Re: Gelcoat [Re: Mugrace72] #218591
08/30/10 02:13 PM
08/30/10 02:13 PM
Wilmington,NC
Dlennard Offline
Dlennard  Offline
Wilmington,NC
They do say cold causes shrinkage
Re: Gelcoat [Re: JACKFLASH] #218592
08/30/10 02:33 PM
08/30/10 02:33 PM
srm Offline
srm  Offline
Originally Posted by JACKFLASH
I think your ratio's are off. When using layup resin one ounce of resin would use 10 drops of hardner. I would assume that gelcoat would be a similar property. Pledge in the spray can is a great air inhibitor and readily available.
I agree. The number that comes to mind is 12 drops of hardener per ounce for polyester resin. I've had good results using the west marine finish gelcoat with wax in the formula. Mixing throughly is also important. Once you think you've mixed it enough, mix it some more.
sm
Re: Gelcoat [Re: srm] #218617
08/30/10 08:32 PM
08/30/10 08:32 PM
Columbia South Carolina, USA
dave mosley Offline
dave mosley  Offline
http://www.youtube.com/watch?v=en-8SbhdF_k&feature=related
pretty good video on gel coat repair.
BTW it states 20 drops per Oz
Re: Gelcoat [Re: Mike Hill] #218638
08/31/10 10:54 AM
08/31/10 10:54 AM
fastcats Offline
fastcats  Offline
Originally Posted by Mike Hill
Grab some of your girl's hair spray. Spray it on there. Then apply just a little heat from a hair dryer. Don't go melting anything. That will start the reaction. Wait 24 hours then sand.
What brand of hair spray?
Re: Gelcoat [Re: dave mosley] #218640
08/31/10 11:18 AM
08/31/10 11:18 AM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
1 oz of fluid is about 500 drops. If you are looking for a mixture:
1% = 5 drops
2% = 10 drops
4% = 20 drops
I use about a 2% mix for regular resin. I use about twice that much for gelcoat. Gelcoat takes longer to dry. Gelcoat is, in effect, resin, pigment (for color), and a thixotropic material. The additives retard the gelling properties of the resin.
If you really want to know and are interested do this experiment. I took some resin classes in college and one of the requirements was to see what resins, gelcoats and epoxies did with different hardener ratios. I took an icecube tray, put equal amount of the same product (ie resin) in each of twelve compartments, then catalyzed them with different amounts. Start with lower than recommended, say 1/2% and increase by 1/2% each until you get to about 6%. Do not stand too close, that 6% will smoke. See how long it takes for each to harden. Your hot one will harden in minutes and probably crack. The slow one may not harden for a couple of days. You will get a really good idea about how your resin reacts and know what you will be comfortable for you.
Re: Gelcoat [Re: Dan_Delave] #218642
08/31/10 11:20 AM
08/31/10 11:20 AM
Dr. DeLave!!!
Re: Gelcoat [Re: John Williams] #218651
08/31/10 12:28 PM
08/31/10 12:28 PM
Dan_Delave Offline
Dan_Delave  Offline
EXACTLY!!!
Re: Gelcoat [Re: Dan_Delave] #218717
09/01/10 11:23 AM
09/01/10 11:23 AM
dave mosley Offline
dave mosley  Offline
Is there a theory on slow vs quick hardening and strength?
Re: Gelcoat [Re: dave mosley] #218718
09/01/10 11:29 AM
09/01/10 11:29 AM
pgp Offline
pgp  Offline
I'm not aware of any. However, I've heard that using too much catalyst with epoxy can leave soft spots. Can't speak to the truth of it.
Pete Pollard
Blade 702
Re: Gelcoat [Re: pgp] #218719
09/01/10 12:43 PM
09/01/10 12:43 PM
Near SLC, Utah
tomthouse Offline
tomthouse  Offline
Near SLC, Utah
I can also tell you, from personal experience, that you certainly can add too much catalyst.
On one occasion I was very impatient, it was quite cold and I added lots more than called for.
The mixtures heated dramatically, then bubbled into froth and finally harden into a gooey consistency like messy foam.
It was very interesting to watch.
The final mess was (shall we say) less than useful so don't get carried away, as I did.
Re: Gelcoat [Re: John Williams] #218722
09/01/10 01:30 PM
09/01/10 01:30 PM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
This looks like Dan! -kinda
Originally Posted by John Williams
Dr. DeLave!!!
F-18 Infusion
#626- SOLD it!
Re: Gelcoat [Re: Karl_Brogger] #218770
09/02/10 12:03 PM
09/02/10 12:03 PM
Frozen Offline
Frozen  Offline
Originally Posted by Mugrace72
Wax paper is Wax paper Karl.
You get it at the grocery store next to the tin foil. confused
Right, I know where my hats come from. smile I was just fishing around in the pantry, (I wrote panty the 1st time, which'd be odd if I came across parchment), anyway, and I found parchment paper. It worked, nothing stuck to it. Blue 3M masking tape refused to sick so I figured it'd work.
The stuff I put down last night was rock hard this morning, so I roughed out the sanding and figured out where I needed to build it up more yet and laid down a second coat. I put in way more hardener than I thought I needed, and I probably did go too much because it started to thicken in a few minutes. It was also 90F today, but that set hard in 1/2hr, which was helped a bit by the sun.
They aren't perfect, but both have tips again. I need to do some more touch ups yet, but I'm leaving for Nebraska tomorrow morning, so thats not going to happen.
Thanks again for the help guys!
The gelcoat hardening must have been related to the paper being in the panty er pantry.. smile
Most likely the problem was not enough hardener. The other things were just a bit helpful. If you stir it well I am not sure it helps to dirty two containers. I personally only do small batches at a time so I do not waste it when it hardens quickly. I also use rubber gloves because the stuff is a pain to get off. You can also put "liquid gloves" on which keep the stuff from sticking to your skin.
What is the problem with using plastic? I use it regularly with gelcoat and polyester. Never had a problem. In fact I think I remember someone telling me that if you put plastic or waxpaper over it as it hardens then the wax stays in the polyester so the next coat will stick better.
I put cloth or chopped cloth on with polyester initially and then put plastic on, then I squeeze out as much resin as I can and then put a many times folded rag on top of that and then a piece of wood to hold it in place and then I put as many spring clamps to push on it as I can fit. This is to squeeze out more resin. My repairs come out excellent. Took me many a repair to figure this stuff out.
Anyone know where I can find carbon fiber in cloth or ribbon at a reasonable price?
Alan F
Tiger
Re: Gelcoat [Re: Todd_Sails] #218805
09/02/10 09:40 PM
09/02/10 09:40 PM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
Nice goggles, are those Barz?
Eric Arbogast
ARC 2101
Miami Yacht Club
0 registered members (), 681 guests, and 362 spiders.
