| Re: Cookie
[Re: pgp]
#214637 06/25/10 04:27 AM 06/25/10 04:27 AM |
Posts: 5,525 | After 33 days at sea, 135 miles east of Newport, winds 15-20.
Pete Pollard Blade 702
| | | Re: Cookie
[Re: boatsmith]
#218567 08/30/10 10:17 AM 08/30/10 10:17 AM |
Posts: 5,525 | I have to get my Tiki 21 back in the water. The decks are completely gone and I'm agonizing over replacing them per design or trying to come up with some sort of trampoline.
My other boat is a beach cat and I really like trapolines.
| | | Re: Cookie
[Re: DennisMe]
#219163 09/10/10 08:26 AM 09/10/10 08:26 AM |
Posts: 5,525 | No! I may have a way around that, but I'm no engineer and question my own "solution".
As designed the deck components take up a lot of space when trailering, are prone to rot and a little on the heavy side.
Hence the quandry.
| | | Re: Cookie
[Re: DennisMe]
#219246 09/11/10 05:50 PM 09/11/10 05:50 PM |
Posts: 5,525 | I bought the boat used and have no confidence that the decking was built to spec.
I will probably default to the builders specs and follow them scrupuluosly which requires epoxy/glass sheathing.
Another problem is related to the outboard motor cavitating. The bracket will either have to be lowered, moved from its aft position more to the center, or both.
| | | Re: Cookie
[Re: DennisMe]
#219323 09/13/10 07:37 AM 09/13/10 07:37 AM |
Posts: 5,525 | It's current position is a little too far aft, imo. The foot of the outboard strikes the rear cross bar so it can't be fully raised. Also, in any wave over two feet lifts the prop out of the water. The obvious thing is to move the mount a little more forward, which is what I will do.
| | | Re: Cookie
[Re: DennisMe]
#219676 09/16/10 09:36 AM 09/16/10 09:36 AM |
Posts: 18 | Hi all, We are Wharrams professional US builders. We typically will build our out board well int he center of the **** as it allows for an installation with the motor at the correct elevation for minimal cavitation and still keep the motor head as far away from the spray as possible. On the first Tiki 30 we built the motor was mounted too low. It never cavitated but there was a lot of drive leg in the water and the motor head was constantly being douched. We recently replaced the motor with a slightly larger model with power tilt (way cool) and built a new motor mount and covering box. Noe it seems to be just prefect. The prop starts to cavitate but never quite does and the motor head is clear of the vast majority of splashes. We build our **** of Joubert okoume and/or Divinycell foam. We sheath both with fiberglass. If the beam attachments are properly built there is no problem attaching tramps. ![[Linked Image]](http://farm5.static.flickr.com/4089/4995511499_1ceb4a548f.jpg) Th above right photo is of our old motor box. Ther is storage uder the cushions for fuel,batteries, fenders,linesand rigging. The front locker has a provision for long stuff, boat hook, mop,fishing poles and spears.There is also a built in cooler under one cushion. The left photo is of a slightly different **** built for a resort that uses it for day charters | | |
4,352
guests, and 686
