| material #209346 04/23/10 08:37 AM 04/23/10 08:37 AM |
Posts: 5,525 | A question for you engineer types. Plywood, the high quality marine grade, has always been a very good material for boat building. Would carbon fiber lends itself to a similar material?
Just asking.
Pete Pollard Blade 702
| | | Re: material
[Re: pgp]
#209366 04/23/10 10:37 AM 04/23/10 10:37 AM |
Posts: 1,203 uk | Does not compute....................
| | | Re: material
[Re: Nimrod]
#209367 04/23/10 10:39 AM 04/23/10 10:39 AM |
Posts: 5,525 | Good quality marine plywood is increasingly difficult to find and increasingly expensive. It's still wood, it still rots.
I would most prefer to find a carbon product and use that in place of plywood. So, I'm looking for carbon sheets, approx. 4' x 8' in some sort of laminate configuration. Carbon/foam sandwich? I'd think 1/4" thickness would be good.
| | | Re: material
[Re: pgp]
#209368 04/23/10 10:43 AM 04/23/10 10:43 AM |
Posts: 3,224 Roanoke Island ,N.C. | Google is your friend. I found this in about 6 seconds. http://www.dragonplate.com/ To compare "expensive" plywood/okoume w/ carbon fiber is a stretch. The cost difference would be huge, but you would definitely end up with a better product. hey Paul , I liked your tri build blog. , good looking boat.
| | | Re: material
[Re: carlbohannon]
#209373 04/23/10 11:01 AM 04/23/10 11:01 AM |
Posts: 5,525 | Thanks guys. For my purposes I think the answer is no...or at least not yet.
| | | Re: material
[Re: pgp]
#209387 04/23/10 01:22 PM 04/23/10 01:22 PM |
Posts: 115 | If you need a flat panel, look for surplus aircraft floor and joinerwork pannels. These are available in 3/8, 1/2 and other thicknesses. They are hpneycomb with s-glass or carbon faces. You can find sometimes on EBay. There was a truck load for auction a few years ago and I lost the auction. Was bought by Advanced Vehicle Technology. Still selling it through their store front at www.avt.com I believe. You cannot bend a flat panel appreciably. On the other hand nothing is as stiff and light including anything you can make at home. | | | Re: material
[Re: Kevin Cook]
#209388 04/23/10 01:48 PM 04/23/10 01:48 PM |
Posts: 805 Gainesville, FL 32607 USA | There is a French epoxy foam that is weighed carefully, mixed then goes off while making bubbles hopefully filling your mold or space between CF panels perfectly, before hardening. Paul Bieker uses this in CF hydrofoils that he builds for Bora Gulari and a few others: they are only about $1000 each. This foam is available in France, UK and Oz and is unavailable in the USA.
| | | Re: material
[Re: dacarls]
#209451 04/24/10 05:18 PM 04/24/10 05:18 PM |
Posts: 1,307 Asuncion, Paraguay | There is a French epoxy foam... ...available in France, UK and Oz and is unavailable in the USA.
I also heard about epoxy foam. Found it in Brazil and would have used to fill my foils, but gave up due to the ridiculous price.
Luiz
| | | Re: material
[Re: Luiz]
#209459 04/24/10 09:25 PM 04/24/10 09:25 PM |
Posts: 266 UK | http://www.gurit.com/page.asp?section=00010001002200580001§ionTitle=SP+Product+Focus%3A+Ampreg+F230+Foaming+Epoxy SP distributor: http://www.compositesone.com/Cheshirecatman note: top url should be all one string. It didn't copy properly into the message panel.
| | | Re: material
[Re: pgp]
#209484 04/25/10 02:31 PM 04/25/10 02:31 PM |
Posts: 893 | Pete, there are alot of build methods out there using flat panels but they all have a common problem, that of stitching and taping them together, it simply doesn't give nice fair lines and those boats I have seen photo's of using this type of method always seem a bit, well, not quite right, sort of the ugly ducklings of boat design. Derek Kelsall uses a method which sort of is a half way house, the KSS and it seems to be a fast boat building method http://www.kelsall.com/methods.html but still in small boats particularly gives the impression of lots of flat surfaces. I'm not sure with good computer modelling a non flat table could be created to get the right bends in the right places before starting to stitch the panels together, would give a better surface. But here is the rub though, all that extra design time could probably be better spent ( and more rewarding ) simply getting on with building the boat using traditional foam and female stations. | | | Re: material
[Re: pgp]
#209488 04/25/10 04:25 PM 04/25/10 04:25 PM |
Posts: 1,449 | Pete, I have done some brief experiments laminating one side of a foam panel and then bending it to the required shape. Once in that shape the other laminate can be applied. However the required shape was only sufficient to build the Razor design I'm currently prototyping in ply. It is on my to do list to build a fully foam sandwich version to prove the point. This bloat has curved sides but also it does have Chines. When seen in the flesh they are not that noticeable and will only be seen in the water when flying a hull. I did post some pics on the F16 forum. One of the objectives of this design was to come up with something that could be built easily from ply or foam sandwich. Bending a foam panel that has both sides already laminated would be quite different.
| | | Re: material
[Re: phill]
#209490 04/25/10 06:50 PM 04/25/10 06:50 PM |
Posts: 805 Gainesville, FL 32607 USA | Phill, Are you suggesting a (thin) foam panel laminated on one side then bent (like over a chine form) before the laminate epoxy goes totally off? I would be very interested in this for a Moth hull. For CF cloth too?
| | | Re: material
[Re: dacarls]
#209498 04/25/10 10:41 PM 04/25/10 10:41 PM |
Posts: 1,449 | Dave, The idea in my application is to apply the inside laminate. It does not matter if it goes off completely as the laminate is quite thin. All it does is prevent the inside from compressing which means the outside has to stretch more when curving the panel. A simplified description is this is bent around some frames. If bent too much it will eventually crack as there is a limit to how much the outside will stretch before failure. This is why I had to do some testing - to ensure it can take the curve without problem. In my testing I used 8mm core cell foam and 200gm plain weave glass. The greatest curvature in the Razor hull is at the transom and it takes the curve quite easily. You may ask why apply the inside laminate first. The fist laminate can be done on a flat table and I reason that it is just easier to apply a vacuum to the outside once the shape has been formed then to vacuum on the inside laminate.
If I find this to not be the case when prototyping the foam version I can go to an outside laminate option. Replacing the 200gm plain weave glass with carbon would achieve exactly the same result. Now if you wanted significantly more curvature you would put the laminate on the outside. Interesting side issue is that I have found that when a light laminate is put on the outside of 4mm gaboon ply I have managed to device a process that will allow me to bend bend it around a 40mm radius without failure and this is without steaming. I'm convinced that there is a great deal more flexibility in the materials that we have available to us than we are currently using. We just have to look for slightly different processes.
Regards, Phill
| | | Re: material
[Re: phill]
#209518 04/26/10 09:53 AM 04/26/10 09:53 AM |
Posts: 5,590 Naples, FL | Pete, is this to re-deck the Tiki? What does the builder recommend?
| | | Re: material
[Re: waterbug_wpb]
#209520 04/26/10 10:01 AM 04/26/10 10:01 AM |
Posts: 5,525 | Yes. These are home built boats. The designer recommends marine plywood which has limited durabiltiy. In addition a small motor mount is built in.
I'll probably go to some sort of trampoline with an aluminum frame.
| | | Re: material
[Re: pgp]
#209523 04/26/10 10:04 AM 04/26/10 10:04 AM |
Posts: 5,590 Naples, FL | so it's non-structural stuff, right? Pimp it out with tounge&groove teak and be done  There were days when I cursed the brightwork duties on a friend's Choy Lee, but dang those things look sweet when they're all dolled up...
4,331
guests, and 637
