| GPS Mounting #207906 04/10/10 09:48 PM 04/10/10 09:48 PM |
Joined: Mar 2009 Posts: 932 Solomon's Island, MD samc99us OP
Posts: 932 Solomon's Island, MD | All,
How are people SECURELY mounting their Garming GPSMAP series units (72 or 76) to their cats? I am looking for a solution that will stand up to a week of Tybee, no matter the complexity.
Scorpion F18
| | | Re: GPS Mounting
[Re: samc99us]
#207919 04/11/10 07:55 AM 04/11/10 07:55 AM |
Posts: 1,459 Annapolis,MD | Mike is right, depending on how you're using your GPS. For the most part I found that while driving, looking at the GPS just made me drive bad. Let the crew handle looking at the GPS. We had tried strapping them to our legs into our harness leg straps. Worked for crew, not for me. Put it in a dry bag, hook the strap to your vest, either put it in a pocket or just drop it down inside the front of your vest.
Last year we mounted two Velocitek Speedpucks to the boom, one on each side. We used those for compass/heading or speed. They're big enough to see out on the wire, and for most of the sailing that's about all you need. I ended up velcro strapping my Garmin to the boom next to it, and set it to the big arrow screen and let it navigate through the waypoints put in. That display was big enough to see at a glance, gave me just enough to see where we were. If there was more I needed from the GPS I bugged Alex for it. | | | Re: GPS Mounting
[Re: samc99us]
#207937 04/11/10 02:55 PM 04/11/10 02:55 PM |
Posts: 1,203 uk | in the front pocket of the crew's PDF, then the helm can read it. The crew has to spin it around after the tack!
| | | Re: GPS Mounting
[Re: ThunderMuffin]
#207940 04/11/10 05:30 PM 04/11/10 05:30 PM |
Posts: 932 Solomon's Island, MD | Thanks for all the advice guys, and saving me machine shop time trying to build a custom bracket.
I may buy two more Foretrex's to mount on the boom, but that seems a little unnecessary if I have one on my wrist.
I scored a deal on some AquaPacks (5 for $20, they usually cost $20 a piece) that are specifically designed for VHF radios, but also fit the GPSMap.
Scorpion F18
| | | Re: GPS Mounting
[Re: samc99us]
#207942 04/11/10 06:38 PM 04/11/10 06:38 PM |
Posts: 1,459 Annapolis,MD | Thanks for all the advice guys, and saving me machine shop time trying to build a custom bracket.
If you use something like this you have the option of velcro strapping it in many places (body and boat). Aquapac pro | | | Re: GPS Mounting
[Re: samc99us]
#207950 04/11/10 08:34 PM 04/11/10 08:34 PM |
Posts: 606 League City, TX | I may buy two more Foretrex's to mount on the boom, but that seems a little unnecessary if I have one on my wrist.
Unless they changed the design the foretrex is vulnerable to bending and popping out the pins that secure the wrist strap if it slips down to your wrist and you put your hand down on the boat in a manouver. Mounting on the boom with the arrow display and waypoints programmed works well. If the arrow is pointing up you are headed to the next waypoint. We use a tack tick on the pole so you can hold a bearing while keeping your head facing forward. We rarely use the map 76 now. They stay tucked in our PFDs all day. | | | Re: GPS Mounting
[Re: flumpmaster]
#207954 04/11/10 09:00 PM 04/11/10 09:00 PM |
Posts: 1,304 Gulf Coast relocated from Cali... | I agree with Chris on that one. We use a Tack Tick mounted on the front crossbeam and occasionaly look at the Garmin Etrex Legend tucked away in the life jacket just to see how far away the next beer is. A water proof bag is recommended even for waterproof GPS's. We trashed 3 GPS's in one day during the GT one year because of the intense spray hitting them.
Lee
| | | Re: GPS Mounting
[Re: TeamChums]
#207960 04/11/10 09:18 PM 04/11/10 09:18 PM |
Posts: 932 Solomon's Island, MD | I wish I had a tack tick, but the cost places it out of reach for this years race. I understand the need for waterproof bags, but here's my opinion: IPX7 guarantees waterproof. If it fails for this reason, send it back to the manufacturer. IMO, if they have real customer support, they should take the unit back, warranty or not, and replace it.
Do the Foretrex's typically fail if properly sealed and the strap sealed to the back of the unit (i.e, redundancy if the pin fails)? $45 is a bit much for a wrist mounted Aquapac, considering my Foretrex was $70 shipped.
Scorpion F18
| | | Re: GPS Mounting
[Re: samc99us]
#207971 04/11/10 10:06 PM 04/11/10 10:06 PM |
Posts: 12,310 South Carolina | ...IPX7 guarantees waterproof. If it fails for this reason, send it back to the manufacturer. IMO, if they have real customer support, they should take the unit back, warranty or not, and replace it... IPX7 is a calculated waterproofing rating where the device can withstand being submerged 1 meter in water. If you want to depend on that unit to pinpoint the finish line later in the day when you need it, use the dry bag. However, unlike the Garmin Legend GPS, I have had good waterproof success with the Foretrex GPS units (the ones with sealed rechargeable batteries - 201?) using two additional techniques to keep the pins from popping. 1) I put some Wind Shear adhesive between the gps and the band to give it some more adhesion. 2) I put a spare wrist strap on my wrist between the gps wrist strap and my hand. The second wrist strap keeps the gps from sliding too far over my hand. I pop the pins when I put my hand down on the trampoline and flex it back. The second strap keeps the GPS high enough that the back of my hand can't get to it.
Jake Kohl | | | Re: GPS Mounting
[Re: ThunderMuffin]
#207981 04/11/10 10:39 PM 04/11/10 10:39 PM |
Posts: 3,224 Roanoke Island ,N.C. | I've killed more waterproof gps' in drybags than out. The condensation from the heating and cooling makes it like a sauna in the bags I had. bad for the unit and fogged the plastic to make reading it tough. Man, that aquaseal Idea is great, musta been some smart sombitch that came up with that.
| | | Re: GPS Mounting
[Re: Team_Cat_Fever]
#207994 04/12/10 06:42 AM 04/12/10 06:42 AM |
Posts: 12,310 South Carolina | I've killed more waterproof gps' in drybags than out. The condensation from the heating and cooling makes it like a sauna in the bags I had. bad for the unit and fogged the plastic to make reading it tough. Man, that aquaseal Idea is great, musta been some smart sombitch that came up with that. ' Did I not give you credit for that? Ooops.
[Re: samc99us]
#207995 04/12/10 07:31 AM 04/12/10 07:31 AM |
Posts: 1,304 Gulf Coast relocated from Cali... | here's my opinion: IPX7 guarantees waterproof. If it fails for this reason, send it back to the manufacturer. IMO, if they have real customer support, they should take the unit back, warranty or not, and replace it. You are partially right in assuming that but the warranty won't be worth a soggy power bar if the unit goes out on you halfway to Fernandina and it's getting dark. Garmin has been good about warranty stuff. It's just that you can't get it taken care of till after the race.
Lee
| | | Re: GPS Mounting
[Re: davefarmer]
#208017 04/12/10 10:46 AM 04/12/10 10:46 AM |
Posts: 1,152 tampa, fl | I lost a foretrex off my wrist on the Jupiter to Cocoa leg last year. While pulling a broken rudder off the transom, the whole unit velcro strap and all went away. As a far as dry bags go, the only way I could keep anything in a drybag dry was first to seal it in a ziplock bag, the seal the ziplock back in another ziplock bag, and then put it in the dry bag.
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | | Re: GPS Mounting
[Re: ksurfer2]
#208020 04/12/10 11:06 AM 04/12/10 11:06 AM | andrewscott
| andrewscott
Unregistered | there is a new dry bag out now called the dry case that has a removable suction pump. i would GUESS that if you pump the air out... its less likely to have lots of condensation inside? http://drycase.com/ | | | Re: GPS Mounting
[Re: brucat]
#208022 04/12/10 11:16 AM 04/12/10 11:16 AM | andrewscott
| andrewscott
Unregistered | and all the flavor would be sealed in! | | |
402
guests, and 35
