How is mast step mounted on 18HT? Using Nacra F17 mast. #209088
04/21/10 04:01 PM
04/21/10 04:01 PM
Lake Murray SC
FasterDamnit Offline OP
Lake Murray SC
I need to come up with a ball and rod to be able to mount a Nacra F17 mast on an 18HT. I know the Nacra used a single rod from dolphin striker to ball with a compression sleeve in the crossbar. Looks like the 18HT us two separate rods. Please advise how the 18HT ball and rod are supposed to be mounted.
Thanks,
Jim.
edit- The Bimare Javelin II.
E-Scow
24' ULDB
Re: How is mast step mounted on 18HT? Using Nacra F17 mast. [Re: FasterDamnit] #209205
04/22/10 12:12 PM
04/22/10 12:12 PM
from my recollection, as you said, the HT mast ball is not a continuous threaded rod- but there is a spacer I believe between the inside top of the beam and the bottom. This makes it an absolute PITA to replace the little nipple on the front beam the mast usually sits on- which was bent on the 2 HTs that I worked on. I am not sure how to mate a nacra style ball-accepting mast base onto the HT's nipple- it wouldn't work. Guess the only options would be to either replace the mast base with an HT base or somehow mount a ball onto the mast base of the beam. I think figuring out the ball would work better since I doubt the mast base would be compatible without a fair amount of modification.
I would get a SS threaded rod and re-create a nacra style mount all the way to the dolphin striker with nuts and all.
hope this helps... but is unlikely to!
Re: How is mast step mounted on 18HT? Using Nacra F17 mast. [Re: PTP] #209275
04/22/10 04:23 PM
04/22/10 04:23 PM
Lake Murray SC
Lake Murray SC
Thanks. You are probably right. Need to get back down to the yard the boat is in and look at it a bit more closely.
E-Scow
24' ULDB
Re: How is mast step mounted on 18HT? Using Nacra F17 mast. [Re: FasterDamnit] #209291
04/22/10 07:17 PM
04/22/10 07:17 PM
Atlanta
GeoffS Offline
GeoffS  Offline
Atlanta
Just curious. Is your F17 mast one of the old carbon masts (a cut down Nacra 20 mast) or one of the new aluminum wing masts?
Re: How is mast step mounted on 18HT? Using Nacra F17 mast. [Re: GeoffS] #209317
04/22/10 11:09 PM
04/22/10 11:09 PM
Lake Murray SC
Lake Murray SC
Carbon. Spliced together from two broken ones.
E-Scow
24' ULDB
0 registered members (), 19,871 guests, and 589 spiders.
16 hours ago
