| H-18 Mast prebend #212651 06/04/10 10:48 PM 06/04/10 10:48 PM |
Posts: 1 | I was reading Rick + Mary's Catamaran Racing: for the 90's and had a few questions about mast prebend. How tight should I make the diamond wires? Do I need to use a tension gauge to get them even? Are the spreaders on the H-18 raked back far enough with the stock setting? If not how far back should I rake them? After sailing should I loosen the diamond wires? Any input would be greatly appreciated. Thanks, Bob.
| | | Re: H-18 Mast prebend
[Re: wwkbob]
#212667 06/05/10 05:46 AM 06/05/10 05:46 AM |
Posts: 1,203 uk | The Hobie 18 does not use prebend. It uses the 'soft' rig system where the mast is allowed to bend sideways slightly by slacker diamond wires.
just tighten the diamond wires finger tight and look up the mast track [no sail up] to check that the mast is straight.
point the spanner at the shrouds when sailing, ease it off towards front beam when it gets windy
[Re: RickWhite]
#212681 06/05/10 08:13 AM 06/05/10 08:13 AM |
Posts: 1,203 uk | Ignore what I said - do what Rick said!
[Re: RickWhite]
#212806 06/06/10 01:13 PM 06/06/10 01:13 PM |
Posts: 53 Arkansas, USA | Rick- Did you guys upgrade the downhaul considerably also?
Kirt
Kirt Taipan 4.9 USA 159, Flyer USA 185 Will sail for food...
[Re: Arsailor]
#212882 06/07/10 06:45 AM 06/07/10 06:45 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | Yes, the downhaul was not stock. Can't remember the purchase now, but we were still class legal. A minimum of 16:1 is recommended today, since there is no class anyway. The reason so much is not to have the power to downhaul, but to be able to uncleat the downhaul while on the trapeze. If less, the crew has to get of the trap to release it when the air lightens up. Rick | | | Re: H-18 Mast prebend
[Re: RickWhite]
#212885 06/07/10 07:30 AM 06/07/10 07:30 AM |
Posts: 1,884 Detroit, MI | Yes, the downhaul was not stock. Can't remember the purchase now, but we were still class legal. A minimum of 16:1 is recommended today, since there is no class anyway. There may be no class where you are, but there is still an active racing Hobie 18 class in many parts of the country. There were 18 boats at the North Americans last year, and there are over 100 members of the HCA-NA that list the Hobie 18 as their primary boat. By making a non-factual, negative comment regarding the Hobie 18 class, you have once again demonstrated your bias against the Hobie Class Association and one-design racing. BTW, max CLASS LEGAL downhaul purchase for the 18 is 8:1. A 16:1 downhaul will rip the tack grommet out of the sail unless it's reinforced. | | | Re: H-18 Mast prebend
[Re: mbounds]
#212893 06/07/10 08:25 AM 06/07/10 08:25 AM |
Posts: 1,187 38.912, -95.37 | There were 18 boats at the North Americans last year see ya at (come to) Lake McConaughy, Nebraska in September for this years' NAC's. Get that 18 on the road, you'll have a blast! And I'm sure Mister Sohn & Mister Cooley can be coersed in to another tag-team, tuning clinic.
[Re: _flatlander_]
#212895 06/07/10 08:36 AM 06/07/10 08:36 AM |
Posts: 1,187 38.912, -95.37 | The class legal 8:1 cunningham lets you crank up the class legal dacron sail enough to sound like a nice snare drum. That's what we ran on our 18.
IMHO, 8:1 is not enough DH purchase to make playing it from the wire a reality. I've raced all the Hobie classes (except 17) and think you're kidding yourself pretending to go upwind like a Tornado, N20 or F18. The 8:1, and less, allowed by Hobie rules is not enough purchase to make the DH anymore effective than a set-it and forget it function a on "class legal" Hobie boat.
[Re: _flatlander_]
#212899 06/07/10 09:10 AM 06/07/10 09:10 AM |
Posts: 330 | The class legal 8:1 cunningham lets you crank up the class legal dacron sail enough to sound like a nice snare drum. That's what we ran on our 18.
IMHO, 8:1 is not enough DH purchase to make playing it from the wire a reality. I've raced all the Hobie classes (except 17) and think you're kidding yourself pretending to go upwind like a Tornado, N20 or F18. The 8:1, and less, allowed by Hobie rules is not enough purchase to make the DH anymore effective than a set-it and forget it function a on "class legal" Hobie boat. Different strokes for different folks, I guess. We race the 18 fairly extensively in one of the more active divisions. 6:1 purchase is all my (female) crew needs to play the downhaul from the wire in 95% of the conditions we sail. If we actually need it bottomed out, she will hand it to me to finish the job if need be, but usually she doesn't need to. Fine tuning the downhaul on the Hobie 18 may not be quite as critical as on some of the modern boats, but it certainly makes a difference and is by no means a set-and-forget adjustment. sm | | | Re: H-18 Mast prebend
[Re: srm]
#212906 06/07/10 09:59 AM 06/07/10 09:59 AM |
Posts: 1,187 38.912, -95.37 | Different strokes for different folks, I guess. We race the 18 fairly extensively in one of the more active divisions. sm Yup, guess so...where were you at Havasu? Is Dean from your Division? He was fast. All us midwest boys could squeak out on an ole '82 was fifth place. Come on out to Nebraska sm and enjoy some ice cream.
[Re: mbounds]
#212915 06/07/10 11:33 AM 06/07/10 11:33 AM |
Posts: 1,203 uk | Yes, the downhaul was not stock. Can't remember the purchase now, but we were still class legal. A minimum of 16:1 is recommended today, since there is no class anyway. There may be no class where you are, but there is still an active racing Hobie 18 class in many parts of the country. There were 18 boats at the North Americans last year, and there are over 100 members of the HCA-NA that list the Hobie 18 as their primary boat. By making a non-factual, negative comment regarding the Hobie 18 class, you have once again demonstrated your bias against the Hobie Class Association and one-design racing. BTW, max CLASS LEGAL downhaul purchase for the 18 is 8:1. A 16:1 downhaul will rip the tack grommet out of the sail unless it's reinforced. You jumped down his throat there a bit! is there some history? How many new H18s sold last year?
[Re: TEAMVMG]
#212919 06/07/10 11:49 AM 06/07/10 11:49 AM |
Joined: Nov 2003 Posts: 749 Santa Cruz, CA SurfCityRacing
Posts: 749 Santa Cruz, CA | Yes, the downhaul was not stock. Can't remember the purchase now, but we were still class legal. A minimum of 16:1 is recommended today, since there is no class anyway. There may be no class where you are, but there is still an active racing Hobie 18 class in many parts of the country. There were 18 boats at the North Americans last year, and there are over 100 members of the HCA-NA that list the Hobie 18 as their primary boat. By making a non-factual, negative comment regarding the Hobie 18 class, you have once again demonstrated your bias against the Hobie Class Association and one-design racing. BTW, max CLASS LEGAL downhaul purchase for the 18 is 8:1. A 16:1 downhaul will rip the tack grommet out of the sail unless it's reinforced. How many new H18s sold last year? I can answer that. None. A few new hulls... But... there are a core group of guys working very diligently all around the country to try and pipe-up the TheMightyHobie18 numbers at regattas. Hence, the OPs question. Nice pic Matt! | | | Re: H-18 Mast prebend
[Re: SurfCityRacing]
#212943 06/07/10 02:09 PM 06/07/10 02:09 PM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | Right, Matt loves me. BTW, I think I have done a helluva lot to promote Hobie sailing for the last 30 years. My point was very simple -- you cannot play the downhaul from the trapeze with low ratios. The 16:1 is not there to play Magilla so you are not going to rip ANYTHING out, and as for line on the deck, you can make it continuous. Sorry I offended you, Matt, but you simply don't see one of my favorite boats around much anymore (TheMightyHobie18) and that is too bad. Hmmm, I think I remember we did use an 8:1, but put a cascade on it -- probably a gray area. Think the rules were there so people would not break masts and stuff. But, a higher ratio on the downhaul would be a big help in sailing the boat. Rick | | |
2,517
guests, and 112
