| Re: boomless H18
[Re: av8or]
#20698 06/10/03 07:23 AM 06/10/03 07:23 AM |
Joined: Jun 2001 Posts: 90 Québec, Canada CharlesLeblanc
Posts: 90 Québec, Canada | How about a used Nacra sail? I am pretty sure that the Nacra 5.0 main would fit and you could still rig your standard sail to get class legal. You would only have to get a hook on your mainsheet pulley
Charles Leblanc
Nacra 5.2 #26
| | | Re: boomless H18
[Re: CharlesLeblanc]
#20699 06/10/03 08:31 AM 06/10/03 08:31 AM |
Posts: 12,310 South Carolina | you would have to add a new upper mainsheet pulley (triple) too since the TheMightyHobie18 has three pulleys mounted to individual tangs on the boom. I agree with Charles - the used sail sounds like a good idea.
Jake Kohl | | | Re: boomless H18
[Re: av8or]
#20702 06/19/03 03:31 AM 06/19/03 03:31 AM |
Posts: 208 | Howdy, Now that I think about it, you may be able to get away without rigging anything for mast control. It is the compression load on the boom that puts a torque on the mast. As long as you don't run the rig too loose, the tension in the shrouds may be sufficient to keep the mast from overrotating. Give it a go, but if you dismast  from the mast being at an odd angle, I'm not responsible. David Ho TheMightyHobie18 1067 | | |
21,527
guests, and 653
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online23,979 Yesterday at 04:54 AM | | | |
