Spinlock for spin halyard #217954
08/22/10 12:16 AM
08/22/10 12:16 AM
Missoula, MT, USA
uogecko Offline OP
uogecko  Offline OP
Missoula, MT, USA
Is anyone using a spinlock for their spinnaker halyard? How have you rigged it? Which model are you using?
Re: Spinlock for spin halyard [Re: uogecko] #217958
08/22/10 03:37 AM
08/22/10 03:37 AM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
I'm happy with the one I'm using with 6mm halyard mounted on the beam about 8 inches from the mast. I have a block about 2ft behind the spinlock so that it doesn't accidentally get uncleated you have to pull the halyard up between the block and the spinlock to uncleat.
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: Spinlock for spin halyard [Re: JeffS] #217964
08/22/10 07:08 AM
08/22/10 07:08 AM
Missoula, MT, USA
uogecko Offline OP
uogecko  Offline OP
Missoula, MT, USA
The stock spin cleat setup on the Infusion seems unacceptable to me. The halyard catches in the cleat during a douse every time.
Have any Infusion sailors replaced the cleat on the mast with a Spinlock? Where do you put it?
Do you get the swiveling Spinlock or the one that does not turn? Do you mount a block somewhere that leads to the Spinlock?
Re: Spinlock for spin halyard [Re: uogecko] #217973
08/22/10 10:33 AM
08/22/10 10:33 AM
Toronto, Ontario
pitchpoledave Offline
Toronto, Ontario
The stock setup works well. You may have to rotate the cleat so that the jaws are down and you may have to rotate the jaws so that the line can drop out of the cleat.
Re: Spinlock for spin halyard [Re: pitchpoledave] #217974
08/22/10 10:38 AM
08/22/10 10:38 AM
Missoula, MT, USA
uogecko Offline OP
uogecko  Offline OP
Missoula, MT, USA
Dave, I'm interested in your stock setup - mine is stock too but it doesn't work well at all. I have a swiveling cleat on the starboard side of the mast above the mainsheet downhaul cleats. I don't believe the jaws are adjustable. The spinnaker halyard releases by pulling it up out of the cleat jaws, but then it goes a bit outboard and down to the trampoline. While I'm snuffing the chute the line recleats itself every time.
Re: Spinlock for spin halyard [Re: uogecko] #217978
08/22/10 10:56 AM
08/22/10 10:56 AM
Toronto, Ontario
Toronto, Ontario
yes.. take the whole block/wheel assembly and disconnect it from the mast and re-attach it upside down. The jaws are bolted on to this assembly and they need to also be unbolted and flipped upside down.
Re: Spinlock for spin halyard [Re: uogecko] #217980
08/22/10 10:57 AM
08/22/10 10:57 AM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
The Infusion should release by pulling down not up. Your swivel cleat may be wrong side up. Mine goes through a block on the trampoline after the cleat allowing it to be uncleated from the port side easily by pulling through the block. Mounted correctly there is no way that it could accidentally recleat itself. We have had the cleat on the mast since we started sailing F18s and like it. I do not use Spinlocks for halyards I have broken too many in that application. I use spinlocks for Cunningham as they are so easy to undo when loaded hard.
Re: Spinlock for spin halyard [Re: Dan_Delave] #217981
08/22/10 11:01 AM
08/22/10 11:01 AM
Missoula, MT, USA
uogecko Offline OP
uogecko  Offline OP
Missoula, MT, USA
Great advice - thanks guys. My assembly is definitely upside down then.
Anybody have a picture of the way they have their cleat on the mast?
Re: Spinlock for spin halyard [Re: uogecko] #217983
08/22/10 11:46 AM
08/22/10 11:46 AM
Toronto, Ontario
Toronto, Ontario
no I don't sorry.
Re: Spinlock for spin halyard [Re: pitchpoledave] #218021
08/23/10 01:18 PM
08/23/10 01:18 PM
Dan_Delave Offline
Dan_Delave  Offline
Take the cleat off and turn it upside down on the Pivoting system. Like the one on the left. No straps to keep the line any place it will work fine this way.
Later,
Dan
Re: Spinlock for spin halyard [Re: Dan_Delave] #218026
08/23/10 02:35 PM
08/23/10 02:35 PM
Missoula, MT, USA
uogecko Offline OP
uogecko  Offline OP
Missoula, MT, USA
I'll give it a try! It looks like with this setup when you uncleat the halyard it will drop between the metal jaws of the block beneath the cleat which would allow it to run free.
Re: Spinlock for spin halyard [Re: uogecko] #218075
08/24/10 01:02 AM
08/24/10 01:02 AM
Dan_Delave Offline
Dan_Delave  Offline
That's the plan.
Re: Spinlock for spin halyard [Re: Dan_Delave] #223339
11/04/10 02:53 PM
11/04/10 02:53 PM
C
conrad dxb Offline
conrad dxb  Offline
C
uogecko, the std system is used by the ex world champs, it is much safer than a spin lock, you may want to use a spin lock on the down hauls though, this allows fast release from heavy loads form hard sailing conditions
0 registered members (), 2,538 guests, and 257 spiders.
