| Re: safe sailing
[Re: PTP]
#208201 04/13/10 02:16 PM 04/13/10 02:16 PM |
Posts: 12,310 South Carolina | how about a REALLY REALLY offset mark! That's would then be "B mark".
Jake Kohl | | | Re: safe sailing
[Re: Smiths_Cat]
#208205 04/13/10 02:35 PM 04/13/10 02:35 PM |
Posts: 3,906 Clermont, FL, USA | The answer is: back to triangle courses. Or any non up-down course. It is also more fun. No, and no it's not.
| | | Re: safe sailing
[Re: Smiths_Cat]
#208209 04/13/10 03:06 PM 04/13/10 03:06 PM |
Posts: 1,203 uk | The answer is: back to triangle courses. Or any non up-down course. It is also more fun. you didn't watch race 2 of the Americas cup then?
| | | Re: safe sailing
[Re: brucat]
#208217 04/13/10 04:21 PM 04/13/10 04:21 PM |
Posts: 807 Hillsborough, NC USA | I respectfully disagree that it is possible to change RRS 11 with the SIs. RRS 86.1(b) states the specific rules that cannot be changed by SIs, and that refers to 86.1(a) which includes all Part 2 rules. And, RRS 11 is in Part 2. This is entirely correct. I was about to say the same thing until I came across this post. I'm not going to quote further, but I agree with everything else Mike said as well. If you really, really want to change the basic right-of-way rules, you could claim you are testing proposed rule changes under RRS 86.3, but then US SAILING limits you to local races unless you get their prior written permission for each event (and other restrictions apply). Regards, Eric US SAILING Certified Judge, Member Area D Appeals Committee | | | Re: safe sailing
[Re: ThunderMuffin]
#208254 04/13/10 09:30 PM 04/13/10 09:30 PM |
Posts: 6,049 Sebring, Florida. | I thought he was talking about any spinnaker boats, not just F16's?
The "avoid collision at all costs" should cover it though.
Blade F16 #777
| | | Re: safe sailing
[Re: Timbo]
#208255 04/13/10 09:53 PM 04/13/10 09:53 PM |
Joined: Jan 2008 Posts: 3,655 Portland, Maine ThunderMuffin
Posts: 3,655 Portland, Maine | that comment was in regards to: I'll bring this matter up with the F16 class, those of you interested can PM me and I'll keep you in the loop. this. | | | Re: safe sailing
[Re: ThunderMuffin]
#208261 04/13/10 11:24 PM 04/13/10 11:24 PM |
Posts: 3,969 | One of the main reasons that the weather (or offset) mark is a dangerous place with spinnaker boats is that the crews are so busy hoisting the kite and adjusting things, they may be more likely to take their eyes off the road. While this won't fix all the problems, one major help here is to have a separate (longer) weather mark (and offset) for the spinnaker boats. Won't help much in a 50-boat spinnaker fleet, but will help a ton in mixed fleets. There are other issues that can happen elsewhere on the course that cannot be easily addressed with rule changes. The primary one is spinnaker boats on the edge of control when it's blowing like stink. They have to bear off (a lot sometimes), which can be unexpected for boats going upwind. Anyway, I'm tired but my point is that I emphasize with this issue, and didn't want to sound preachy in my prior post. But, as others have mentioned, the worst thing on a course (for all of us) is any boat that is sailing around, knowing that they can't see. At that point, snuff the spinnaker, or buy a boat that you can actually control.  Mike | | | Re: safe sailing
[Re: mbounds]
#208287 04/14/10 07:36 AM 04/14/10 07:36 AM |
Joined: Mar 2003 Posts: 334 Thunder Bay ON CAN mmadge
Posts: 334 Thunder Bay ON CAN | What Pete is looking for is something like what they use in iceboating, where the windward boat has the right of way when going off the wind (freedom to bear away in a puff).
It is possible to change Rule 11 in the SIs, although I've never seen the language they use for iceboating.
I think it opens up a whole new can of worms - that doesn't need opening. I've seen (and been in) a few close calls, but usually it's between a boat going upwind and a boat going downwind.
This would not prevent port / starboard situations from occurring between upwind / downwind boats, which is where most of the danger comes from. The other thing Ice Boats have experimented with is having Darling marks on the course.Prevents boats from rounding weather mark and gybing right away onto starboard.Also prevents boats from coming in right on the port tack layline,or coming in hot on the starboard layline downwind. | | | Re: safe sailing
[Re: mmadge]
#208291 04/14/10 07:58 AM 04/14/10 07:58 AM |
Posts: 1,382 Essex, UK | That's what an offset mark is - and we already have them......
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: safe sailing
[Re: Jalani]
#208300 04/14/10 09:16 AM 04/14/10 09:16 AM |
Posts: 334 Thunder Bay ON CAN | That's what an offset mark is - and we already have them...... No, Darling marks are not just offset marks.The weather Darling mark is placed down wind and to the right (looking upwind) of the weather mark.The leeward darling is placed upwind and to the left of the leeward mark.You are not allowed to sail between the mark(called turning bouy) and darling mark. Keep in mind Ice boats are going 40-70 M.P.H.,when you have a collision you are losing more then just gelcoat.
| | | Re: safe sailing
[Re: mmadge]
#208309 04/14/10 10:11 AM 04/14/10 10:11 AM |
Posts: 12,310 South Carolina | so the darling marks are basically offset marks but on the approach to the mark - not on the departure side?
[Re: PTP]
#208319 04/14/10 10:42 AM 04/14/10 10:42 AM | andrewscott
| andrewscott
Unregistered | yeah, I know... This sport isn't completely 100% safe and never will be. As much as anyone messes with the windward mark- with offsets, "pre" offsets before the mark there is still the rest of the course. Driving at spring fever required a lot of situational awareness. It only takes one head in the boat moment dealing with a fouled jib sheet/downhaul/rotator to lose that awareness. I still have those moments of "crap, I just gybed and I am not sure I really checked my 6 o'clock." anyway... we all gotta trust each other and maintain as much situational awareness as possible. as a guy who races only a few times a year (and have only skippered 1 time)... it might be beneficial to have a "newbee skippers meeting" pre or post the regular skippers meetings at events to go over some rules/situations to be esp on the look out for. I admit i know few only a few rules, and much of what was said here is over my head... | | |
3,137
guests, and 249
