| Mast rake #209941 04/30/10 01:07 PM 04/30/10 01:07 PM |
Posts: 246 Kiel, Germany | Which paramenters change if you increase mast rake? Is this an appropriate instrument if you expect strong winds?
F18: C2 / A-Cat: Minelli
| | | Re: Mast rake
[Re: Baltic]
#209992 04/30/10 09:49 PM 04/30/10 09:49 PM |
Posts: 829 Charleston, SC | I generally play with mast rake only if I expect extreme condition-either way. If it's going to be very windy, I'll send the mast back a little. If I know it'll be light for an entire day, I'll send it forward a little. It's important to know where the baseline is.
Also, do keep in mind that changing rake will effect things such as spinnaker luff tension. I'm a stickler on proper spin luff tension and have to be aware that when I change the rake, the tension will have to be adjusted accordingly via the spin pole or up top with the bale setting.
Trey
| | | Re: Mast rake
[Re: NCSUtrey]
#210008 05/01/10 04:38 AM 05/01/10 04:38 AM |
Posts: 246 Kiel, Germany | I generally agree with your remarks concerning luff tension of the spin, but isn't it a good thing having it tighter us usual in heavy air? I wonder how different mast rake affects the main, at least the angle of sheeting should change.
| | | Re: Mast rake
[Re: Keith]
#210014 05/01/10 08:02 AM 05/01/10 08:02 AM | andrewscott
| andrewscott
Unregistered | changes in mast rake may require changes in rudder rake as well
419
guests, and 114
