Page 6 of 8 1 2 3 4 5 6 7 8
Re: Formula 14 development [Re: Gato] #195586
11/07/09 08:40 AM
11/07/09 08:40 AM
Hope you will do your usual excellent photomentary of the build.
Re: Formula 14 development [Re: Rolf_Nilsen] #214796
06/28/10 12:10 PM
06/28/10 12:10 PM
Ft. Pierce, Fl. USA
Seeker Offline
Seeker  Offline
Ft. Pierce, Fl. USA
To take advantage of the most recent design trends I did a total revamp of my F14 design.
Including:
1) Broadening the hull from 9-1/2" to 14" wide
2) Completely changed the section shape
3) Add slightly more rocker profile
Almost finished with rebuilding the jig...here is the Starboard side Jig roughly completed…
Uploaded with ImageShack.us
Re: Formula 14 development [Re: Seeker] #214968
06/30/10 03:44 AM
06/30/10 03:44 AM
I like the look of that! Are you planning on building in wood or foam/glass?
Re: Formula 14 development [Re: Jalani] #215022
06/30/10 01:09 PM
06/30/10 01:09 PM
Ft. Pierce, Fl. USA
Seeker Offline
Seeker  Offline
Ft. Pierce, Fl. USA
Thanks Jalani...Foam and S2 glass/Kevlar, I already have the fabric...went to buy the 3/8" H80 Divinicell from my usual supplier (Merritt Marine In Palm Beach) and they said it would take 3 months to get it here from Europe...They just put in an order and their whole order is taking that long...Merritt is a major wholesaler to the Marine Industry down her in South Florida. Haven't been able to find another source (Divinicell or Corecell) that is not a couple of thousand miles away with $200+ shipping for the 7 sheets I will need.
I went ahead and ordered it from Merritt, but now I am kind of dead in the water...trying to find the lay-up schedule for a carbon version of the aluminum superwing in the mean time...
Re: Formula 14 development [Re: Seeker] #222758
10/26/10 09:35 PM
10/26/10 09:35 PM
Ft. Pierce, Fl. USA
Seeker Offline
Seeker  Offline
Ft. Pierce, Fl. USA
Finally got the divinicell cut and routed...got a bit of a start on the first half of the first hull.
Re: Formula 14 development [Re: Seeker] #222768
10/27/10 05:13 AM
10/27/10 05:13 AM
Glad to see you're back into it. I like the jigs you've built - they look very neat. Please keep us lazy voyeurs up to date with progress. smile
Re: Formula 14 development [Re: Jalani] #222797
10/27/10 02:33 PM
10/27/10 02:33 PM
Ft. Pierce, Fl. USA
Seeker Offline
Seeker  Offline
Ft. Pierce, Fl. USA
Thanks John for the complement...this build is going to have to go in spurts, as time permits. Tackled the tight chine radius this morning...worked well considering the compound curve the strips were required to make.
Worked on the sheer this evening...so all the basic foam for one half of one hull has been glued in place....the epoxy/glass bubbles were too wet on the new work to trim the foam tight to the jig.
Re: Formula 14 development [Re: Seeker] #222867
10/28/10 10:48 AM
10/28/10 10:48 AM
Ft. Pierce, Fl. USA
Seeker Offline
Seeker  Offline
Ft. Pierce, Fl. USA
Edge trimed closer... and stood right side up you can get a better look at what she is going to look like. Because the photo was taken at 45 degree angle, it is a little out of perspective, its leaner than it looks here...click on the photos for larger version...
Re: Formula 14 development [Re: Seeker] #223967
11/12/10 11:19 AM
11/12/10 11:19 AM
Ft. Pierce, Fl. USA
Seeker Offline
Seeker  Offline
Ft. Pierce, Fl. USA
Update...foam for both half's of hull #1 glued up...slow but steady progress. Couldn't resist popping one of them out of the jig and weighing it...as you can see 6 lbs 12 oz for one half of a hull...foam only.
Re: Formula 14 development [Re: Seeker] #224112
11/14/10 03:07 PM
11/14/10 03:07 PM
Scarecrow
Scarecrow
Seeker, you might want to make yourself known here, there are a whole lot of people looking to buy your boat.
Re: Formula 14 development [Re: ] #224284
11/16/10 02:47 PM
11/16/10 02:47 PM
Ft. Pierce, Fl. USA
Seeker Offline
Seeker  Offline
Ft. Pierce, Fl. USA
Scarecrow, thanks for the heads up...that's an interesting thread they have going on over there about building a rigid wing for a 14'-16' Cat or Tri...
A topic I was interested in exploring. With the cost of a carbon mast and a set of new sails being so high, it is very attractive to weigh the advantages of a rigid wing.
One of the most attractive aspects of it is the possibility of building the sail as well as the boat itself...
Re: Formula 14 development [Re: Seeker] #224285
11/16/10 03:19 PM
11/16/10 03:19 PM
Scarecrow
Scarecrow
Seeker, do you have much to spare in your weight budget? Given most of it can be built from scraps in your build a wing could turn out quite cheap. Particularly if you're happy not to twist the first section.
Re: Formula 14 development [Re: ] #224379
11/18/10 03:42 PM
11/18/10 03:42 PM
Ft. Pierce, Fl. USA
Seeker Offline
Seeker  Offline
Ft. Pierce, Fl. USA
Scarecrow...great tip...I threw out a laundry list of very specific questions over there on rigid wing design and Steve Clark gave very specific answers to every one of them...has to be an internet first...no beating around the bush...no generalities...nothing vague...straight question...straight answer. Steve was incredibly generous with his expertise. Thank you again for the redirect.
After you promting, I have spent many, many hours of research on the net. The prospect of building a rigid wing in place of conventional mast and soft sails seems very plausible at this point, and not nearly as bazaar as it is made out to be.
Re: Formula 14 development [Re: Seeker] #224401
11/19/10 03:36 AM
11/19/10 03:36 AM
It'll be one hell of a result if you build a lightweight 14 footer with a rigid wing! You'll certainly generate a lot of interest!!
Re: Formula 14 development [Re: Jalani] #224473
11/20/10 07:59 PM
11/20/10 07:59 PM
lesburn1 Offline
lesburn1  Offline
Seeker, I thought that there was a max. girth for the mast of an F14?
lesburn1.blogspot.com
A-Cat USA 49
18Sq 49
Re: Formula 14 development [Re: lesburn1] #224475
11/20/10 09:27 PM
11/20/10 09:27 PM
Ft. Pierce, Fl. USA
Seeker Offline
Seeker  Offline
Ft. Pierce, Fl. USA
You are so right... That is one of the few restraints on the F14 design.Will it stop me from persue a solid wing sail? Not at all. A rigid wing suitable for a 14' cat is looking very promising, if it proves feasable, I am going for it. If I go this route I will respect the F14 Class and call my cat something else...
Robert
Re: Formula 14 development [Re: Seeker] #224477
11/20/10 11:14 PM
11/20/10 11:14 PM
lesburn1 Offline
lesburn1  Offline
call it a F14+
A-Cat USA 49
18Sq 49
Re: Formula 14 development [Re: lesburn1] #224492
11/21/10 09:54 AM
11/21/10 09:54 AM
Ft. Pierce, Fl. USA
Seeker Offline
Seeker  Offline
Ft. Pierce, Fl. USA
I have a way to go in completing my platform before the rig becomes a critical issue.I am hoping by that time, Steve Clark will have finalized his current work on build plans for a rigid wing suitable in size for 14'-16' cat's & Tri's.
Robert
Re: Formula 14 development [Re: Seeker] #224493
11/21/10 09:59 AM
11/21/10 09:59 AM
Ft. Pierce, Fl. USA
Seeker Offline
Seeker  Offline
Ft. Pierce, Fl. USA
lesburn1, doesn't the tornado class have allowances for experimental variations? Sail # with an "X" or something to that effect?
Robert
Re: Formula 14 development [Re: lesburn1] #224502
11/21/10 07:01 PM
11/21/10 07:01 PM
Darryl_Barrett Offline
AS the "practical" interest in the F14 (lots of interest in the concept but very few "on the water" F14 cats) did not seem to "happen", it was voted on some two years ago to make the only restriction on the class the length IE an F14 is any "multi hull" sailing vessel that does not exceed 14' in hull length. Everything else is open. This makes the F14 a fully development class that, if multi hulls are built within that one measurement restriction, eventually the practical design limitations will soon be self regulating.
0 registered members (), 14,421 guests, and 459 spiders.
Most Online22,490
3 hours ago
