| Re: best vmg
[Re: Leo Ambtman]
#215772 07/12/10 10:12 AM 07/12/10 10:12 AM |
Posts: 12,310 South Carolina | Can anybody tell me what gives the best vmg upwind. No steering or no sheet or a mix. What mix? short answer: It's a combination of both that depends heavily on sea state. I don't have the time at the moment for the long answer
Jake Kohl | | | Re: best vmg
[Re: Leo Ambtman]
#215789 07/12/10 12:33 PM 07/12/10 12:33 PM |
Posts: 1,203 uk | No easy answer, watch the Alinghi guys in the 1st AC race to see the debate going on.
| | | Re: best vmg
[Re: Leo Ambtman]
#215794 07/12/10 12:48 PM 07/12/10 12:48 PM |
Posts: 12,310 South Carolina | a medium answer: you need to steer slightly as when the boat is fully (over)powered, it will benefit from sailing slightly higher without loosing much speed...but not a whole lot higher and not grabbing that bite to windward too quickly. The sail needs to be eased to accommodate the immediate need for depowering while the helm eases up a little bite to windward slowly enough that the turning action doesn't slow the boat. When the puff relinquishes, the sail comes back in (with anticipation!) and the helm can bare back off slightly. The timing for this between the crew and the helm is very important and not an easy thing to get right.
If it's light to medium wind conditions, you can survive with some speed by cleating the sheet and steering to the wind although you will find that some small sheeting changes will greatly enhance your speed. If it's medium to high wind conditions and choosing between one or the other, you're better off holding the helm steady and sheeting the mainsail in and out....but again, to do both in concert is faster.
[Re: Leo Ambtman]
#215803 07/12/10 02:30 PM 07/12/10 02:30 PM |
Posts: 1,203 uk | With a gust the apparant wind veers aft. ????
| | | Re: best vmg
[Re: TEAMVMG]
#215826 07/13/10 06:28 AM 07/13/10 06:28 AM |
Posts: 3,528 Looking for a Job, I got credi... | With a gust the apparant wind veers aft. ???? Draw the vectors Paul; Best way to understand this is take it to extremes. If we are sailing up wind (at say 45 to true) in 1 kt of wind and we are travelling at 0.5kt; this will result in the apparent wind being somewhere forward at (guess) 30 degrees. Now make the wind jump to 20kts and the wind component vs boat speed component means the apparent will move aft (the angle will increase).
F16 - GBR 553 - SOLD I also talk sport here | | | Re: best vmg
[Re: scooby_simon]
#215827 07/13/10 06:53 AM 07/13/10 06:53 AM |
Posts: 12,310 South Carolina | With a gust the apparant wind veers aft. ???? Draw the vectors Paul; Best way to understand this is take it to extremes. If we are sailing up wind (at say 45 to true) in 1 kt of wind and we are travelling at 0.5kt; this will result in the apparent wind being somewhere forward at (guess) 30 degrees. Now make the wind jump to 20kts and the wind component vs boat speed component means the apparent will move aft (the angle will increase). Simon, thanks for that - I hadn't considered that effect properly myself either.
#215849 07/13/10 12:51 PM 07/13/10 12:51 PM |
Posts: 807 Hillsborough, NC USA | With a gust the apparant wind veers aft. Simon, thanks for that - I hadn't considered that effect properly myself either. It's commonly called a "velocity lift". The reverse effect - when you sail into a lull, is known as a velocity header. Regards, Eric | | | Re: best vmg
[Re: Leo Ambtman]
#215859 07/13/10 02:34 PM 07/13/10 02:34 PM |
Posts: 571 Hamburg | With a gust the apparant wind veers aft. For that reason you can wind up. However you have to wait for the boat to accelerate. The apparant may turn back and luffing is useless. In heavy wind it may be a bit different as the boat do not accelerate as much as in medium wind. Hi Leo, that's true, however it is less pronounced as on monohulls. Most beach cats have a very flat up wind vmg curve. That means it doen't matter if you go 50deg or 60deg to the true wind direction, the vmg will be pretty much the same. Also due to the high speed of a cat, the changes in apparent wind direction are smaller. Loosing speed due to excessive tiller action is far more worse. I try to do steering as a fine adjustment of heeling angle and waves and do the big stuff with the sheet. Keep the speed up, more speed is more lift from the foils. With speed you can point higher, with speed you can manouvre more quickly and with speed the boat behaves better in waves. Go first for speed than for hight. Cheers, Klaus | | | Re: best vmg
[Re: Leo Ambtman]
#215869 07/13/10 03:38 PM 07/13/10 03:38 PM |
Posts: 2,584 +31NL | When you sail in a lull it is useless to fall off as the headwind turns with you. The best is to go on and wait till the wind picks up again. So not the opposite of what you could do with a gust (luffing). I'm no expert but my understanding is that by sailing a little bit lower in the lulls you will pickup a puff earlier as they move down the course. IMHO sheeting, operating the cunningham, and steering as little as possible is the fastest. | | | Re: best vmg
[Re: Tony_F18]
#215885 07/14/10 08:36 AM 07/14/10 08:36 AM |
Posts: 120 | Tony has it spot on, it is a concert between driving / sheeting and cunningham.
In a puff, ease main (talking inch or two MAX), point up a bit ( a degree or two). We generally ease main slightly delayed from pointing (i.e if point is going to take more then a degree or two, ease). If the main is constantly eased (i.e two inches of main sheet out more then it should be), cunningham goes on a bit to de power main.
On the F18 (at least C2 / Capricorns) the crew does main and cunningham as they can sheet in and out faster, this also requires a lot of practice and good communication with skipper. The skip takes the main in lighter air (and of course downwind).
Side note: if the cunningham is max on and you are still overpowered, take a look at diamond tension, probably could be tighter.
| | | Re: best vmg
[Re: maritimesailor]
#215886 07/14/10 08:51 AM 07/14/10 08:51 AM |
Posts: 12 | This is a great discussion, I've been trying to come up with a good 'rule of thumb' for how to handle this myself and had been under the impression that you want to keep the sheet on and play the traveler in the puffs to prevent the main from getting too much shape, power, and drag. Playing the traveler can be tricky, I've found that it doesn't always want to move when the sheet is fully on, looking forward to playing the sheet this coming weekend instead. Thanks guys!
| | | Re: best vmg
#215887 07/14/10 09:02 AM 07/14/10 09:02 AM |
Posts: 3,528 Looking for a Job, I got credi... | Side note: if the cunningham is max on and you are still overpowered, take a look at diamond tension, probably could be tighter.
Erm, ease the traveller. Diamond tension does a number of things depending on spreader rake.
[Re: smv]
#215888 07/14/10 09:29 AM 07/14/10 09:29 AM |
Posts: 12,310 South Carolina | Also note that with a straight traveler in-line with the rear beam, the action of releasing the traveler down the beam actually sheets the mainsail in tighter.
1) set diamond wire tension for the conditions anticipated that day 2) upwind sailing, work the downhaul to control power in gusts combined with some light helm corrections. 3) upwind sailing, when the downhaul is no longer enough to control the power in the boat, the crew needs to set the downhaul in a moderate to upper position and start working the mainsheet in and out slightly...again in conjunction with some light helm correction. 4) when it's getting really sporty upwind, and the crew is having to really saw the main in and out deeply, it's time to drop the traveler an inch or two and leave it there. Continue working the mainsail and helm.
#215890 07/14/10 09:57 AM 07/14/10 09:57 AM |
Posts: 3,528 Looking for a Job, I got credi... | Also note that with a straight traveler in-line with the rear beam, the action of releasing the traveler down the beam actually sheets the mainsail in tighter.
1) set diamond wire tension for the conditions anticipated that day 2) upwind sailing, work the downhaul to control power in gusts combined with some light helm corrections. 3) upwind sailing, when the downhaul is no longer enough to control the power in the boat, the crew needs to set the downhaul in a moderate to upper position and start working the mainsheet in and out slightly...again in conjunction with some light helm correction. 4) when it's getting really sporty upwind, and the crew is having to really saw the main in and out deeply, it's time to drop the traveler an inch or two and leave it there. Continue working the mainsail and helm. And if that’s not enough; bring the plates up a little might help. If it get really sporty; max downhaul; and de-rotate the mast.
[Re: scooby_simon]
#215897 07/14/10 11:52 AM 07/14/10 11:52 AM |
Posts: 5,590 Naples, FL | you would think that with all this emphasis on playing the downhaul, they'd make that line a little more forgiving on the hands.... But maybe it's just me and my house bi*ch hands...
| | | Re: best vmg
[Re: Leo Ambtman]
#215900 07/14/10 12:42 PM 07/14/10 12:42 PM |
Posts: 337 Arizona | Great thread. I also have been playing the travler w secondary adjustments by steering. I will be going out tomorrow and will try using the downhaul and sheet activly and leave the travler alone. I just doubled my purchase on the downhaul, so I think this is more viable now. Thanks for the info.
Auscat MKV 444 A class NACRA I-20- 440/CATHATKA | | |
2,834
guests, and 321
