| High winds #21670 07/01/03 03:17 AM 07/01/03 03:17 AM |
Joined: May 2003 Posts: 4,451 West coast of Norway Rolf_Nilsen OP
Posts: 4,451 West coast of Norway | Hi,
last weekend we was out distance racing with the big monohulls. My wife was crewing on the Tornado and we was having a good time in low winds. Typical 1 - 2 meters a second. As we passed an crossing fjord the wind changed to a beam reach and 11 - 13 meters a second (measured with wind instruments on a mono). We was of course having a good time, albeit wind against stream made some quite steep waves. The monos surrounding us was properly impressed..
After rounding a mark, we had to go upwind against the 11 - 13 m/s wind. This was only the third time my wife sailed the Tornado, and the first time in a trapeze harness. We abandoned the race after about half an hour of beating, and reached off home instead.
The reason we abandoned was that I did not want to sail dead downwind in that amount of wind with my wife. As it is now, she is keen to go sailing and trapezeing again. But after a pitchpole I dont think I would see her anywhere close to the Tornado again.
All this brings me to my question: When will a 16, 18 or 20 feet long cat pitchpole. How hard does it have to blow if your hulls are in good shape (clean og smooth) and you sail dead downwind. Both crew on the back of the boat, and using both bows for bouancy forward. I have stuffed both bows dead downwind several times with the old Tornado rig. But have not had an opportunity to try it with the new rig..
Any good ideas about 'survival sailing' downwind i heavy winds ?
Is it prudent to avoid the kite when it blows above 10 m/s ?
Btw: An 28 feet monohull averaged 23 knots with spi downwind in those conditions..
For those not using the metrical system, here is a small comparison table.
2.5 m/s = 4 knots 4,5 m/s = 9 knots 6,5 m/s = 13 knots 9,5 m/s = 18 knots 12,5 m/s = 24 knots 15,5 m/s = 30 knots | | | Re: High winds
[Re: Rolf_Nilsen]
#21677 07/02/03 09:56 AM 07/02/03 09:56 AM |
Posts: 465 FL | For steering DDW try using the following (3)three indicators, that kind of 'check and balance' each other. First, the bow wind indicator. Second, pay attention to the feel on helm. You can maintain a very slight weather to neutral helm with the sails stalled out. If the helm goes a lee you WILL eventually jibe, so push the helm away from you to get back to neutral helm. If the weather helm helm increases pull the stick to get back/close to neutral helm. Finally, with the jib strapped in (stalled) watch which side the jib FAVORS, as it oscillates back and forth (how it behaves) out of the corner of your eye, and react accordingly. This is useful when it is raining so hard you can not see the bridal fly.
In Kevin's picture you can see the crew let both jib and main out, opening the slot(lift), increased sail area, etc. I have found offshore in squalls the shifts are gradual enough to react, but ounce you get close to high land or on lakes geographical shifts hard to anticipate/predict. Looking behind you, often helps, as you can sheet in before the puff (dark water) hits you. Its fun watching the other boats go over next to you, as they let OUT their sails. As for the kite perhaps someone else can enlighten us? | | | Re: High winds
[Re: Rolf_Nilsen]
#21679 07/03/03 09:19 AM 07/03/03 09:19 AM |
Posts: 800 MI | Hi Rolf good topic , Think many new catsailors get used to luffing the boat up into the wind direction going to windward and close reaching .-Many then continue this luff UP reaction when sailing downwind . The most difficult aspect for catsailors new to the spin is getting accustom to bearing OFF the wind in gusts . Realizing exactly where the wind is and how it is flowing across the sails and understanding when to bear of or head up ,-this transition from flow direction is key to staying upright ,-as we all do in rounding C mark . Earlier posters had difficulty with this in higher winds for this reason ,-the transition and power increase . Sailing down-wind the sails are slightly stalled which reduces force on them ,-as we head up to the new course we are heating it up momentarily until we reach the opposite upwind mode of luffing up inside the wind direction again . Keeping maximum speed through this transition and out on the wire are important ,understanding -moment,- boat speed ,-wind direction ,-the stuff of sailing ,--sailing well ,--we all learn by trial and error ,we all take some lumps in doing so , its part of the sport . One thing you have with the T CAT DESIGN IS AN EXTREMELY WELL DESIGNED CRAFT , BUT --it was designed originaly with a pin top main sail with less sail area and no spin . The very fine bow sections as orginally designed allow the T to slice through chop and small waves . NOW the added power of the new rig will power those fine sectioned low volume bows into waves and will keep going .Someting the original design did not antisipate ,--a larger sq top main and spin the added forces from them . We see most new spin rigged designs with much more volume forward . The T is ONE OF the most competitively raced class at the top levels so excellent technique and boat tuning modifications set up for higher winds and seas will compensate ,-trap locations of crew ,-sailing more downwind angle with spin ,-depowering the main ,-etc. The spin does help provide some lift downwind but also increases speed off the backs of waves and into the next . Steering through very confused seas with irregular patterns or crosswaves with tidal current while maintaining this awareness of wind angle becomes the task that top skippers have {almost } mastered . Evan the top Worrell -Tybee teams still flip ,--sometimes numerous times in a leg of the race . Safety lines to keep the crew in place on the wire and footstraps are a must have in these conditions . It is some of the most fun you can have on a cat ,-strapped in trapped off the back ,shute up ,--surfing down and flying off the back of big waves , -especially exciting at night . Have fun Carl
| | | Re: High winds
[Re: sail6000]
#21680 07/03/03 01:05 PM 07/03/03 01:05 PM |
Posts: 4,451 West coast of Norway | More good advice here! You mentioned de-powering the main while sailing with the spi. Do you really propose to use lots of downhaul in hard wind ? I would believe the compression forces on the mast to exceed the limits if you did ? Otherwise, stuffing the bows with the old pinhead main is easily done. You dont need the new rig to do a proper 'submersion'  Your note about taking off one wave to stuff the bows into the next is now written in letters of fire in my book. I guess having lots of weight at the outmost back of the boat is important. I weight in at 92 Kg and my most regular crew at almost 100 Kg, so we always hope for som real wind when competing. BTW: I saw a really awsome pitchpole executed in this way on the video "Awesome Aussie Skiffs". Launched off a wave and stuffed the nose into the next. Crew went flying and instant pitchpole. The video is highly reccomended. | | | Re: High winds
[Re: jollyrodgers]
#21682 07/07/03 02:06 PM 07/07/03 02:06 PM |
Posts: 12,310 South Carolina | The following happened to me a few weeks ago and I still can't figure out what I should do in these circumstances:
Sailing off the wind on a beam reach we're running down the beach hauling gluteous maximus...wind at about 15knots. 4 to 6' waves are coming from nearly the same direction and would be quartering off our stern if we were sitting still. When coming down the larger waves the bows are digging in hard into the back of the next wave. Four pitch poles and a lot of cussing later, we gave up.
Question: how do you compensate for gusts and/or the large waves at this attitude? If you turn downwind to depower, you're steering deeper into the trough and harder into the back of the next wave. If you turn up to ease the angle into the trough, you're powering up the boat by going into a reach. Will maintaining boat direction but hardening up the sails accomplish the depowering needed? My initial reaction would be to steer up at a higher angle to the waves and trim your sails carefully to depower on the reach.
I had a crew that had never been on a sailboat before so I was a little leary to put him in a situation where he had to constantly react - although in hindsight, that probably would have been better than the four capsizes (BTW, he's still itching to go again). The times I did react and try to steer down, I think I was doing so too late - we were racing and I was coaching him too much and not paying enough attention to our position with the waves.
Jake Kohl | | | Re: High winds
[Re: nesdog]
#21684 07/07/03 09:37 PM 07/07/03 09:37 PM |
Posts: 20 | On the flat water of the inland lakes I sail, when the wind howls its time to sheet in, travel up, drive down and move to the back of the bus. I've run the bow on my 6.0NA down to the foil on a (really) broad reach and never felt like I was going to auger in. However I drive as deep as I can without sailing by the lee, guessing >>135° apparent, which aides in keeping the windward hull down if not just barely out of the water. Gybes are terrifyingly fast when sailing a narrow track. Stopping is a different matter as hitting the beach full bore is bad. More on that when I finally figure out the brakes on this thing. Rounding up into the wind to luff is scary when moving that fast.
Nacra 6.0NA to kill myself quickly and a Johnson 18 to do it a little slower.
| | | Re: High winds
[Re: Nacra546]
#21686 07/08/03 07:03 AM 07/08/03 07:03 AM |
Posts: 12,310 South Carolina | I will attest to the fact that in order to pitch-pole a Nacra 6.0NA you have to bury it up past the main beam. It can be done! (ouch). I'm really beginning to learn to watch over my shoulder when sailing downwind in the heavy stuff!
#21687 07/08/03 08:18 PM 07/08/03 08:18 PM |
Posts: 58 Canberra, Australia | As a sailor of a shorter hulled boat (Taipan 4.9), sailing downwind in a big blow can be a little hairy at times. One of the best things we've learned to do is to pull the centreboards up over about 18kts. Keeping them down helps with doing the 'wild thing' under that. Down the 'back of the bus' is definately the order of the day usually with skipper on windward hull or just inside and crew on leeward hull hanging on for grim death while being firehosed with spray from the leeward bow. Keeping the downhaul on while going downwind in a blow is fine in my opinion. I've had a few big stacks and some broken battens but the mast is fine. The last thing that you want to be doing is easing it to bag up the sail and give you even more power. Also, with an adjustable wing mast we reduce the rotation angle to depower the rig further. All this is up to around 25kts and depending on the sea state its still fairly manageable with the traveller somewhere between the footstrap and the inside of the hull. Heading is fairly 'hot' - enough to get the windward hull out or at least put the weight on the leeward one (just be ready to bear off real quick and watch for puffs). Above 25kts we're pretty much in survival territory and I find that heading lower so you are just above DDW with both skipper and crew sitting on the high side is the way to go (not terribly quick in a racing context but should get you to the bottom mark). I find having the crew sitting on the hull at the top and then the skipper on the tramp somewhere near the top footstrap is the most comfortable (if you can call it that). Some people have one crew out on the wire right down the back of the boat sometimes but you run the risk of getting wiped out by a passing wave. Sheeting the main in even more is also beneficial as it really depowers the top of the rig especially and stops some of the bow-down attitude a little. Only problem is getting over the 'ease out' mentality in the puffs because this will just load it all up again. Just by-the-by, that photo of John and Darren was taken in Sydney Harbour while training for a world championships I think. The 'Blast' referred to had both of them on trapeze with a standard (non turbo) rig and is a great video to watch if you can find it anywhere. also, there is a Tornado class forum at the Tornado Homepage if you haven't already seen it. cheers!
Taipan 4.9 AUS129 AlphabetSoup
| | | Re: High winds
[Re: ABC]
#21689 07/09/03 05:04 AM 07/09/03 05:04 AM |
Posts: 4,451 West coast of Norway | ABC: Whow, Taipan 4.9's.. I want one of those for solo sailing and sailing with our little girl. Got the plans from AHPC a month ago, but to busy sailing these days. It sounds like you sail the Taipan just like the Tornado without a kite. I would not hesitate to use the downhaul if we was overpowered without the kite. With the kite, i guess downhauling the main does not affect the sailplan in the same way and the compression in the mast would be positively huge ? I'm following the Australian Taipan butt. via your website and discussion group. It sounds like you have a great class going on a really good boat! The Tornado discussion forum on the ITA website has had issues since day one. On the new web site, which is under construction, they are still referring to the old forum.. I sure hope they get to fix it before they release the new site. I guess these tecnical issues are why there has been so few postings.. Alive: What kind of Marstrom mast do you use. The 'new' one with thicker walls in the extrusion, or the standard one ? We have got the standard mast, and also a really stiff IYE mast from the 80's. Thanks for the advice with regards to the kite and trapeezeing. With the crew standing on the rudder, wont that disrupt your helming ? Or has he got most of his weight on the front foot ? As we are running things by now, the crew trapezes just behind the skipper, on skippers trapeeze. I will introduce him to your concept today  Btw. your website seems to have gone away. The domain seems to have been deleted from all name servers. Better check it out with your ISP before someone comes and 'squats' on it. | | |
4,838
guests, and 650
