| Spreader Rake #215072 07/01/10 07:04 AM 07/01/10 07:04 AM |
Posts: 186 Chattanooga, TN | OK so Sis and I have noticed that in the lighter air we can not get the boat to move while in heavy air we did well as long as we could double trap. I know I am a lot heavier then the previous skipper but the light air problems were dramatic we felt. Well after RTI it was pointed out to me that we had way to much spreader rake. Got home and measured it and found the rake set at 125 mm. Talked to mike borden and found he and Chris are set at 55 or lower. This would explain why we are dying in the light air. So I am wondering what are most of you setting the rake at. We have the 09 Goodall main and together top out around 290 lbs. Thanks
Jody
Blade F16 724
Plays with Sharp Objects
| | | Re: Spreader Rake
[Re: jody]
#215076 07/01/10 07:34 AM 07/01/10 07:34 AM |
Posts: 5,525 | I've never understood spreader rake. Why does that setting explain why you're dying in light air?
How did you measure your rake?
Pete Pollard Blade 702
| | | Re: Spreader Rake
[Re: pgp]
#215078 07/01/10 07:46 AM 07/01/10 07:46 AM |
Posts: 439 Memphis, TN | Pete, The discussion about spreader rake and all of that could take a board of it's own, especially with all of the varying opinions on this board. So, Here are some links that can get you going..... http://www.ahpc.com.au/PDF/VIPER%20Tuning%20Guide.pdfThat says Viper tuning, but there is some explanation of what spreader rake can and do. So, that would pertain to all boats, even monos.... another. http://www.landenberger-sailing.com/spip.php?article21That one takes reading a couple of times to get it, then you need to experiment with it. The Viper tuning also explains how to measure the spreader rake. What everyone needs to take in consideration that the bend characteristics of all masts and sails will be different. Basically, If boat 1 and 2 have a brand new main from the same manufacturer and the masts are the same(wing masts), the bend characteristics of mast 1 could be different from mast 2. In other words, what rake works on boat 1 might not work on boat 2. But, discussing it with another sailor should start getting you in the ball park. The ONLY way to REALLY know, go out and sail against another boat. Mike.
Viper USA 132
1984 Hobie 18
| | | Re: Spreader Rake
[Re: jody]
#215080 07/01/10 08:01 AM 07/01/10 08:01 AM |
Joined: May 2006 Posts: 954 Mumbles Y.C Wales U.K Mark P
Posts: 954 Mumbles Y.C Wales U.K | Hi Jody By all means find out what other peoples settings are but don't forget as Matt pointed out recently no two masts, sails and the way you sail/race is the same. Your main should have tell tales roughly 2-3 feet above the spreaders and roughly a foot inside the luff, Set your spreaders to keep these tell tales flying as close to 100% as possible. If you don't have these tell tales in the above area you'll never know if you have the correct, matching mast to luff curve.
MP*MULTIHULLS | | | Re: Spreader Rake
[Re: pgp]
#215083 07/01/10 08:09 AM 07/01/10 08:09 AM |
Posts: 3,528 Looking for a Job, I got credi... | the way to measure it is to put a sail batten accross the back of the diamons where they exit the spreaders and then measure the distance to the sail track on the mast.
Too much rake means the mast bends more easily and there is less power in the sail.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Spreader Rake
[Re: Matt M]
#215085 07/01/10 08:33 AM 07/01/10 08:33 AM |
Posts: 5,525 | If 125mm is excessive, what is the normal range?
| | | Re: Spreader Rake
[Re: pgp]
#215097 07/01/10 09:49 AM 07/01/10 09:49 AM |
Posts: 548 MERRITTISLAND, FL | If 125mm is excessive, what is the normal range? Jeez Pete, were you not reading the post above? You have to look at the whole picture. Sailing to somebody’s fixed chart will do you a huge disservice. His 125 was probably set as a result of some post somewhere and although it sounds high it may work fine. 125 and 500 lbs of tension may be way too much prebend – but maybe not. With a lower tension setting it may be great. This though may cause more bending in the mast, so again if you do not adjust your jib trim and rotation to take this into account you will be slow. Is the problem the mast settings, or the other settings. If you trim properly and drive properly 125 in rake COULD be wicked fast. Screw up any other item on trim and you may not ever know what caused a problem with boat speed if you have one. (I have seen as much as 90 but the tension is so low for most reputable sails you run a risk of breakage, I have seen some older Euro A class set ups that were around 10) | | | Re: Spreader Rake
[Re: pgp]
#215101 07/01/10 10:15 AM 07/01/10 10:15 AM |
Posts: 9,582 North-West Europe | Normal range as defined in what I see or heared being used over a wide range of F16 masts and sails (see Matt's comments) is :
30 mm to 70 mm spreader rake
I'm running 48 mm myself (superwing mast from 2002 and a 2003 redhead mainsail with a luff curve cut for a 150 kg crew but also with an issue in the very top requiring me to always run lots of downhaul).
| | | Re: Spreader Rake
[Re: jody]
#215105 07/01/10 11:18 AM 07/01/10 11:18 AM |
Posts: 118 Pensacola, FL | Jody, Are you sure it is just a light air problem? You and Joanna seem slow all the time.
Chris Trident F16
| | | Re: Spreader Rake
[Re: PTP]
#215112 07/01/10 12:46 PM 07/01/10 12:46 PM |
Posts: 954 Mumbles Y.C Wales U.K | That's why I have been taught to trust in the telltale method. Sail makers don't just stick em any old where. Each tell tale is positioned to guide you to achieve optimum sail shape and control. Take the very top telltale, middle if you have three in a row what's it telling you?........ If the outside is flying horizontally and the inside isn't you've either sailed off the wind (pinched) or you haven't enough mainsheet tension. Now you are beating nicely the mainsheet is pulled on as hard as is reasonably practical for the conditions and the top telltale still wont fly horizontally. If you pull more downhaul on from your marked max power setting (we've all marked our downhaul position for max power haven't we). Then the inside top telltale WILL fly horizontally. And so on, each telltale serves a purpose.
[Re: PTP]
#215120 07/01/10 01:33 PM 07/01/10 01:33 PM |
Posts: 4,119 Northfield Mn | what about leach tales? never been able to figure those out really You want them flipping- foward, back, forward, back, forward, back. If they're flying forward too much: oversheated and the sail is hooked. In light air the rememedy is to crank on the cunningham and open the top of the sail up to get a consistant shape. If they're flying back too to much: Undersheated or...... I'm talking completely outta my butt.....
| | | Re: Spreader Rake
[Re: PTP]
#215125 07/01/10 03:23 PM 07/01/10 03:23 PM |
Posts: 4,119 Northfield Mn | You still want them behaving like I said when you are going downwind as the main still thinks its going to weather. You should be playing the main going downwind just as much as going to weather. A bit hard if you're singlehanding though.
| | | Re: Spreader Rake
[Re: Karl_Brogger]
#215128 07/01/10 04:05 PM 07/01/10 04:05 PM |
Posts: 186 Chattanooga, TN | CAB how high can a main go up the mast again?  Will have to look at the taletalls again. Have noticed that up wind the one just above the tang area is flying the complete opposite of the others, thought about just taking it off, but reason hits and I think it might be trying to tell me something. Any one got a telltale decoder or a babble fish?
Jody
Blade F16 724
653
guests, and 199
