once spliced. You could use 1/16", but I'd keep an eye on them for wear. I had the same set on the FXone for 3 years, the only reason I replaced them was that I wanted to move them to a shackle and had to cut them off.
They're easy to make yourself. I thought splicing was a black art, turns out its super simple. They also don't kink, which drives me bonkers with wire. I tie mine off to the base of the mast with a bungee on the FXone, then just use ball ties to keep them from flying around. I wouldn't do that with wire as I don't want to scratch up my mast. Assuming your handles and thimbles are in good shape, you can re-use them when making new lines as well. If you make your own wire trap lines I guess you could do the same, bit I have no swaging tools.
I do want to try out rope for the shrouds as well. I currently strip the shrouds/forestay off the mast when trailering.
Re: Sliding slope with the Viper design ! [Re: Robi] #206275
03/21/10 10:41 AM
03/21/10 10:41 AM
pgp Offline
pgp  Offline
Good! You can splice me up a set! laugh
Pete Pollard
Blade 702
Re: Sliding slope with the Viper design ! [Re: pgp] #206276
03/21/10 10:54 AM
03/21/10 10:54 AM
You get the stuff, I can do that. Doesn't take long at all.
Robbie will show you how at the clinic if you ask.
Re: Sliding slope with the Viper design ! [Re: Wouter] #206277
03/21/10 11:04 AM
03/21/10 11:04 AM
Western Australia
Stewart Offline
Stewart  Offline
Western Australia
It is unwise to use a header like that Wouter.
Re: Sliding slope with the Viper design ! [Re: Stewart] #206283
03/21/10 03:34 PM
03/21/10 03:34 PM
Wouter Offline OP
Wouter  Offline OP
Just a bit of an "attention grabber"
Nothing serious.
Re: Sliding slope with the Viper design ! [Re: Wouter] #206291
03/21/10 05:57 PM
03/21/10 05:57 PM
Hobart, Tasmania, Oz.
Dazz Offline
Dazz  Offline
I love it when your wrong Wouter!
d. The trapeze lines may be rope or wire and shall have a minimum breaking strain of 320kg. Wire shall be a minimum of 2.0mm dia. and of 1x19 construction. Rope shall be a minimum of 2.5mm dia.
http://www.taipan.asn.au/taipan%20rules%20april%202009.doc
cool
C2 AUS 222 by Goodall design
"Darph Bobo"
Re: Sliding slope with the Viper design ! [Re: Dazz] #206327
03/22/10 11:50 AM
03/22/10 11:50 AM
Wouter Offline OP
Wouter  Offline OP
Hah !
So when did you guys hold the vote on that as I have the Taipan Class rules of several years ago and these still state that the trap-lines must be at least 2 mm wire.
Good to see the Taipan rules "updated" in this respect though.
Karl, I've been using dyneema trap lines ever since 1998 and haven't see one fail on me yet. Don't ever want wire traplines ever again.
For anybody who is interested I didn't splice my loops but just stitched them by hand using polyester thread (sailmaker). Works well.
Re: Sliding slope with the Viper design ! [Re: Wouter] #206341
03/22/10 02:06 PM
03/22/10 02:06 PM
Why stich when splicing takes seconds?
Re: Sliding slope with the Viper design ! [Re: Wouter] #206343
03/22/10 02:21 PM
03/22/10 02:21 PM
France
pepin Offline
pepin  Offline
France
I have to ask: why?
Re: Sliding slope with the Viper design ! [Re: scooby_simon] #206344
03/22/10 02:28 PM
03/22/10 02:28 PM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
I suppose I should buy some tools and practice this art.
USA 777
Re: Sliding slope with the Viper design ! [Re: tback] #206347
03/22/10 02:38 PM
03/22/10 02:38 PM
don't need to buy tools. Use innards of a bic pen and practice on some 7/64 amsteel (which is perfect for trap lines). Go to samsonrope.com and look at their splicing instructions. Try it and you will see that paying postage to send the line to someone else so they can do it is just plain silly.
I have been tossing around making my own shrouds for my 31 (principles are all the same) but am a wee bit nervous smile
Re: Sliding slope with the Viper design ! [Re: tback] #206349
03/22/10 02:40 PM
03/22/10 02:40 PM
France
pepin Offline
pepin  Offline
France
You don't need no tools really. You can do everything with a thin piece of wire folded in two. A small splicing needle helps sometimes but even the smallest one (4) is usually too big to splice 2.5 or 3mm diameter rope.
Re: Sliding slope with the Viper design ! [Re: scooby_simon] #206362
03/22/10 03:37 PM
03/22/10 03:37 PM
Wouter Offline OP
Wouter  Offline OP
I still use the orginal Dyneema cordage (launched back in the late 1990's). The kind with a tough very finely braid outer core and an inner core of very loosely braided dyneema fibres. Not the D12 or whatever line with a nice braid.
Simply put the kind of line I use (very tough, UV/abbrasion resistant and inexpensive) is of the kind that simply can not be spliced. Was a good choice; I had line left over from 1998 when I first tried it on my Prindle 18 and the current lines have survived since 2004. Although my boat did stay in storage last season. Otherwise boat lives on the beach 6 months per year in sand, sun and salt.
In short, this type of line has proven itself and I'm not switching !
Re: Sliding slope with the Viper design ! [Re: PTP] #206363
03/22/10 03:44 PM
03/22/10 03:44 PM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
any special recommendations for the thimble? Stainless, ceramic, etc.
USA 777
Re: Sliding slope with the Viper design ! [Re: tback] #206369
03/22/10 04:35 PM
03/22/10 04:35 PM
pgp Offline
pgp  Offline
It is a dark art, join a local coven.
Pete Pollard
Blade 702
0 registered members (), 15,986 guests, and 760 spiders.
Most Online22,490
Yesterday at 08:14 AM
