| Sail tube help #21601 06/28/03 02:26 PM 06/28/03 02:26 PM |
Joined: Jun 2003 Posts: 3 Memphis, TN streetdoc432 OP
Posts: 3 Memphis, TN | Where is a good place to start looking for sailtube material? Do HVAC suppliers carry 14" 3/16 wall PVC? The largest diameter PVC at my Home Depot is 8". Any suggestions? [color:"blue"] [/color]
1989 Hobie 18 Magnum. Harken hardware. Plum Crazy sails.
| | | Go to a commericial irrigation supplier
[Re: streetdoc432]
#21602 06/28/03 03:39 PM 06/28/03 03:39 PM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen
Posts: 1,037 Central California | Go to an industrial/commercial irrigation supply--they'll have every size and length you could ever want. Check the yellow pages--it may take a few phone calls.
I got a great deal on a 14 ft long 12 or 14" diameter because the end was chipped. So ask to see what they've got in their "scrap" pile. I just sawed off the chipped end to square it up with a hand saw. I also bought end caps. Works great--fits my sails, rudders, wetsuits, life jackets, etc. Good luck.
| | | Re: Sail tube help
[Re: streetdoc432]
#21604 06/29/03 05:36 PM 06/29/03 05:36 PM |
Posts: 12,310 South Carolina | I got mine at an industrial plumbing supply place (sewer, etc.). They had some extra laying around that they practically gave me.
Jake Kohl | | | Re: Gann Industrial Supplies Inc
[Re: samevans]
#21609 06/30/03 06:22 PM 06/30/03 06:22 PM |
Posts: 139 Daytona Beach FL | Here is a Q that might be a bit off topic, but what about using a thin wall, light-weight PVC tube for a snuffer? I think the Tiger uses something like that.
Is there such thing as thin-wall PVC tubing?
94 N5.5SL
| | | Re: just use a handsaw
[Re: MauganN20]
#21613 07/01/03 12:59 PM 07/01/03 12:59 PM |
Joined: Jun 2001 Posts: 975 South Louisiana, USA Clayton
Posts: 975 South Louisiana, USA | The 12" double wall pipe you should be able to pick up for about $4/ft. Check around you may find someone to sell 1/2 of a section. Clayton Disclaimer... We're a distributor but we're too far to do you any good. So this is not an ad. | | | Re: thin wall PVC tubing
[Re: TheoA]
#21615 07/03/03 09:26 AM 07/03/03 09:26 AM |
Posts: 217 | Most home depot-type store sell 4" diameter PVC pipes for sewer lines - i.e. not required to hold pressure, so they are thin wall. 4" may be too small for a snuffer, but there may be 6" or larger diam available from a specialty place.
362
guests, and 51
