| Standing a carbon mast #214257 06/21/10 05:54 AM 06/21/10 05:54 AM |
Posts: 16 | Hi all I was just wondering what set up people have, to enable them to stand a carbon mast by themselves. Currently i use the help of others to hold the trapeze lines well i raise the mast. Some of the taipan sailer's at my club have rigged a small line which connects between the front beam and the trapeze lines which seems to work ok - I'm still considering this approach. Any advise would be great | | | Re: Standing a carbon mast
[Re: ACE11]
#214422 06/23/10 03:28 AM 06/23/10 03:28 AM |
Joined: May 2006 Posts: 954 Mumbles Y.C Wales U.K Mark P
Posts: 954 Mumbles Y.C Wales U.K | I do practically the same as ACE except I'm a bit lazier, I don't adjust the forestay lengths (ever) they are taped up! I also place a car carpet mat on the tramp as well just in case I need to put the mast down prior to lifting onto the mast step. I achieve my rig tension by pulling the traveller over to each side and attach the mainsheet to the relative trap wire, pull on mainsheet and fit the shroud eye and pin in the required hole position. Each to there own devices I guess. However, Like Klaus and ACE if it's windy it's far better to swallow your pride and ask for help. MP*MULTIHULLS | | | Re: Standing a carbon mast
[Re: Mark P]
#214552 06/23/10 10:35 PM 06/23/10 10:35 PM |
Posts: 3,116 Annapolis, MD | Don't forget to pin the mast base in the process.
crac.sailregattas.com
[Re: Mark Schneider]
#214561 06/24/10 04:29 AM 06/24/10 04:29 AM |
Posts: 954 Mumbles Y.C Wales U.K | There is no pin 'hinge' facility on the mast base of the Bimare AJ or my friends Tool. I've seen them on the Saarberg masted FLYER. With both the Bim and Tool you just lift the mast to vertical in close proximity to the front beam and then when the time is right lift the whole mast up and onto to the boat. Sometimes it is necessary to tie the base of the mast loosely to the front beam to stop the base of the mast kicking away when you are either raising or lowering.
[Re: Mark P]
#214716 06/26/10 04:30 PM 06/26/10 04:30 PM |
Posts: 571 Hamburg | There is no pin 'hinge' facility on the mast base of the Bimare AJ or my friends Tool. Interesting my 2004 Bimare has a pin... Why change it? | | |
2,785
guests, and 238
Mod | | Forums35 Topics22,989 Posts268,931 Members8,150 | Most Online23,979 Sep 24th, 2025 | | | |
