| My Wave Impressions #211787 05/24/10 12:59 PM 05/24/10 12:59 PM |
Posts: 3,969 | OK, sailed a Wave for the first time ever this weekend at Madcatter. Even though I managed to flip it and tore up something in my knee in the process, I was very impressed with this little boat. Here are some things I observed (keep in mind how much of a die-hard SMOD Hobie guy I am as you read this)...
Awesome buoyancy! It would be really hard to pitchpole this thing. I'm very heavy, and no matter where I sat on the boat, it always felt solid under me.
Having said that, this thing REALLY needs a tiller. Like any boat, you want your weight forward when it's light, and especially when going downwind, so a tiller would really help. What's the downside of having a tiller on the Wave?
The boat I was on had a one-piece tramp. I would never buy one. Not only is it impossible to get tight enough, there's nothing to grab onto when the boat's on its side, or worse, to try to climb back aboard after it's righted. Especially with no dolphin striker to step onto, I had to have a safety boat helper pull me out of the water. I know, I'm a spoiled H16 sailor, and could just make a rope ladder if I owned one...
Downwind...wow, does this thing need a chute! I thought downwind on a H16 was boring in light air, this thing is boring downwind in all conditions!!! Now I know how Opti sailors feel!
All in all, I would definitely buy one of these, and think everyone should have one as a spare boat for those regattas when your crew bails, etc. Having a nice fleet of 10 Waves at every regatta would be an awesome goal.
| | | Re: My Wave Impressions
[Re: brucat]
#211804 05/24/10 07:47 PM 05/24/10 07:47 PM |
Posts: 921 Alachua, FL | It was blowing 20 plus in one of the races, and it was like taking a nap going to C mark. Dead downwind they told me. Every time I tried to surf, I ended up sailing on a higher angle and lost distance to the DDW folks.
Mike, The problem was the race committe was not familiar with the ICWA Wave course. They set B mark as an off set rather than a true reach. It should have been clear over by the shore. Then we would have had two hot reaches and only one DDW. Believe it or not, those B leg reaches have a lot of passing situations, and scary submarine dives if it is blowing...like it did at times on Saturday. I have lobbied for a tiller extension, but you really don't need one. It only helps the little people get way forward and that is FAST for them. Fat guys really need to stay at the back when it is blowin'. Otherwise you will be swiming with the fishes.
Jack Woehrle Hobie Wave #100, Tiger Shark III HCA-NA 5022-1 USSailing 654799E Alachua FL/Put-In-Bay | | | Re: My Wave Impressions
[Re: brucat]
#211820 05/25/10 06:27 AM 05/25/10 06:27 AM |
Joined: Aug 2007 Posts: 342 Indianapolis, IN - Midwest USA... IndyWave
Posts: 342 Indianapolis, IN - Midwest USA... | Having said that, this thing REALLY needs a tiller. Like any boat, you want your weight forward when it's light, and especially when going downwind, so a tiller would really help. What's the downside of having a tiller on the Wave?
Mike, Check out some of my posts on the Wave forum. I agree with most everything you said, and have come up with a few (non-class-legal) cheap and easy solutions, ie: tiller extensions from Lowe's and my "spin-brella". I'm not sure they really enhance performance any, but in the right hands, maybe?
What - Me Worry?
2006 Hobie Wave 7358 "Ish Kabibble"
[Re: IndyWave]
#211822 05/25/10 07:16 AM 05/25/10 07:16 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | Hi Mike, You are correct about the downwind legs. That is why the official class course is a triangle, windward, leeward finish. Thus, two beats, two reaches and only on boring downwind leg. Another reason for only one downwind leg is we don't want to have weight minimums, and little people are much faster downwind. Which leads us to the tiller extension. Big people can get farther forward, and then the little people only gain a few boat lengths on them. With a tiller, the little people could get farther forward, thus gaining a lot of boat lengths downwind. I believe our class has thought all of those things out and have ended up with a very competitive class, where folks over 200 lbs and folks under 100 lbs can both compete. As for a chute, I agree. Hobie has a spinnaker for it, but it doesn't work. I designed a roller furling Hooter and it does work. It is mounted as a masthead, and can be used upwind and off the wind. I have won several major races with this rig, beating a lot of H16s boat for boat, and even several Hobie 18s. Take a look at http://www.catsailor.com/waves/superwave_overall.htmlI was working on a design where I could also carry a self-tacking, roller furling jib, a longer bowsprit with a bigger Hooter. It was during the Sandusky Steeplechase that I first tried it out -- I was staying with a Hobie 20 sailed by a top national sailor. Well, for a while.., then it imploded. I stopped working on that project, although it is most certainly do-able. Guess the point is you could put a lot of sail power on the design because it has so much buoyancy. A few years ago a bunch of us thought about a Formula 14 Class. So, a bunch hopped up some H14s, and I did the Wave. The 14 does not have the buoyancy to carry a lot of extra power. They were faster, but always capsized. Rick | | | Re: My Wave Impressions
[Re: RickWhite]
#211829 05/25/10 09:40 AM 05/25/10 09:40 AM |
Posts: 3,969 | Again, these are all just first impressions. The class seems to be very competitive and fun!
My point about the tiller was for when the wind is light. Fat guy on the back of any boat is slow.
As for the B mark at Madcatter, that's not Irene's fault (well, maybe for the first race). She wanted our input for how to set up the courses. Garbage in / garbage out. All we needed to do was tell her to move the B mark and she would have.
To really get rid of the DDW leg, why not just use all triangles? Or, have a course of two triangles then the sausage? The distances don't have to be long.
I should have stated, simple is good. Adding a chute would be fun, but not if it means over-complicating things, or adding cost and complexity that would result in less boats racing.
BTW, thanks for the boat Rick!
Mike | | | Re: My Wave Impressions
[Re: brucat]
#211830 05/25/10 09:50 AM 05/25/10 09:50 AM | xanderwess
| xanderwess
Unregistered | Mike If you looked at Patrick's boat, he has the classic also and had a great way to get the tramp really tight with these turnbuckle things. Maybe he'd post a picture. I wish we would have had some freakin' wind in INDY a couple weeks ago! I was in first for a little while (then the wind kicked, switched and sent me waaay back......) | | | Re: My Wave Impressions
[Re: carlbohannon]
#211839 05/25/10 01:33 PM 05/25/10 01:33 PM |
Posts: 921 Alachua, FL | It gets your weight where you want it and reduces the windage.
Just my opinion I LIKE windage DDW
[Re: Mugrace72]
#211840 05/25/10 02:57 PM 05/25/10 02:57 PM |
Posts: 3,224 Roanoke Island ,N.C. | It gets your weight where you want it and reduces the windage.
Just my opinion I LIKE windage DDW \ Jack , Are you coming to the Duck Cup? If so could you bring your scales? Thanks.
[Re: Team_Cat_Fever]
#211841 05/25/10 03:16 PM 05/25/10 03:16 PM | xanderwess
| xanderwess
Unregistered | BTW, what the heck is a wave supposed to weigh? I think mine is heavy as hell (judging by the grunts we had doublestacking her) | | | Re: My Wave Impressions
[Re: ]
#211855 05/25/10 04:47 PM 05/25/10 04:47 PM |
Posts: 921 Alachua, FL | BTW, what the heck is a wave supposed to weigh? I think mine is heavy as hell (judging by the grunts we had doublestacking her) At the Duck regatta last Sept. I weighed all the boats and there was only an 8# difference between the heavy and the light ones. Mine was the heaviest at 259 and it is an '06.
#211856 05/25/10 04:48 PM 05/25/10 04:48 PM |
When is it? My boats are in Ohio.
[Re: Mugrace72]
#211920 05/26/10 10:50 AM 05/26/10 10:50 AM |
When is it? My boats are in Ohio. June 12 and 13 http://norbanks.com/store/Sailing-Regattas/
#211924 05/26/10 11:39 AM 05/26/10 11:39 AM |
Posts: 921 Alachua, FL | Oh...I was thinking in the fall. What do you want to weigh Todd? If someone from here wants to take them, I just need them back before June 20.
[Re: WightWave]
#215449 07/07/10 10:19 AM 07/07/10 10:19 AM |
Posts: 921 Alachua, FL | Hi All,
I also found that the Wave sails downwind Wing on Wing very well but don't know if doing this made a difference. How do you do that with one sail?
596
guests, and 243
