Best product for restoring/polishing hulls? #21425
06/24/03 07:53 AM
06/24/03 07:53 AM
Lansing, Michigan
Nick Offline OP
Nick  Offline OP
Lansing, Michigan
What have you found to be the best polish/restorer for your hulls? My 16 is looking a little chalky. Do you like MacGregor's? Starbrite? Something else?
1978 Hobie 16 "Burt The Cat"
Re: Best product for restoring/polishing hulls? [Re: Nick] #21426
06/24/03 06:06 PM
06/24/03 06:06 PM
Bogie Offline
Bogie  Offline
Sandpaper. Yep, no kidding.
Depends on how bad the oxidation is. If need be, start with 600 wet or dry, used wet of course, then move up to 1000, then 1500, then 2000 if you can find it. Finish off with 3M fine grit rubbing compound. If the chalking is not that bad, you might start with 1000 to make the job easier.
It'll look as good as new.
Re: Best product for restoring/polishing hulls? [Re: Nick] #21427
06/26/03 10:28 AM
06/26/03 10:28 AM
north alabama
turtle Offline
turtle  Offline
north alabama
I agree, I tried expensive color restorers which didn't work so out of desperation, I cleaned them with straight bleach them I used sand paper. The sandpaper made my old yellow hulls shine, I have an '81. I don't know what it does to the clear coat. I waxed the hulls afterwards and my boat doesn't stay in the water.
0 registered members (), 19,015 guests, and 708 spiders.
Most Online22,490
11 hours ago
