Page 2 of 3 1 2 3
Re: Weather proofing a wood box? [Re: orphan] #213966
06/16/10 08:29 AM
06/16/10 08:29 AM
pgp Offline
pgp  Offline
"I put the reenforcement strips on the inside."
+1 I didn't want to give water a chance to collect anywhere.
Pete Pollard
Blade 702
Re: Weather proofing a wood box? [Re: pgp] #213970
06/16/10 09:23 AM
06/16/10 09:23 AM
I'm liking the bed liner stuff.
Boxes are subject to a lot of vibration, so the coating needs to be flexible and tough. The road is a very harsh environment, especially in the rain, when all the gook on the road ends up on the sailbox.
I'd be concerned that the bond with the wood might fail - you'd need to stay on top of repairing any penetrating dings in the coating.
It just doesn't win in the looks department. Gotta look good to go fast, even with the sailbox.
Re: Weather proofing a wood box? [Re: mbounds] #213971
06/16/10 09:31 AM
06/16/10 09:31 AM
2 oz cloth and a gallon of polyurethane. $45
Or all the leftover gelcoat from your local boat repair shop...
Re: Weather proofing a wood box? [Re: mbounds] #213972
06/16/10 09:40 AM
06/16/10 09:40 AM
Daytona Beach Florida
O
orphan Offline
orphan  Offline
O
I used 1X2(fir) around the edges(of 1/4 inch birch ply screw and glue) and the cross supports(also 1X2 fir) sat on top of the 1X2. This also keep equipment elevated off the bottom of the box for air circulation. I curved the top of the box for drainage with a 1 1/2 in overlap. The lid is a lift off lid. Never had a problem with water getting into the box. With the curved lid the box was strong enough to support my 245 pounds. I coated the inside with polyester resin to keep any moisture out of the wood. Total coast to build about 145 dollars.
Re: Weather proofing a wood box? [Re: orphan] #213974
06/16/10 09:50 AM
06/16/10 09:50 AM
Maryland
Kris Hathaway Offline
Maryland
I have plans for a custom box and hope to turn the project into learning resin infusion. I originally planned to build completely out of 1/2" MDO (weatherproof signboard, not MDF) but saw the layup process of an awasome A-Cat, Predator Blog, and decided to use the MDO for framing and foam for filler, glassing over both. This weekend I spoke to an Albacore racer that was estatic about resin infusion. He saved a lot of weight and achieved greater strength over glass layup. Because they have a weight min, he was able to "overbuild" in the important areas.
Kris Hathaway
Re: Weather proofing a wood box? [Re: Kris Hathaway] #213977
06/16/10 10:32 AM
06/16/10 10:32 AM
Hamburg
Smiths_Cat Offline
Smiths_Cat  Offline
Hamburg
Use epoxy as primer (2 to 3 layer), an epoxy is fine, not only west system. Than use a good paint. Acryl or polymer based, if you have the protective gear PU would be the ultimate choice. The primer is key to keep the moisture inside the wood constant (and low), so that the paint can stick. The paint protects the epoxy from UV rays.
Cheers,
Klaus
Re: Weather proofing a wood box? [Re: Smiths_Cat] #213978
06/16/10 11:53 AM
06/16/10 11:53 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
In the UK the truck bed liner ply is called Grudamesh
I think that the textured side is more resilient than the smooth side;
Re: How about a polymer truck bed coating? [Re: tomthouse] #213981
06/16/10 01:24 PM
06/16/10 01:24 PM
Karl_Brogger Offline OP
Originally Posted by tomthouse
I don't know about you guys, but I'm feeling the love here and I really like the looks of your shop in the background of your picture of the box.
When its clean:
I've got the box basically built. I should probably take all the crap that's going to go in there, and actually make nice little dividers, but I'm lazy, and its already taking longer than I wanted it to.
I'm kind proud of this bit. It will be the gutter between the two lids. The box is twelve feet long, with about a 4 foot lid in front, and a bit less than 8 foot lid for the back portion.
I kicked around the bedliner stuff. It'd kind nice to do just a couple of coats of something and be done with it. I gotta get some hinges, finish building the two lids, and it'll be ready for a coat of something.
Re: How about a polymer truck bed coating? [Re: Karl_Brogger] #213982
06/16/10 01:35 PM
06/16/10 01:35 PM
Punta Gorda, FL
jkkartz1 Offline
jkkartz1  Offline
Punta Gorda, FL
Why not some oil based stain?
Its easy to apply, soaks in good and is reasonably priced.
Re: How about a polymer truck bed coating? [Re: jkkartz1] #213983
06/16/10 01:39 PM
06/16/10 01:39 PM
Looks great - is that 12-feet inside? That would accommodate a spin pole nicely with about 1/4-inch to spare. Nice work.
Re: How about a polymer truck bed coating? [Re: John Williams] #213984
06/16/10 01:47 PM
06/16/10 01:47 PM
Outside. All I need is 11',3" for the F16 pole.
Re: Weather proofing a wood box? [Re: mbounds] #213985
06/16/10 01:48 PM
06/16/10 01:48 PM
brucat Offline
brucat  Offline
Karl... you complete me.
You guys need to get a room.
NTTAWWT.
Do you want the SHORT list???
Looks great Karl! I could use a custom cabinet for a TV in my RV, but I'm a catsailor and therefore, really cheap. Well, mainly I wouldn't want to pay more for a cabinet than the TV is worth...
Re: Weather proofing a wood box? [Re: brucat] #213988
06/16/10 02:19 PM
06/16/10 02:19 PM
O
orphan Offline
orphan  Offline
O
Hell, That's not a sail box. That looks like furniture. Really nice stuff. For that quality build go with several coats of UV Polyurethane or spend the few extra buck and go with epoxy.
Re: How about a polymer truck bed coating? [Re: John Williams] #213991
06/16/10 02:56 PM
06/16/10 02:56 PM
andrewscott
andrewscott
or 100 illegal immigrants - what would you charge for rent?
ps very nice looking, esp like the corners (are those called dove tails or something)
Re: How about a polymer truck bed coating? [Re: ] #213997
06/16/10 04:13 PM
06/16/10 04:13 PM
It'd be a shame to hide that joiner work.
I'd go with a clear finish on the top and sides, the bedliner stuff on the bottom where it needs the impact protection and nobody sees it. It's a rolling advertisement for your work.
I like the curved top idea, too.
Oh, yeah - Karl?
Buy a freakin' ad, would ya?
Re: How about a polymer truck bed coating? [Re: mbounds] #214000
06/16/10 04:21 PM
06/16/10 04:21 PM
I'd bet, Matt, that Karl doesn't have much interest in selling these - he's clearly got a ton of work in this one. Any guess what he would sell it for? Any further guess what people would be willing to pay?
Re: How about a polymer truck bed coating? [Re: John Williams] #214006
06/16/10 06:09 PM
06/16/10 06:09 PM
Ton of work? No, I'm up to about 12 hrs.
Matt- I like your idea, I bought a gallon of the bedliner stuff. I'm thinking I'll do the inside, and the bottom with it, then do the rest in some sort of clear poly, and just give it a recoat each year. I better dig out some stain it as well, since I grabbed some of the nastiest looking stuff I had on hand.
Also no, I have zero interest in making these. The 12' panels are serious pain in the brown eye, and I'd have to do a better job. I would be curious what people would realistically pay.
Curved lid, too much phuckin' around. My driveway has more pitch than most Southern roofs, so it'll be okay.
Construction is done:
I don't even have a boat.
Re: How about a polymer truck bed coating? [Re: ] #214007
06/16/10 06:24 PM
06/16/10 06:24 PM
I think what you're talking about is the just a profile so the panel has a spot to go. Its all done with a machine, so zero skill involved. Basically I made doors and mitred and glued them together to make up the "box" part.
Dovetails are a mechanical joint heralding from the days when you had to cut off Bessie's hooves to make glue. Glue from way back when sucks, and when the glue fails you still have a joint that'll hold tight. When done correctly, glue isn't really all that neccessary. The flip side is that glue has gotten so good that dovetails should be obsolete, but the process has gotten so cheap that its more popular than ever.
The joint in the corner of these draweres are dovetailed:
Re: How about a polymer truck bed coating? [Re: Karl_Brogger] #214010
06/16/10 07:14 PM
06/16/10 07:14 PM
Ok, so what is your hourly rate for labor?
Re: How about a polymer truck bed coating? [Re: John Williams] #214012
06/16/10 08:06 PM
06/16/10 08:06 PM
I'm not suggesting he sell these - it's a reflection on the quality of the work in his cabinet business.
Ad would be for the cabinet business.
Page 2 of 3 1 2 3
0 registered members (), 20,780 guests, and 1,475 spiders.
Most Online22,490
Yesterday at 08:14 AM
