| New Centreboards #215709 07/10/10 08:04 PM 07/10/10 08:04 PM | thricebitten
| thricebitten
Unregistered | Hi all, am about to make a major modification to Thrice Bitten.  Have purchased a set of couple of year old design, A class Flyer centreboards and cases  , which I am going to get put into my 15 year old Faye hulls (it currently has very wide, wider than boyer centreboards)  . No surprises that I will get them installed as far back as possible (which is where the back of the current cases is), the interesting bit is that I intend to get them installed vertically (most Mossies angle them back the maximum 10 degrees), so what do you think? | | | Re: New Centreboards
[Re: ]
#215710 07/10/10 08:20 PM 07/10/10 08:20 PM |
Joined: Apr 2007 Posts: 432 McCrae Y.C. Mornington Peninsu... Simon C
Posts: 432 McCrae Y.C. Mornington Peninsu... | Hi Gary, 10 degrees forward, port canted out 35 degrees, starboard canted in 26 degrees... Might give me a chance to catch you some time  On a more serious note... what's the thinking behind verticle? Is it because they were that way in the Flyer or do you have a theory? Cheers
Simon Taipan AUS341
[Re: Simon C]
#215716 07/10/10 11:43 PM 07/10/10 11:43 PM | thricebitten
| thricebitten
Unregistered | Hi Simon, why would you imagine I would have a theory?  Well it does seem that all cats that do not have measurement restrictions on distance back that centreboards are placed built in recent years, have vertical centreboards and that incudes the Flyer ones I have bought. As far as I can see the only reason for raking centreboards back is when you want to move your Centre of Lateral Resistance further back and rules do not allow it. I am hoping that the smaller centreboards vertical will not move CLR forward much if any at all, as the rudder blades will actualy account for a larger pecentage of the CLR, than previously, helping to balance the fact that the tip of the centreboards will be further forward. Now for the theory  . When sailing long sailboards with swinging centreboards as the wind increased we found a effect we called railing up. This was caused by depressing the lee rail of the board on purpose which as the speed increased resulted in the centreboard lifting the board out of the water and helping it to plane, it also allowed you to point higher as you balanced the forces of the increased lift from the centreboard. No surprise I hear you say, you where using the centreboard as a lifting foil.  When the wind increased it would flip the board over, to stop this we would rake the centreboard back. My theory, raking centreboards back reduces lift  . On sailboards we use to even rake them forward in light winds, which increased lift even more, but made them very hard to control  . So there you have it, I hope to get more lift which should improve windward performance  . But expect it will make the boat twitchier? something I am willing to live with, I hope | | | Re: New Centreboards
[Re: ]
#215756 07/12/10 06:15 AM 07/12/10 06:15 AM |
Posts: 87 Gold Coast QLD | Hi Guys I'm new to the Mosquito class and I have just started to build my first one. I was Just reading your thread about boards and was wondering if you could point me in the right direction is there a reconmended board and rudder width and length that most people use other than the specs on the rules form? Thanks
Damien 1820 Raw Prawn (under construction)!!! QLD
[Re: Damo]
#215758 07/12/10 06:39 AM 07/12/10 06:39 AM |
Joined: Jan 2006 Posts: 556 Somers, Westernport Bay, Victo... Peter_Foulsum
Posts: 556 Somers, Westernport Bay, Victo... | Hi TBA and welcome to the swarm.  I hope that your building all goes to plan and you have your new Mozzie on the water for the start of next season.  Where do you plan to sail/race and what is your sail number ? Any details would be greatly appreciated for addition to the Mozzie register. If you don't want to make it public just send me a PM through this forum site. In terms of centreboard width and length there are many variations but most have a width of around 250 mm and a length just greater than 1 m. My current centreboards are 10 inches wide by 1020 mm long. These were cut down from the original timber boards which were much wider and longer and I have seen no adverse effects. Regards, Peter
Mosquito 1814 Macka Mozzie
[Re: ]
#215760 07/12/10 07:03 AM 07/12/10 07:03 AM |
Posts: 556 Somers, Westernport Bay, Victo... | Hi Gary, My ancient Mozzie had vertical boards and when I made the change to the 10 degrees rake it made made an enormous difference.  That little shift in the centre of lateral resitance appeared to reduce the weather helm significantly and allowed me to set the rudders up close to vertical. I also reduced the width at the same time so that may also have had some effect. Mind you the aft edge of the centreboard case is not as far rearward as the modern Mozzie so that could account for some difference (3305 mm versus 3353 mm allowable) Jeremy Pearse did some experimentation with "A" class centreboards without much success. Not sure if they were 9" wide but they just didn't have the same tracking ability as the 10" boards. I'm sure Jeremy could give you some clarification. Regards, Peter
[Re: Peter_Foulsum]
#215761 07/12/10 07:06 AM 07/12/10 07:06 AM |
Posts: 87 Gold Coast QLD | Thanks for the reply and feed back Peter. Sail number 1820 (on the plans any way)I currently skipper a Nacra 5.8 out of Cleveland yacht club in Brisbane while i build the Mozzie but I live on the Gold Coast so when the boat is built probberly both places at this stage. I bourght an old hull mould from Jim Boyer recently and the hulls will be under way shortly, I know they are an older design mould but for my first boat these will do fine. Your tips on the foils are much appreciated, I can start to work on these in between the hulls. Time is my biggest problem at the moment so I'll just keep ticking along Thanks once again and look foward to joining the Mozzie clan Cheers Damien
[Re: Damo]
#215821 07/13/10 01:30 AM 07/13/10 01:30 AM | thricebitten
| thricebitten
Unregistered | Hi all, my new boards are 220 x 1005, effective length 550 under the hull. Old boards where 290 x 965, effective length 510 under the hull. No doubt placing cases as far back as legal in hull is essential, vertical as opposed to raked 10 degrees I guess I will find out.  or | | | Re: New Centreboards
[Re: Matt_Stone]
#215824 07/13/10 04:09 AM 07/13/10 04:09 AM |
Joined: Mar 2010 Posts: 77 Gippsland Lakes mitchellsailor
Posts: 77 Gippsland Lakes | Matt you're on the right track, but in fact it is I that have just bought the new sail :P. Time will tell if this is to beat you, Gary or both hahaha.
Mosquito 1750 Bonnie-GLYC / Peninsula
The plan was simple.... Like my brother in law Phil, except this plan just might work!
[Re: mitchellsailor]
#215922 07/15/10 12:46 AM 07/15/10 12:46 AM | thricebitten
| thricebitten
Unregistered | Hi M & M, my theory is never stop trying to go faster  . If I keep moving the goal posts hopefully you whipper snippers won't kick any goals  . Oh I have ordered new rudders also.  | | | Re: New Centreboards
#216492 07/26/10 04:02 PM 07/26/10 04:02 PM |
Posts: 87 Gold Coast QLD | Hi Guy's Thanks for the tips on the board sizes. Before I start you wouldnt have sudgestions for rudders as well? When I build the boards I can make the rudders at the same time, any help would be graitfull Thanks once again Regards Damien
[Re: Peter_Foulsum]
#216559 07/28/10 01:53 AM 07/28/10 01:53 AM |
Posts: 87 Gold Coast QLD | Hey Peter please check you PM Thanks Damien
[Re: DickenCider 1777]
#217748 08/17/10 06:02 PM 08/17/10 06:02 PM |
Joined: Mar 2003 Posts: 943 East Gippsland, Australia Tim_Mozzie
Posts: 943 East Gippsland, Australia | Hi AJ Good to see you on the forum at last.
Gary is planning to put them back to the max measurement, but not raked. Because they are narrower than the ones we have been using that also helps get the CofE a bit further back. Overall his CofE may end up slightly forward of the current boats but it is going to be very close.
It's just a question of whether the possible gains from having them vertical will outweigh any disadvantage from moving the CofE slightly forward. We will see...
Tim Shepperd Mosquito 1775 Karma Cat
2,530
guests, and 406
