| Vacuum Table #220288 09/25/10 05:20 PM 09/25/10 05:20 PM |
Posts: 1,449 | Folks, I have recently made myself a vacuum table for my next project for the flat panels, c/b and rudder construction. Cost about $100. Just a sheet on melamine and aluminum frame from 2x2 angle. Vacuum film stuck to the frame with mastic. A self adhesive weather seal stuck to the lower surface from the local hardware store. Seals between the frame and the melamine. Some line and pulleys to lift the frame up to he roof so I can work on the table. So simple and it works a treat.
I can pull 22 inches of mercury on this table.
Regards, Phill
| | | Re: Vacuum Table
[Re: Rolf_Nilsen]
#221115 10/07/10 05:55 AM 10/07/10 05:55 AM |
Posts: 1,449 | Rolf, Sorry, too busy building to take pics. The vacuum table is now hoisted to the ceiling of my workshop while I use the table frame as the base of a jig to assemble the Central mounting module of the Farrier trimaran that I'm building. Last week I made a 5mm thick glass plate on the table along with other stuff it was 800mm x 1200mm which I've cut into parts for the CMM. 9 layers of 450gm alternating Bi Directional and Double Bias cloth vacuumed down with around 10 pounds pressure per square inch. (Amazing how it adds up that is something like a total of 1536 pounds of pressure.) Based on weight and area measurements I achieved a 55/45% glass to resin ratio. When I lower the table down to make bulkheads I will take some pics of it. Regards, Phill
| | | Re: Vacuum Table
[Re: Rolf_Nilsen]
#225498 12/16/10 03:39 AM 12/16/10 03:39 AM |
Posts: 1,449 | Hey Rolf, As requested I took some pics. I've even created a folder for the F-85SR build and added some pictures of the vacuum table in action vacuuming the float bulkheads. F-85SR Build Photo Albumn
3,175
guests, and 228
Mod | | Forums35 Topics22,989 Posts268,931 Members8,150 | Most Online23,979 Sep 24th, 2025 | | | |
