Re: Sailing my 1st boat yesterday - n5.5u [Re: Cookie Monster] #20749
06/12/03 06:32 PM
06/12/03 06:32 PM
where did you find your leaks?
Re: Sailing my 1st boat yesterday - n5.5u [Re: Jake] #20750
06/12/03 06:41 PM
06/12/03 06:41 PM
Pensacola, Florida / Katy, Tex...
Cookie Monster Offline
I found the leaks on the from fittings where the bridle (foil) attahces. Makes sense. Everytime you bury a bow at speed. there is pressure that just forces the water in. There was another under the lip inside the daggerboard well. Same thing. Easy fix.
Don
Don Cook ARC22 #2226 ADRENALIN
Re: Sailing my 1st boat yesterday - n5.5u [Re: Cookie Monster] #20751
06/12/03 11:36 PM
06/12/03 11:36 PM
Burlington, Vermont USA
K
Kevin Rose Offline
Kevin Rose  Offline
K
Don
Using a similar method for pressurizing the hull, I found leaks around the rivets that hold the 4-way jib track to the hull.
I also pressurize my mast (through the holes that the rotator mounts through) and check for leaks each spring.
Kevin Rose N6.0na #215 Lake Champlain (New England's "west coast") Burlington, Vermont
Re: Sailing my 1st boat yesterday - n5.5u [Re: Kevin Rose] #20752
06/13/03 07:06 AM
06/13/03 07:06 AM
the first place my mast leaked was that rotator connection.
Re: Sailing my 1st boat yesterday - n5.5u [Re: Jake] #20753
06/15/03 04:59 AM
06/15/03 04:59 AM
Austin, TX
Aggie97 Offline OP
Aggie97  Offline OP
Austin, TX
Speaking of Mast rotators, the guy (not carl) who sold me the boat said not to worry about it, I would not need to use it until I got more experienced. Is this true? Should it be rigged at all to prevent any type of over-rotation?
Also, I noticed in the newer Nacra owners manual it says to take the mast step pin out after the mast was stepped - is this advisable?
-Brandon
N5.5u #424
Austin, TX
-Brandon N5.5u #424 Austin, TX
Re: Sailing my 1st boat yesterday - n5.5u [Re: Aggie97] #20754
06/15/03 10:05 AM
06/15/03 10:05 AM
Yes and Yes
Make sure you don't over-rotate and yes take the pin out.
I have firsthand experience of what happens when your mast comes tumbling down and you left the pin in the base.
Not pretty.
Re: Sailing my 1st boat yesterday - n5.5u [Re: Aggie97] #20755
06/15/03 02:19 PM
06/15/03 02:19 PM
Andrew Offline
Andrew  Offline
The 5.5u like many boomless Nacras uses a forced rotation system. Rotation takes care of itself most of the time; you would force rotation to maximize sail area downwind in a racing situation, and sometimes upwind in very light air. For cruising, I agree...don't mess with it. As for pulling the pin: Do pull it, but carry it on the boat. Some of the most experienced Nacra sailors I know keep it attached to an eyestrap rivetted to the main beam near the mast step.
good luck w/a great boat
Re: Sailing my 1st boat yesterday - n5.5u [Re: Andrew] #20756
06/15/03 06:48 PM
06/15/03 06:48 PM
Austin, TX
Aggie97 Offline OP
Aggie97  Offline OP
Austin, TX
Thanks folks, the pin will come out next time!
0 registered members (), 354 guests, and 44 spiders.
