| Top speed for the Hobie 18 #21711 07/02/03 11:26 AM 07/02/03 11:26 AM |
Posts: 7 | Hi,
Does anyone know where I can find the practical top speed for my boat? It's a Hobie 18.
Thanks.
Kirk
| | | Re: Top speed for the Hobie 18
[Re: h17windbtch6333]
#21713 07/02/03 01:27 PM 07/02/03 01:27 PM |
Posts: 7 | I'm glad to hear about the trailer. That's with the jib out or furled?
But seriously... There must be a practical limit, caused by, for example, the ability of the available weight of the helmsman and crew to keep the windward hull down. Or perhaps there is a maximum hull speed that is reached before that point?
I know there is a formula for estimating the max speed of a keel boat. (I think it's max speed in knots = 1.34 X square root of the boat length in feet.) But the formula doesn't apply to catamarans.
Kirk
[Re: kirkl]
#21715 07/02/03 02:36 PM 07/02/03 02:36 PM |
Posts: 3,114 BANNED | | | | Re: Top speed for the Hobie 18
[Re: MauganN20]
#21716 07/02/03 03:14 PM 07/02/03 03:14 PM |
Posts: 264 Neb | | | | Re: Top speed for the Hobie 18
[Re: catman]
#21718 07/02/03 05:32 PM 07/02/03 05:32 PM |
Posts: 7 | Thanks Mike.
I searched, as you recommended, and found some references. The only real practically arrived at number was 24.6 mph (which is 21.4 knots), posted back in 12/02. This fellow measured using a GPS. I'm going to take this as a "minimum maximum speed", for now.
I'm a brand new sailor. Knowing the limits of the craft gives me something to assess my own progress against. Not that I intend to set any speed records, but it just puts my own performance in perspective.
I bought a SpeedMaster trailing impellor knotmeter. It seems to work well. I clocked 12.8 knots Monday in moderate winds. Even that modest speed was lots of fun for me. I can't wait to get out in some stronger winds. (I'll probably dump us, but I'm sure it'll be great while were flying.)
Kirk
[Re: kirkl]
#21719 07/02/03 11:52 PM 07/02/03 11:52 PM |
Posts: 14 Seabrook, Tx | Hey Kirkl Where did you find that knotmeter? Sound like a fun gadget. }=)))*>
PrindleFish }=)))*>
[Re: PrindleFish]
#21720 07/03/03 06:36 AM 07/03/03 06:36 AM |
Posts: 7 | It's a "SpeedMate" (sorry, not SpeedMaster as I previously wrote) Knotmeter from Speedtech. It displays current speed, max or average speed and distance travelled. It comes in a couple of models: one where the impeller has to be stuck to your hull; and another with a trailing impeller -- basically a wire with the impeller at the end that you drag behind you. In both cases there are no holes to drill  . I bought the trailing impeller, since you never know if the hull you attached the gizmo to might be out of the water. It works great, so far. (I've only had it a week.) I bought the thing online directly from Speedtech at www.speedtech.com. They're having a small sale on it right now for $160 U.S. (down from $180). It keeps the maximum speed even when off, until you reset it. That way your friends can't falsely claim to have beaten your record!
Kirk
[Re: kirkl]
#21721 07/03/03 08:50 AM 07/03/03 08:50 AM |
Posts: 7 | Hey! When I posted this I expected to see all kinds of people bragging about how fast they've pushed their Hobie 18. When I got a question about my knotmeter, I started thinking... Maybe very few people actually know how fast they go. Is that so? Am I the only anal-retentive to search out and install a knotmeter on a Hobie 18?
Kirk
[Re: kirkl]
#21722 07/03/03 08:57 AM 07/03/03 08:57 AM |
[Re: kirkl]
#21723 07/03/03 09:04 AM 07/03/03 09:04 AM |
Posts: 12,310 South Carolina | Installing a knot meter or using a GPS eliminates your ability to broadly exaggerate during campfire stories! GAWD! AND WE CAME DOWN THIS WAVE DOIN' LIKE 30 KNOTS MAN!!!!
Jake Kohl | | | Re: Top speed for the Prindle 19
[Re: kirkl]
#21724 07/03/03 10:44 AM 07/03/03 10:44 AM |
Posts: 364 | by gps was 25.7 mph, under spinnaker.
Andrew Tatton
Nacra 20 "Wiggle Stick" #266
Nacra 18 Square #12
[Re: kirkl]
#21725 07/03/03 12:25 PM 07/03/03 12:25 PM |
Posts: 1,307 Asuncion, Paraguay | It keeps the maximum speed even when off, until you reset it. That way your friends can't falsely claim to have beaten your record! Your friends won't trust it anyway - you can cheat with a blower, a drill, etc. to rotate the impeller faster then the boat sails
Luiz
| | | Re: Just a little faster than you should
[Re: Matt M]
#21727 07/03/03 06:00 PM 07/03/03 06:00 PM |
Posts: 7 | Sounds right to me. I was interested in max speed more as an indicator of fun level and fearlessness than ability, really, anyway.
Do you think that speed is a good indicator, for a particular wind and tack, of how well trimmed you are?
Kirk
2,609
guests, and 268
